03-09-2011, 13:18 | #16 (permalink) |
Freak Poster Join Date: Oct 2007 Location: ALgeria
Member: 621702 Status: Offline Thanks Meter: 21 | hwkupdateclient Locating HWK Upgrade server... HWK Upgrade server found! Preparing connection to server... Connecting to HWKUpgrade server... Connection to server failed: Socket Error # 10060 Connection timed out.(Une tentative de connexion a échoué car le parti connecté n'a pas répondu convenablement au-delà d'une certaine durée ou une connexion établie a échoué car l'hôte de connexion n'a pas répondu.) i use hwkupdateclient v 2.1.0 plz help |
03-10-2011, 16:48 | #17 (permalink) | |
No Life Poster Join Date: Oct 2007
Member: 608516 Status: Offline Sonork: 100.1607007 Thanks Meter: 123 | Quote:
07-13-2011, 17:21 | #19 (permalink) |
Freak Poster Join Date: Oct 2008 Location: india.burdwan
Member: 875675 Status: Offline Sonork: no Thanks Meter: 11 | Upgrade log: ---------- HWK Update Client v 2.2.0.0 ---------- ---------- HWK upgrade started:7/13/2011 9:49:26 PM ---------- -- Reset Failed, Trying to Repair UFS ... -- Boot Fail: C:\Program Files\Common Files\SarasSoft\Ufs.sdb ---------- Locating HWK Upgrade server... HWK Upgrade server found! Preparing connection to server... Connecting to HWKUpgrade server... Server connection successfully established. Authenticating on server... Authentication stage error: Access violation at address 00402D5D in module 'UpdateClient.exe'. Read of address 00000014 \ help me please |
07-14-2011, 05:38 | #20 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: Lake Mary (Orlando)
Member: 1016569 Status: Offline Thanks Meter: 229 | solution Quote:
09-10-2011, 09:54 | #22 (permalink) |
No Life Poster Join Date: Jun 2011 Location: earth
Member: 1591394 Status: Offline Thanks Meter: 552 | -- Reset Failed, Trying to Repair UFS ... -- Boot Fail: C:\Program Files\Common Files\SarasSoft\Ufs.sdb your ufs is damaged or usb cable bad contact me on yahoo ill try fix via team viewer id: kikaskikas |
09-10-2011, 10:30 | #23 (permalink) |
Freak Poster Join Date: Feb 2005 Age: 49
Member: 118395 Status: Offline Thanks Meter: 25 | for me Locating HWK Upgrade server... HWK Upgrade server found! Preparing connection to server... Connecting to HWKUpgrade server... Server connection successfully established. Authenticating on server... Authentication stage error: Error: Server returned unrecognized reply |
09-10-2011, 10:41 | #24 (permalink) |
Junior Member Join Date: Sep 2011 Location: jorpati-2 ktm,nepal
Member: 1651577 Status: Offline Thanks Meter: 5 | please cheak speed of ur net n try.some time due to slow net it show like that. n wait for 24 to 48 hours after making un sucess update.it take 24 to 48 hours to recover. |
09-23-2011, 11:50 | #26 (permalink) |
Junior Member Join Date: Sep 2010
Member: 1388560 Status: Offline Thanks Meter: 2 | all error list,,,, 1. HWK SD REPAIR ERROR: xxxxx HWK upgrade error. This error occures when HWK was affected by third-party tools before upgrade or your HWK is a clone. Please don't contact anyone, it's your own stupid fault. 2. Your account is suspended. Please contact your reseller! Your account is blocked by administrator. Please contact your reseller You need to provide your reseller at least the following information: - The date and invoice number of your HWK purchase - Full log given to you by upgrade client 3. No more upgrade logs. HWK module with this serial number was already upgraded. If you already upgraded your HWK, you need not to upgrade it again until directed. If you haven't tried to upgrade it yet, get this error on upgrade and cannot run latest software versions, please contact your reseller You need to provide your reseller at least the following information: - The date and invoice number of your HWK purchase - Full log given to you by upgrade client 4. Server is going to shutdown. Please try update in 20 minutes. Server is being stopped by administrator. Please try upgrade process again in 20 mins. 5. Account for this HWK module does not exist on server. Please contact your reseller! Account for HWK number with this serial does not exist on server. Please contact your reseller. You need to provide your reseller at least the following information: - The date and invoice number of your HWK purchase - Full log given to you by upgrade client 6. Authorization failed! Are you using the latest HWK Upgrade client software version? Server authorization error. Please ensure you are using the latest UFS suite and upgrade client software versions 7. Your account was closed by the server administrator. Please contact your reseller! Your account on server was closed by administrator. Please contact your reseller You need to provide your reseller at least the following information: - The date and invoice number of your HWK purchase - Full log given to you by upgrade client 8. Error: Your update client version is expired! Please download new client from the support area and start the upgrade again. Download new upgrade client from support area and try upgrading your HWK module with it. 9. Error upgrading applets: HWK UPDATE ERROR: xxxxxx Hardware problem occured during upgrade process. Please contact your reseller. You need to provide your reseller at least the following information: - The date and invoice number of your HWK purchase - Full log given to you by upgrade client 10. Error connecting to ufs: hwk login error: xxxx Error establishing data transmission channel with HWK module. Please ensure your module is present and is correctly installed. If you are unable to solve the problem by yourself - please contact your reseller You need to provide your reseller at least the following information: - The date and invoice number of your HWK purchase - Full log given to you by upgrade client 11. Authentication stage error: Server reported error:Not translated! Please select English language om the software's welcome page and retry upgrade process. Now error message will be shown correctly 12. Connection to server failed: Socket Error # 10060 Connection to server failed: Socket Error # 10061 Connection refused. Please disable or uninstall all installed antivirus and firewall software and retry upgrade operation. If the error persists, please ensure, that your internet provider is not using firewall also 13. Authentication stage error: Socket Error # 10053 Software caused connection abort. General TCP/IP failture occured. Please disconnect from internet (having your modem switched off for example), wait for 5-7 minutes and connect to internet again and retry upgrade process. 14. Authentication stage error: Socket Error # 10054 Connection reset by peer. TCP/IP connection to server from your PC is unstable. Please try to connect to internet via different internet provider. If you have no such possibility, please try to perform upgrade process several times until you get positive result. 15. Connection Closed Gracefully. Connection to server was suddenly terminated. Please retry upgrade process a bit later or try to connect to the internet via another internet provider and retry the upgrade. 16. Authentication stage error: Error: Server returned unrecognized reply. You are using an old version of the update client, please install the latest HWK Suite and use the update client from that version. 17. License 5 not active. Please contact your UFSx reseller and request a set of license keys for your UFSx device. Troubleshooting Box Auth Error 33 Dieser Fehlercode kann mit den Anweisungen auf folgender Seite gelöst werden: http://www./showpo...69&postcount=7 Box Auth Error 20 / 32 Dieser Fehlercode kann mit den Anweisungen auf folgender Seite gelöst werden: REQ->FBI Process - Box Auth Error 20 - GSM-Forum Box Auth Error 1 Das HWK Modul ist nicht in das Flash Gerät eingebaut. Der Einbau sollte das Problem lösen. Error 112-1-0219 Dieser Fehler erscheint, wenn ein HWK Cracker verwendet wird. Löschen Sie folgende Dateien (hwkkiller.dll + ufsloader.dll) aus diesem Verzeichnis: C:\WINDOWS\system32 Installieren Sie die HWK Suite dann neu. Authentication stage error: Server reported error: No more upgrade logs. Es ist kein weiteres Update erforderlich. Authentication stage error: Server reported error:Account for this HWK module does not exist on server. Please contact your reseller! Ihr Account ist noch nicht aktiviert oder es wird kein originales HWK Modul verwendet. Error Connecting UFS: HWK Error: -1 Kein HWK Modul im Flash Gerät eingebaut. Oder HWK Modul ist TOT (Kaputt) Error Connecting UFS: HWK Error: -3 HWK Seriennummer ist blockiert oder nicht original. Anleitung Error 20/32 DO NOT, perform this process unless you have Box Auth Error 20, update client reports "use Update Firmware to authorise UFS !" or you are advised to do so. 1. Run the update client. 2. Select your language. 3. Click "Next". 4. Wait until the "Update UFS Firmware" button is enabled and then click it. 5. Select req.fbi file, you will need to get this file from the support area. 6. After a few seconds the process will complete and create a file called xxxxxx.req. (where xxxxxx is your UFS serial number) 7. Send this file to your UFS reseller. 8. When you receive xxxxxx.fbi from your UFS reseller, perform steps 1-4 above. 9. Select xxxxxx.fbi 10. After a few seconds your box will be authorised. Your UFS reseller is the only person who can help with this process, do not ask here in the forum, we will not generate xxxxxx.fbi files for you. NOTES:- 1. the xxxxxx.fbi file sent by your UFS reseller is one time use only. 2. once you have made the xxxxxx.req file, do not perform any other steps on the box, since this will cause the xxxxxx.fbi file to be out of sync. |
12-05-2012, 10:10 | #27 (permalink) |
Junior Member Join Date: Dec 2012 Location: oman
Member: 1847879 Status: Offline Thanks Meter: 0 | error Upgrade log: ---------- HWK Update Client v 2.2.0.0 ---------- ---------- HWK upgrade started:12/5/2012 1:03:57 PM ---------- -- Target Id : 62 CF 0 0 -- UFSx Boot : UFxBoot V2.2 (c) SarasSoft 2003. -- UFSx Firmw.: UFS_USB V2.8 (c) SarasSoft 2007. -- UFSx S/N : 77326 -- Features : 00000001 -- Licence 5 : False -- UFSx Vendor: TWISTER ---------- Locating HWK Upgrade server... HWK Upgrade server found! Preparing connection to server... Connecting to HWKUpgrade server... Server connection successfully established. Authenticating on server... Authentication stage error: Access violation at address 00402D5D in module 'UpdateClient.exe'. Read of address 00000014 guys can u help me plzz??? |
12-06-2012, 13:16 | #28 (permalink) |
Junior Member Join Date: Dec 2012 Location: Bahawalnagar Age: 37
Member: 1849182 Status: Offline Sonork: [email protected] Thanks Meter: 0 | help to install ufs sarasofts This ufs has two exe file.which can i install first? when i will upgrade client?tell me plz?step by step process of instalation? |
12-06-2012, 13:26 | #29 (permalink) |
Member: 1849182 Status: Offline Sonork: [email protected] Thanks Meter: 0 | plz help me how we will install sara softs ufs device?it has two exe files for main software? which will be install first and when i upgrade client?tell me step by step process of installation and upgrading? |
01-10-2013, 05:30 | #30 (permalink) | |
No Life Poster Join Date: Jan 2011 Location: ISLD
Member: 1489021 Status: Offline Sonork: 100.1620946 Thanks Meter: 831 | Quote: hello bro ur download link not work for me plz shere same more and also guid me how is possible to install advance thanksssssss | |
I cant upgrade my hwk please HELP MR ODIA | topcomgsm | HWK | 15 | 09-28-2008 19:51 |
i cant update my hwk,please help | eryandy_natuna | UFS2 + UFS3-Tornadoflasher | 1 | 07-03-2008 05:52 |
