08-26-2013, 18:20 | #394 (permalink) |
Freak Poster Join Date: Dec 2012 Location: Multan Number 6 Age: 31
Member: 1858524 Status: Offline Sonork: 100.1651800 Thanks Meter: 81 | Bro here is solution!!!!!!!!!!!!! http://forum.gsmhosting.com/vbb/f411...013-a-1705026/ |
08-27-2013, 07:22 | #395 (permalink) |
No Life Poster Join Date: Jul 2013 Location: gsm forum
Member: 1984655 Status: Offline Sonork: 119.30.39.25 Thanks Meter: 82 | App: UFSx (HWK) Control Panel v 2.3.0.2 by SarasSoft CPU: GenuineIntel Platform: Windows NT 5.1 (Build 2600 Service Pack 2) Versions: Ufs2xx.dll 3.2.4, Ufs2xx.sys 2.8.14 C:\Program Files C:\Program Files\Common Files Nokia Path not Found, Set to: C:\Program Files\Nokia\Phoenix C:\Documents and Settings\songeta mobile\Desktop C:\Documents and Settings\songeta mobile\Start Menu\Programs App: UFSx (HWK) Control Panel v 2.3.0.2 by SarasSoft Box: 1 Location: 34 Serial: 132460 UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 7 UFS_USB V2.6 (c) SarasSoft 2005., Sn: 132460 LIC: True None Authorised Copy of Software Detected, Reinstall HWK: NOT AUTHORISED, Update Box Bad IX: 1111 Failed: 102 Your IP: 119.30.39.67 Support: Bad HID, Cannot Access Suport Something Wrong, Try to Use [Update Box] Box: 1 Location: 34 Serial: 132460 UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 7 UFS_USB V2.6 (c) SarasSoft 2005., Sn: 132460 LIC: True Your IP: 119.30.39.67 Support: Bad HID, Cannot Access Suport REST: Ok UFSx: UFS3 SarasSoft, USB S/N: 132460 NVML: Ok INIT FBI Failed: 1 Box: 1 Location: 34 Serial: 132460 UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 132460 LIC: True Your IP: 119.30.39.67 Support: Bad HID, Cannot Access Suport REST: Ok UFSx: UFS3 SarasSoft, USB S/N: 132460 NVML: Ok Support: Bad HID, Cannot Access Suport User Id not Allowed Support: Bad HID, Cannot Access Suport User Id not Allowed Box: 1 Location: 34 Serial: 132460 UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 132460 BOX_AUTH_ERROR: 20 BOX: CORRUPTED or MANIPULATED Your IP: 119.30.39.67 Support: Bad HID, Cannot Access Suport REST: Ok UFSx: UFS3 SarasSoft, USB S/N: 132460 NVML: Ok |
09-16-2013, 13:14 | #403 (permalink) |
Junior Member Join Date: Nov 2010
Member: 1449749 Status: Offline Sonork: 12345 Thanks Meter: 7 | UFSx_Support_Suite_Setup_v02.03.00.00 download 1. Uninstall ALL previous versions, you MUST uninstall HWK Suite BEFORE trying to uninstall HWK Support Suite Setup. 2. Install UFSx Support Suite Setup 3. Connect your UFSx+HWK before running the UFSx Control Panel 4. Run UFSx Control Panel 5. Select the "Hardware" Tab 6. If you only have one UFSx connected it will be selected, if more than one, select the check box next to the required UFSx. You can click "Scan Boxes" to refresh the list if you have connected further boxes since opening the Control Panel 7. Click "Check Box" 8. Click "Update Box" 9. Click "Check Box" 10. Select the "Software" Tab 11. Amend "Application Install Path" and/or Nokia Install Path, if required. 12. Click "Check Server" 13. Click "Install" 14. If you have more than 1 UFSx+HWK run steps 5-13 for each UFSx+HWK (NOTE: You must install something at step 13) |
The Following 3 Users Say Thank You to umesh chandra For This Useful Post: |
