08-07-2013, 20:14 | #361 (permalink) |
Insane Poster Join Date: Dec 2005 Location: Chile
Member: 208230 Status: Offline Thanks Meter: 13 | UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 120320 HID: 5387E5E5426000E0, HWK: A1.04-PRO1 BOX_AUTH_ERROR: 20 HWK: NOT AUTHORISED, Update Box Bad IX: ABCD Failed: -6 Your IP: 200.109.32.246 Support: Account Ok Something Wrong, Try to Use [Update Box] Box: 1 Location: 321 Serial: 120320 UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 120320 HID: 5387E5E5426000E0, HWK: A1.04-PRO1 BOX_AUTH_ERROR: 20 HWK: NOT AUTHORISED, Update Box Bad IX: ABCD Failed: -6 Your IP: 200.109.32.246 Support: Account Ok REST: Ok UFSx: UFS3 SarasSoft, USB S/N: 120320 NVML: OK INIT FBI Failed ! Please solve this problem |
08-08-2013, 06:55 | #362 (permalink) |
Junior Member Join Date: Apr 2011
Member: 1563442 Status: Offline Thanks Meter: 1 | Upgrade log: ---------- HWK Update Client v 2.2.0.0 ---------- ---------- HWK upgrade started:8/8/2013 11:20:34 AM ---------- -- Target Id : 62 CF 1 10 -- UFSx Boot : UFxBoot V2.2 (c) SarasSoft 2003. -- UFSx Firmw.: UFS_USB V2.8 (c) SarasSoft 2007. -- UFSx S/N : 99970 -- Features : 00000001 -- Licence 5 : True -- UFSx Vendor: TWISTER -- HWK ID : A1.04-PRO1-E99AE6354160005A -- HWK Status : 1, DL: 0 ---------- Locating HWK Upgrade server... HWK Upgrade server found! Preparing connection to server... Connecting to HWKUpgrade server... Server connection successfully established. Authenticating on server... Authentication stage error: Error: Server returned unrecognized reply give me the solution its urgent |
08-12-2013, 03:34 | #366 (permalink) | |
Junior Member Join Date: May 2013
Member: 1932907 Status: Offline Thanks Meter: 0 | Quote:
press update box again.. | |
08-12-2013, 13:52 | #367 (permalink) |
Junior Member Join Date: Feb 2008
Member: 705683 Status: Offline Thanks Meter: 5 | Sorry Every one.But he saying true .Now ufs is in a new avtar as called Sarash ufsx Turbo * SarasSoft UFS Turbo SKU# UFST 9 Review(s) | Add Your Review Availability: In stock $150.00 Qty: Add to Cart * Add to Wishlist Quick Overview BUY NOW AND GET FREE WORLDWIDE SHIPPING! All New UFS Turbo is a multiplatform box that supports most common phone models of Samsung, Nokia, SonyEricsson, LG and many other manufacturers. Click on image to zoom More Views * Details BUY NOW AND GET FREE WORLDWIDE SHIPPING! All New UFS Turbo is a multiplatform box that supports most common phone models of Samsung, Nokia, SonyEricsson, LG and many other manufacturers. << CLICK HERE FOR THE LIST OF SUPPORTED ANDROID MODELS >> Technical Specifications: 1. High Speed USB interface (480Mhz carrier) 2. On board High Speed USB Hub 3. On board uUSB RID control (Samsung, LG JIG emulation) 4. High Speed UART communication up to 3.686.400 Bauds 5. High Speed Fbus transfer, up to 16Mhz 6. Programmable BSI resistance 7. On board Vpp generator (12v) 8. Custom Vbat, Vpp , Rx, Tx and BSI connector 9. Universal uUSB cable with all possible modes for Samsung and LG 10. USB / UART switching on same Universal Cable 11. Samsung Android devices Factory Programming Mode (FPGM) 12. First time in USB using USB3 cable 13. Smartcard Protected 14. HWK module installed 15. High Speed cables included (4pcs) NOTE: NEW UFST Box is required to use new version 2.3.0.0 or higher SOFTWARE RELEASES LATEST RELEASE: SAMSUNG TOOL v2.3.0.0 (20 July 2013) SWIFT T456-FIDO,T456-ROGERS added (UNL,SECT,IM,FL) SWIFT-AEROFONE [Patch MSL] fixed for DUOS Products. E1086W,E1153i,E1182-CHN,E1195L,E1200,E1200M,E1200M-CHN, E1200T,E1202,E1205,E1205L,E1205M-CHN,E1205T,E1207,E1207T-IND, E1207-MEA,E1220T,E1230T,E1232B,E1232D added (PUNL,PIM,FL) C3520,C3780,C3782,E2250,E2252 added (UNL,SECT,IM,FL) E2220,E2222L (UNL,SECT,IM) SWIFT-3G C3630,C5190,C5530,E3217B,E3217L,S5270K,S5270L,S568 0 added (UNL,SECT,FL) C5010,E3210,E3213,S5610 Direct Unlock Fixed. IMEI Repair Added for Almost All Models: C3630,E2310,E2313,S3710,S5270,S5610,.. INFINEON C3310,C3310R,C3312,C3312R,C3313K,C3330,C3332,C3350 ,C3350M, E2230L,E2350B,E2600,E2600M,S3800,S3802,S3802W,S522 0,S5220R, S5222,S5222R,S5229,S5292,S5296 added (CUNL,PUNL,PIM,FL,UFL) E1151 Missing boot fixed. E1151 IMEI Rebuild and Direct Unlock added (AT Mode) Note: Need make Boot Mode Info before use of AT Mode. QUALCOMM M210S,T356 Added. BROADCOM S5380B,S5380D,S5380F,S5380G,S5780D,S7250,S7250D added (UFL) LG TOOL v2.3.0.0 (20 July 2013) 1. Infineon Egold Boot Fixed (was broken in v 2.2.0.3) 2. Infineon E500,KM553,KM555,KM555e,KM555g,KM555R added (FL,CUL) 3. Infineon GT370,GU230GO,S367 added (FL,CUL,DUL,IM) 4. Infineon T370,T375,T385,T385b,T395,T500GO,T505GO,T565, T565b,T575 added (FL,DUL) 5. MTK: A290 added (FL,3xIM) 6. MTK: USB Support for UI Functions (Select COM on Phone) 7. WiFi MAC Address Write Added for Infineon and MTK platforms. --------------------------------------------------------------------------------------------------------- OLDER RELEASES: DCTxBB5 v2.2.0.3 1. BB5 RAPU Based Products USB Flashing / UI support added: RM-670,RM-679,RM-681V,RM-701,RM-730,RM-750,RM-763,RM-774,RM-779, RM-781,RM-814,RM-815,RM-816 (700,T7-00,Vertu Con.T,600,702T,500,303,701,603,300,C5-08,C5-05,C5-06) 2. DCT4 INFINEON Based Products Flashing / UI support added: RH-130,RH-131,RM-724,RM-725,RM-769 (100,100.1,C2-05,C2-05.1,101) 3. Vertu products names changed to RM-582V, RM-681V to keep compatibility with DataPackageManager application. 4. New Flashloaders included. 5. Fixed BSOD bug on W7 x64 when Connect Box. LG_GSM v2.2.0.3 1. Infineon: A190,A190a,A190b Read Lock Keys, Unlock, Dual IMEI Fixed. 2. Infineon EgoldVoice64_ULC2: KG370,KG375,KG376,MG370a,MG370b added (FL,CUL,DUL,IM) 3. Infineon XMM2130: LG500G,LG800G added (FL) 4. Infineon XMM2150: A200,A225,A230,A250,A255,A258,C330,T500,T505,T510, T515, T530 added (FL,DUL) S365 added (FL,CUL,DUL,IM) Note: Use [Unlock] before IMEI rebuild. 5. Fixed BSOD bug on W7 x64 when Connect Box. SAMs v2.2.0.3 SWIFT-AEROFONE E1080T-SEA,E1175T-MEA,E1190-CHN,E1195,E1195-CHN,E1230 added (PUNL,PIM,FL) E1055G info/unlock bug fixed. xx-DX models renamed to xx-SEA (note: DD is IND not SEA) E2222 (UNL,SECT,IM) SWIFT-3G (CUNL,SECT) fixed for C3630C,C3730C,S3930C E3213K,i6320C,i6330C,S3710,S3770,S3778,S3830U,S561 0, S5610K,S5630C added (CUNL,SECT,FL) INFINEON IMEI2 Rebuild added for DUOS models. Minor bugs in AT protocol fixed: (not read Codes and IMEI Rebuild fails on some models) Notes: Some S3550 units stucks on DFFS (CSC) Flashing, Solution: Untick [Use EBL from FLS Pack] CheckBox. COMMON Fixed BSOD bug on W7 x64 when Connect Box. DCTxBB5 v2.2.0.2 1. BB5 RAPU Based Products USB Flashing / UI support added: RM-776 (C3-01.5) 2. DCT4 INFINEON Based Products USB Flashing / UI support added: RM-692,RM-693,RM-702,RM-713 (C2-02,C2-02.1,C2-03,X1-01) LG_GSM v2.2.0.2 1. Infineon: A108,A190,A190a,A190b,A210,A210b,GB125R,GC900fGO,G T350f, KS360GO added. 2. EGV V3-32 and EGV V3-64 Direct Unlock and IMEI enable added. Note: Use [Unlock] before IMEI rebuild. 3. EGV V3-64 new Flash Chips Support. SAMs v2.2.0.2 TRIDENT VISION <CODE CORRUPTED> for non 8 Digits PCK Fixed. SWIFT-AEROFONE E1050-CHN,E1050V,E1086i,E1150-CHN,E1155L,E1180,E1190,E1220i added (PUNL,PIM,FL) E1182L added (DUNL,PUNL,PIM,FL) E1225T,E1182 TFS Flashing bug Fixed. C3322 Unlock, IMEI, Sections bug Fixed. B7722,B7732 Slave Part Flashing/Read/E2P added. QUALCOMM T669 Added. INFINEON C3011,C3560,C3750,C3752 added (CUNL,PUNL,PIM,FL,UFL) E2232 Flashing bug Fixed. <CODE CORRUPTED> for non 8 Digits PCK Fixed. DCTxBB5 V 2.2.0.1 1. DCT4+ ASIC2 Unlock Bug Fixed (RH-92,RH-93,RH-94,RH-95,RM-189,RM-190,RM-225) 2. Wrong Locks Status Indicator Fixed (RH-86,RH-87) 3. Detail Description Message on Bad VPL File Exception. 4. BB5 RAPU Based Products USB Flashing / UI support added: RM-744,RM-745,RM-775 (C5-00.3,C5-00.2,X3-02.5) LG_GSM v 2.2.0.1 1. Infineon: A100,A100a,A175,A175a,A175b,A180a,A180b,GB102GO,GB 105a, GB107a,GB125a,GB126a,GS101a,GS101GO,GS107a,GS107b, GS117, GS155,GS155a,GS155b,GS500f,GU200,GU200a,GU200b,KF5 10c, KF600c,KF600d,KM570,KM570f,KP105a,KP106a,KP106b,KP 107a, KP107b,T325g,TE350GO added. 2. ADI: KP115a,KP130b,KP215a,KP260c,KP265d added. UFS_SAMs V 2.2.0.1 SWIFT Some DUOS models Slave Boot bug Fixed. SWIFT-AEROFONE E1050,E1055T,E1080W,E1170i E2P Size Fixed. Max Section Size Increased. E1182 added (DUNL,PUNL,PIM,FL) C3303i,C3322,C3500 added (CUNL,DUNL,IM,SECT,E2P) Note: C3322,C3500 TFS and CSC Flashing not Supported yet, use Original Flasher. SWIFT-3G C5010B added (CUNL,SECT,FL) QUALCOMM A885,A886,F406,S3370B,S3370L added. INFINEON E2652,E2652W USB Flahing bug Fixed. E2152i added (CUNL,PUNL,PIM,FL,UFL) XGOLD213 BIF file Write bug fixed. XGOLD213 Patch bug fixed. BROADCOM B5310R,C6712,S3853,S5250W added (UFL) COMMON Used Abbrevations List can be seen at the Bottom of this page. DCTxBB5 V 2.2.0.0 1. BB5 products: RM-576,RM-577 (6700s,6700s-1c) added. 2. Local RPL Service Fixed for ASIC 2,5,6,7,11 (UEM_PASW is Correct now) Note: Need Confirm [Readout and Use UEM IMEI] when do [Rd UEM]. 3. [Check Ask/Rpl] Renamed to [Calc Ask/Rpl] as can Calculate RPL now. 4. [Calc Ask/Rpl] Function will Generate Real RPL from ASK file (ASIC 2,5,6,7,11) Note: When Reading UEM, do not Forget Set Right [UEM Changed] Status ! 5. RSA Lock/Unlock for All DCT4+ products (not need Patch) 6. Life Timer added to [PM Edit] 7. DCT4 INFINEON Based Products USB Flashing / UI support added: RH-111,RH-125,RH-126,RM-607,RM-608,RM-643,RM-644,RM-647,RM-653, RM-669,RM-689,RM-704,RM-732,RM-733 (1202,1616-2,1616-2b,C1-01,C1-01.1, C1-02,C1-02.1,1280,1800,1800b,C1-00,C2-00,X1-00,X1-00.1) 8. BB5 RAP3Gv40 Based Products USB Flashing / UI support added: RM-509,RM-510,RM-511,RM-540,RM-598,RM-604,RM-615,RM-638,RM-721,RM-722 (3710a-1,3710a-1c,3711a-1,X3-00,7230-1c,7230-1,5330-1d,6303ci,C2-01,C2-01.5) 9. BB5 RAPU Based Products USB Flashing / UI support added: RM-582,RM-596,RM-601,RM-609,RM-610,RM-627,RM-629,RM-632,RM-634, RM-639,RM-640,RM-645,RM-648,RM-658,RM-659,RM-662,RM-675,RM-682, RM-688,RM-691,RM-697,RM-699,RM-707,RM-718,RM-719,RM-720,RM-749 (Vertu CQ,N8-00,C6-01,E6-00,E6-00.1,X5-01,5230-1d,E5-00,E5-00.2,X3-02,C3-01, C5-00.X5-01.2,E73,X7-00.1,C3-01m,C7-00,6702s,C5-00.1,C7-00b,C5-03,E5-00m, X7-00,C6-01.3,C5-03.2,C5-04.1,C7-00s) 10.BB5 RAPIDO Based Products USB Flashing / UI support added: RM-484,RM-485,RM-486,RM-551,RM-552,RM-559,RM-588,RM-593,RM-594, RM-612,RM-624,RM-625,RM-684 (N86-1,N86-3,N86-5,X6-00.1,X6-00m,X6-00,5230-1,5230-1c,5230-1b,C6-00, C6-00.1,5288,5250) 11.BB5 JUNO (BCM21351) Based Products USB Flashing / UI support added: RM-497,RM-586,RM-614,RM-618,RM-709,RM717 (7020a-2,2710c-2,C3-00,X2-00,X2-01,X2-01.1) 12.Original SX4 Card Support Added (Use Any PCSC Compatible Card Reader) LG_GSM v 2.2.0.0 1. Infineon: A110,A130,A133,A133GO,A170,A180,C100,C105,C300,C30 0GO,C305, C310,GB220,GB220nGO,GB230,GB280,GD350,GD510,GD510N ,GM360, GM360i,GM600,GS170,GS290,GS290GO,GS290N,GS390GO,GS 500,GS500g, GS500gx,GS500v,GT350,GT350GO,GT350i,GT360,GT365,GU 220,GU230, KC550,KC550d,KF510,KF510d,KF600,KF600d,KM380,KM380 c,KM380d, KM385d,KM386c,KP500,KP500N,KP501,KP502,KP502GO,KP5 05,KP550, KP570q,KS360,KS365,T300,T310,T310i,T310N,T315,T315 i,T320, T320e,T320g,T325 added. Notes: 1. To See Unlock Codes and Instructions, Press [BOOT] 2. To Flash Dead Phones, Tick [Emerg. Boot] 3. FLS and BIN files supported for Flashing. 2. USB Support for Infineon SGOLD3, SGOLDRADIO, XGOLD213. Note: To use USB Select USB in [Baud] ComboBox. 3. ADI: G210,G220,G232,G233,G259,G262,G263,G610,G622,G632, G635, G639,G660,G672,G677,C682,G688,G810,G822,G828,G912, GM200,GM205, GM205GO,GM210,KF245,KG296,LG8930,MG235,MG295,MG296 added. 4. TI: C1300i,C2000,G850,L1400i,MG191a,MG191b,MG200c,MG20 0d added. 5. MTK: A120,A155,A160,A165,GB160a,GB160b,GB161,GB190a,GB2 70, GS190,GS200,GS205 added. 6. BT Address Write Added for ADI, Infineon and MTK platforms. SAMs V 2.2.0.0 TRIDENT A127,i626,T719,X475 added (DUNL,IM,FL) OM(SYSOL) T209,T319 added (DUNL,IM,FL,SECT) SWIFT A436,A437,A516,A517,T229,T249,T339,T349-LTA-USA,T369, T409,T619,T739 added (DUNL,IM,SECT,FL) Added Multi Drive support for TFS Read. Fixed SLAVE Boot Bug on some models (D980,D980F,D988) TFS Extractor and TFS Builder added, Allows to Edit TFS files. SWIFT-AEROFONE Added [Patch MSL] Function to Patch without MCU Part Flashing. C3300i,T109,T119 added (DUNL,IM,FL) E1050,E1055G,E1055T,E1080F-IND-MEA-SEA,E1080W, E1081T-EU-IND-MEA-SEA,E1083C,E1085F,E1085F-MEA,E1087T,E1105F, E1150i,E1160i,E1170i,E1170T,E1172,E1175T-EU-IND,E1178,E1225F, E1225T,E1225T-IND,E2121L added (PUNL,PIM,FL) Notes: 1.Mixing of EU IND MEA SEA Files causes Blinking or Dead Sets. 2.E1081T EU E2P Image is not Compatible with IND, MEA or SEA. 3.For Cross Flashing Select Model Name Extension by File type. 4.Before Unlock, Info to see Codes or Rebuild IMEI use [Patch MSL] Button or Flash with [Patch MSL] Option Enabled. C3222,C3222W added (DUNL,CUNL) Note: C3222 Flashing not Supported yet, use Original Flasher. TFS Extractor and TFS Builder added, Allows to Edit TFS files. SWIFT-3G C5010E,E3210 added (CUNL,SECT,FL) QUALCOMM A597,A847,A927,B2710D,C5180,S5520,S5580,S6700T,S68 88,T359,T479, T746,T749 added. More Versions Support of Hidden Sysinfo models CUNL and UNFR: A597,A706,A707,A717,A727,A847,A887,A897,A927,B2710 ,B2710D,S3370, S5530,T359,T469,T479,T559,T659,T746,T749 QUALCOMM+LSI S8500B,S8530 added (FL) BROADCOM S5230N added (FL,CUNL,UNFR,BRP) S3850,S5260,S5263,S5330L,S5560i,S5750E,S5753E,S723 0B,S7230E, S7230W,S7233E added (FL) S5250,S5253,S5330,S5330L,S5333 Boot Repair (BRP) [QCDI Info] Renamed to [BCMBL Info] for BroadCom Models. INFINEON B3310i,C3200,C3200G,C3200L,C3530,C3530L,E2230,E223 0M,E2232, E2330,E2330B,E2330C,E2530,E2652,E2652W,S3310i,S335 0,S3353, S3550,S3550C,S3550L added (CUNL,PUNL,PIM,FL,UFL) Note: for USB Flashing select 'USB0' in [BaudRate] box. E1151, Now Possible to Flash Read BIN Dump (Size: 007F0000) UFS_SAMs v2.0.10.7 SWIFT-AEROFONE E2152 FULL, _RD, E2P Write Bug Fixed. Note: E2152 DX Firmwares cannot be Properly Flashed. QUALCOMM B2710,S3370E added. QUALCOMM+LSI S8000L added (FL) BROADCOM S5620B,S5628i added (FL) COMMON Used Abbrevations List can be seen at the Bottom of this page. LG_GSM v 2.1.0.6 (HWK Required) 1. Added NSCK,SPCK,CCK,SIM codes Display for GS10x UFS_SAMs v2.0.10.6 TRIDENT X427 added (DUNL,IM,FL) TRIDENT VISION M2520 added (UNL,CUNL,IM,FL) Display of USER LOCK Key for All Models. SWIFT E2550,E2550D,E2558 added (UNL,SECT,IM) Notes: 1.Chinese Versions E2550Zxxx select as E2558 for UNL,SECT,IM. 2.E255x PRAM Flashing not Supported yet, use Original Flasher. B3410C,E2510C,S5050C added (UNL,IM,FL) Note: Chinese Versions B3410Zxxx select as B3410C. SWIFT-AEROFONE C3300D,C3300K,C3303,C3303K added (UNL,SECT,IM,FL) use 530Kom Cable. E1107-DX,E1107L,E1117-MEA-IND,E1130,E1130B,E1150-MEA-SEA,E1153, E1160-DX,E1220,E2120i,E2120L,E2121,E1252,E2121B,E2210T,E 2152, E2370 added (CUNL,PUNL,PIM,FL) Note: Mixing of DX MEA SEA Models causes Blinking or Dead Sets. [Restart] Button now Exit TAT mode with Battery. Auto Exit from TAT Mode when Flashing, not need Cable or Battery Reconnect after UI functions (Info,IM,..) SWIFT-3G J808,S5550,S5550U added (CUNL,SECT,FL) B7722,B7732 DUOS added (CUNL,SECT,FL) Flashing only Master Part. C3630C,C3730C,S3930C TD-SCDMA added (FL) use 530Kom Cable. QUALCOMM A657,A887,A897,M7600L,S5530,T559 added. BROADCOM A697,B3410W added (FL,CUNL,UNFR,BRP) S5250,S5253,S530,S5333 added (FL) Boot Repair Enabled for All Broadcom models, use 530Kom Cable. Some Models have encrypted Boot2.img and don't have uart_boot, for these models use our released Boot_Repair packs. Note: S562x with OneNand Flash Chip, Cannot be Repaired. Added Unlock support(CUNL) for Hidden Sysinfo models (S5560,..) if have no succes in SysInfo search, need ReFlash, to have untrashed FS COMMON Reduced/Full Log of TFS file list progress for OM/Swift. Improved FileOpen dialog, to Override suggested path to last used on same model. Used Abbrevations List can be seen at the Bottom of this page. DOCUMENTS Samsung B7722 How to Rev.1 Samsung C3300_C3303 How to Rev.1 Samsung S523x Warning Rev.1 Samsung S7070 How to Rev.1 Samsung Swift-Aerofone MSL3 Models How to Rev.1 UFS_SAMs v2.0.10.5 TRIDENT VISION M2513 added (UNL,CUNL,IM,FL) SWIFT Added MCU_Id and Type Display. Increased Preloader boot speed. QUALCOMM More Versions Support of Hidden Sysinfo models CUNL (S3370,..) A877,M7600H,M8800H,S5603T,S7120H,S8300T added. QUALCOMM+LSI M8910,M8910B,M8910H,M8910U,S8000,S8000B,S8000C,S80 00H,S8000U, S8003,S8500,S8500C added (FL) BROADCOM C3510T,M3710,S5560H added (FL) S3650H,S5230C added (FL,CUNL,UNFR,BRP) INFINEON Infineon Platform Introduced, See on [Sky/INF] Tab. E1151 added (CUNL,FL) DHLT Engine will ask about additional DHLT tables generation. COMMON [Refresh] will Auto Select Ports, be sure that Right Model and Mode is Selected (Untick [QualComm mode] when Flashing !) LG GSM V 2.0.10.4 1. Infineon GB107,GB108,GB115,GS100,GS101,GS102,GS105, GS106,GS107,GS108,KG289,KP109 added. UFS_SAMs v2.0.10.4 TRIDENT VISION B3210M added. Bug in E2P Filename Display fixed. OM(SYSOL) On the Fly E2P Patch added to keep Original IMEI number. SWIFT C3212i added(UNL,IM,FL) On the Fly E2P Patch added to keep Original IMEI number. SWIFT-AEROFONE E1080i,E1086,E1086L,E1170,T139 added (CUNL,PUNL,PIM,FL) On the Fly E2P Patch added to keep Original IMEI number. On the Fly MCU Patch added to bypass MSL security for MSL3 (MSLC16) products (E1080,E1080i,E1086,E1150,E1160, ...) after is possible Direct Unlock, Rebuild IMEI in normal way. QUALCOMM S3370,S5350M added (FL,CUNL,UNFR) S5350 added (CUNL,UNFR) Increased Speed in Communications (NVM Read/Write, RAM Read) BROADCOM B5310U added (FL) i6230,S3653M added (CUNL,FL,BRP) Combo Cable (USB+RJ45) Support added, not need Manipulations with Cable when use [QCDI Info] Corrected CSC,APP,PFS flashing for BCM2153 platform (B5310,..) [Boot Change] Product will Restart after success Boot Change, if Failed, will stay in Download Mode to Allow Retry. [Full Download] will Write All without Restart after Boot Change. COMMON [Refresh] will Show Avalaible Ports List with Full Names. UFS_DCTxBB5 v2.0.10.0 1. New BB5 products: RM-381,RM-455,RM-468,RM-492,RM-529,RM-530,RM-570,RM-573,RM578,RM-579,RM-584,RM-599,RM-600,RM-635 (6750-1,6350-1b,5730s-2,6790s-1b,E72-2,E72-1,3208c,6760s-1,2730c-1,2730c-1b,E72-5,6790s-1c,E63-5,2690) 2. New DCT4+ products: RM-590,RM-591 (2220s-2,2220s-2b) 3. More DCT4+ added for unlock (ASIC 3168) see corresponding list. 4. McuSw tag fixed in vpl parser. 5. Fixed time-out bug for some RAPU models. 6. [Det.Log] CheckBox now active, can auto create LOG file. 7. [Info] Shows Camera DCC settings and Status (for both Cameras) 8. [PM Edit] Revised: Read/Write DCC, Simlock Data, Parallel Model. 9. Increased PM read default margins, to have DCC in read PM for DCT4+ 10.[Check Ask/Rpl] to Check Ask/Rpl files contents (Asic 2,5,6,7) 11.Fixed [Format] bug for new BB5 Symbian products. 12.ENO File flashing support (E63,E66,..,N97,..) 13.[Locks] for BB5 remade, now calculate codes for SLPA and SL20 14.[Check] Shows PASUBTOC SL related contents. Do not use external VPP adapter with RX2 enabled cables, since this will put VPP direct to RX2 and its possible to KILL the phone. LG GSM V 2.0.10.0 1. MTK GB160,GB165,GB170,GB175,GB190,GB195,KG198 added. 2. Infineon GB101,GB109,GB110,GB125,GB130,KE858,KP108 added. 3. Infineon New Flash Chip SV7E3204UTA support. 4. ADI KG129,KG248,KG298 added. 5. " Cannot open file " Bug Fixed. SAMs V 2.0.10.0 TRIDENT C158,C158B,C188L,C240L,C258,C260B,C260L,C260M,C300 B,E576,E758, X138,X180,X468P,X478,X568 added (DUNL,IM,FL) USB flashing introduced for HPE models (U600,.. Approx. 2x faster) TRIDENT VISION B3210,B3310,B3313,C3010S,C3050C,C3053,C3060,C3110H ,M620N, S3030C,S3500C,S3500H,S3500i,S3501C,S5150,S5150C added (CUNL,IM,FL) MSL3 bypass introduced (B3210,B3310,B3313,C3060,C3060R,...) USB UI functions introduced, allows to unlock USB only phones. USB flashing introduced (Approx. 5x faster) (Cannot use USB flashing of dead phones which have UL erased or damaged. RJ45 flashing can be used to recover from erased UL situation) SWIFT A177,A226,A227,A237,A257,B3410,B5702,B5712C,B5722, B5722C,C3212, C3510,C3518,C6112,C6112C,D980F,E200E,E208B,E250L,E 848i,F118, F278,J150B,M2710,M2710C,M2710L,M3510C,S3100,S3110, S3110C, S3600C,S3600H,S5200C,T219,T329,T729 added(UNL,IM,FL) Added ENG flashing for DUOS FOTA models (D988,B5712C,..) Auth. Boot and Firmware Sign. for Secure models (B5722,C3510,C6112,S3100) B5702,D988,F265L,S5050 (SECT) bug fixed. CSC Area format added. SWIFT-AEROFONE A137,CC01i,E1070C,E1100C,E1101C,E1107,E1113C,E1120 C,E1210, E1310C,E1310E,E1360,E1360C,E1360S,E2100C,E2210C,E2 210H added (DUNL,IM,FL) E1080,E1080C,E1080T,E1085,E1085L,E1085T,E1088C,E11 00H,E1150, E1150C,E1160,E2120,E2120B,E2120C,E2130 added (CUNL,FL) SWIFT-3G C5110,C5130,C5130S,C5130U,J800R added (CUNL,FL,SECT,BT) P270 (CUNL,SECT) bug fixed. E2P Write is supported only for C5130,C5130S and C5130U. QUALCOMM A551,A561,A637,A746,A747,A766,A767,A811,A821,A827, A836,A837, A867,C5220,C5510H,C5510U,G508,G508E,M7600B,M7600H, S5350, S5600B,S5600L,S5608U,S5510,S7120U,S7350C,S7350E,S7 350F, S7350H,S7350i,S7520U,S8300H,T469,T659,T749,T919,T9 29,U808 added. Fixed flashing of non page size aligned files (rc1,rc2,ffs) Added flashing support for QSC62xx models. UNLOCK and UNFREEZE added for these models: A551,A637,A767,A827,A837,C5220,F400,S5510,S7350,S7 350C, S7350F,S7350i,T639,Z170,Z240E,Z360,Z720,ZV40 BROADCOM QC Legacy BroadCom models introduced: i6220,S3650,S3650C,S3650M,S3650W,S3653,S3653W,S523 0,S5230G, S5230H,S5230M,S5230W,S5233A,S5233S,S5233T,S5233W,S 5560,S5560C, S7070 (CUNL,FL) To read codes use: [Mobile Info] button using USB Cable (Phone Switched-ON) and after [QCDI Info] button, using RJ45 Cable (Phone-OFF) QC Legacy BroadCom models Full Flashing (with BOOT Change) [BOOT Repair] for QC Legacy BroadCom models added. Boot Repair and Codes Read is possible only for phones with NM_20 pin USB/RJ45 connector ! COMMON Log to file added. CLONE error message fixed. UFS_DCTxBB5 v2.0.9.0 1. New BB5 products: RM-424, RM-465, RM-469, RM-481, RM-482, RM-483, RM-491, RM-504, RM-518, RM-547, RM-555, RM-561, RM-564, RM-566, RM-602 (6720c-1, 5730s-1, E52-1, E52-2, E55-1, E55-2, 6710s-1, 5530c-2, 3720c-2, 6730c-1VF, N97-4, 2700c-2, 6720c-1b, 6730c-1, 5800d) 2. New DCT4+ products: RM-519, RM-520 (2720a-2, 2720a-2b) 3. New Samsung Flash Chip: 00EC2606 (K8S3215ETF) 4. Corrected VPL parsing for some models (N97) 5. Only NU48F256 left in [1331] option and moved to BB5 Tab. 6. SX4 bypass introduced using temporary NPC certificate erase. 7. [One Boot] option introduced (RAPx based One MCU products) 8. Enabled Files Multiselect, when Writing Certificates. 9. Erase Option for BB5 (for Experts Use Only !) Do not use external VPP adapter with RX2 enabled cables, since this will put VPP direct to RX2 and its possible to KILL the phone. LG GSM V 2.0.9.0 1. Unlock Codes Display for Infineon EGOLD Voice added (Boot and See NCK Code for Instructions Press UNLOCK) SAMs V 2.0.9.0 TRIDENT T539 added (DUNL, IM, FL) TRIDENT VISION Fixed MSL algorithm for some models (C3050, ...) SWIFT D606, D900E, E260, M2310, P220, S366, S5050, S5200 added(DUNL, IM, FL, SECT) SWIFT-AEROFONE B270i, C276, C276L, E1070M, E1070T, E1075, E1075L, E1105T , E2100B, E2210B added (DUNL, IM, FL) QUALCOMM Manual Port Selection Added (Use Refresh, After Each Phone Reboot or Reconnect) (Untic QualComm Mode, Before Flashing) F480R, i6210, U900W added. UNLOCK and UNFREEZE added for these models: A736, A737, F490, G800, G800L, M7600, S5600, U900W, Z400, Z 540 We would like for some users to add localisation in their own native language to the software, localisation is added to SAMs only at the moment but will be added to other modules in future. Conditions: 1. Only 1 contributer per language. 2. You must know how to use the software and what each function does. 3. The chosen language is your native language or you are fluent in the selected language, for example Chinese is not my native language and I would like someone to take over from me and finish/correct as required. SAMs V 2.0.5.4 TRIDENT U600, U608 added. "Test Mode" enter improved. Warning about Battery usage, during UI operations. Corrected Reserved Regions for some models(D83x, D84x, E90x, P31x, X82x) Added MSL calculation, allows direct unlock and show correct codes for new models(D83x, E570, E90x, P31x, U60x, X5xx, X63x, X68x, X8x x, .) IMEI challenger implemented, allows rebuild IMEI for new models. DCTxBB5 v2.0.5.3 1. Modified BB5 codes enter, to allow unlock "Counter Expired". DCTxBB5 v2.0.5.2 1. Added BB5 files integrity check, while flashing. 2. Fixed some minor bugs in "Init SimLocks". 3. Added Dejan solution for BB5 ("Locks") 6630, 6680, 6681, n70, n90 etc... Test others on your OWN risk! DCTxBB5 v2.0.5.1 1. Revised "Init SimLocks" function, now allows direct unlock of 1600(RH-64, RH-65)and other models. DCTxBB5 v2.0.5.0 1. New BB5 products: RM-101, RM-188, RM-208, RM-260 (N92-2, 6086, E65-1, 6086b) 2. New DCT4 products: RH-94, RH-95, RH-97, RH-98, RM-225.RM-229 (1112, 1112i, 6060v, 6061, 6030b, 6030) 3. New CDMA products: RH-71, RH-77, RH-89, RM-121(2125, 2126i, 2118, 2115i, 2355) 4. New CDMA TIKU products: RM-41, RM59, RM-60, RM61, RM-66, RM-124, RM-125, RM-154, RM-193 (3155, 3155i, 6155, 6235, 6236i, 3152, 6265, 6265i, 2855, 6 165, 6275, 2865) 5. Support of new Flash update pack 7.4.13.26017, new Flash chips added. 6. Improved F-Bus polling, fixed "Bad Resp UFSx" after fatal error. 7. Improved diagnostics of "Dead APE" and not recognized Flash chips. 8. Fixed "Patch" option bug. 9. UDA(CP) flashing for RM84, RM99 (N70-1, N70-5) 10.Self Tests monitor introduced. 11.Unlock of DCT4+ (BB4.1 ASIC 2 & 11) phones. 12.Certificates backup for BB5 phones introduced ("Rd Cert"and"Bk.308"for SL_Data) 13.BB5 File System Format introduced. 14.Windows Vista(tm) 32bit OS support. LG_GSM v2.0.5.0 1. KG110, KG320 support fixed. 2. Added new models. 3. Windows Vista(tm) 32bit OS support. SAMs v2.0.5.0 COMMON Windows Vista(tm) 32bit OS support. Cut Power option (Restart - power on mobile) TRIDENT C140, C216, C240, C250, C260, C266, C268, C308, P310, P318, X166, X636 added. MSL1 bypass, allows direct unlock. OM635x E635 added. SWIFT E256, E376, E480, E488, E736, E750, E758 added. E25x direct unlock. Full TFS Read, TFS editor. Option to exclude E2P part from MCU read. All other modules have been updated to include Windows Vista(tm) 32bit OS support DCTxBB5 v2.0.4.2 1. New BB5 products: RM217, RM222 (6300, 6300b) 2. PM Write: cofirmation to overwrite security data (21, 120, 208, 308) SAMs v2.0.4.2 COMMON Cables description added. TRIDENT MVN CTS flashing fixed (X830 'Unknown File System' error) FDI CTS flashing fixed (E570, X630, X680 Empty folders) Full Reset (*2767*3855#) is mandatory after CTS flashing ! X838 added. DCTxBB5 v2.0.4.1 1. New BB5 products: RM198, RM216 (6085, 6131NFC) 2. Firmware Downgrade option for BB5 phones. 3. Fixed APE bug in COR files flashing. UFS_DCTxBB5 v2.0.4 1. New BB5 products: RM43R, RM100, RM140, RM146, RM147, RM158R, RM174, RM181, R M209, RM291 (N91-2, N92-1, 7390, 5300, 5300b, N91-6, 5200, 5200b, 7373, 2626) introduced. 2. RM170, RM171(E50-1, E50-2) fixed. 3. New Flash update bundle support (6.44.047) UFS_LG_GSM v2.0.4 1. M4410 support added. 2. UI functions added for LG models. 3. Added BIF->MOT, BIN->MOT conversion. UFS_SAMs v2.0.4 TRIDENT C300, D830, D836, D838, D840, D848, E570, E906, S401i, X156 , X160, X160b, X168, X461, X481, X510, X518, X520, X530, X680N, X81 0, X818, X830 added (Unlock works with battery only !) SWIFT E250, E258, E500, E780, E786, E788 added. Direct unlock for new models (D900, D820...) OM635x E420, E428 added. X65x - Unlock E2P feature added. S50x - Fixed "Full" flashing bug, E2P R/W added. UFS_DCTxBB5 v2.0.3 1. New Flash update bundle support (6.35.036) 2. Fixed bug in MM_Erase for TIKU models RM-165 (8800d) 3. Improved path search routines. UFS_LG_GSM v2.0.3 1. KG210, KG220, KG221, KG225, KG240, KG245 support added. UFS_SAMs v2.0.3 TRIDENT I300, I308, I320, X680, X688 added. CTS flashing (D520, D528, X680, X688) SWIFT E370, E378, E380, E388 added. Introduced Unlock E2P for MSL phones (D900, D820, E370, ...) Read E2P shows info (IMEI, Lock Status, Unlock Codes) Please Note: I300 / I320 PDA Flash is also supported by a third party utility, check the start menu after install. UFS_DCTxBB5 v2.0.2 1. New BB5 products: RM67, RM86, RM87, RM106, RM112, RM123, RM132, RM133, RM145, RM199, RM200 (N71-1, 6136, 5500d, 5500, N71-5, 6233, N73-5, N73-1, 6234, 6136b, 6151) introduced. 2. New DCT4 ASIC support added. 3. New DCT4 products RH86, RM165 (2610, 8800 Sirocco) 4. Fixed VPP control. 5. Fixed support of new Flash update packs. (Flash Pack v6.32.029 included.) 6. Fixed minor bugs. UFS_LG_GSM v2.0.2 1. Sharp Gsm products added: GX20, GX30, GX30i, TM100, TM150, TM200 UFS_SAMs v2.0.2 COMMON Introduced E2P Read/Write. Allows easy backup/edit E2P areas to repair or rebuild CAL data for new models.(Locks etc...) TRIDENT C130, E900, E908, S500i, X210, X218, X500, X508, X630, X638, X820, X828 added (Unlock works with battery only) CTS flashing (E900, E908, X630, X638, X820, X828) SWIFT D900, D908, X670, X678 added. Corrected problems with TFS read. NOR Erase. Direct unlock for older models. OM635x X650, X658 added. NOR Erase. Email to a Friend Product Tags Add Your Tags: Add Tags Use spaces to separate tags. Use single quotes (') for phrases. |
The Following User Says Thank You to tushar_56789 For This Useful Post: |
08-12-2013, 19:07 | #368 (permalink) |
Junior Member Join Date: Nov 2011 Age: 43
Member: 1682987 Status: Offline Thanks Meter: 6 | Box: 1 Location: 21555 Serial: 83962 UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 0 0 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 83962 BOX_AUTH_ERROR: 51 BOX: CORRUPTED or MANIPULATED Your IP: 115.249.253.121 Support: Bad HID, Cannot Access Suport -- Reset Failed, Trying to Repair UFS ... -- Boot: 62 CF -- Done, use Update Firmware to authorise UFS. UFSx: UFS3 SarasSoft, USB S/N: 83962 NVML: OK INIT FBI Failed ! how to rectified this problem |
08-13-2013, 08:44 | #370 (permalink) |
Junior Member Join Date: Jul 2013
Member: 1974996 Status: Offline Thanks Meter: 0 | I get following error while client updating on windows 8 plzzzzzzzzzz help me to solve this problem Upgrade log: ---------- HWK Update Client v 2.2.0.0 ---------- ---------- HWK upgrade started:13/08/2013 1:08:22 PM ---------- -- Target Id : 62 CF 1 10 -- UFSx Boot : UFxBoot V2.2 (c) SarasSoft 2003. -- UFSx Firmw.: UFS_USB V2.8 (c) SarasSoft 2007. -- UFSx S/N : -- Features : 00000001 -- Licence 5 : True -- UFSx Vendor: UFS3 -- HWK ID : -- HWK Status : 1, DL: 0 ---------- Locating HWK Upgrade server... HWK Upgrade server found! Preparing connection to server... Connecting to HWKUpgrade server... Server connection successfully established. Authenticating on server... Authentication stage error: Error: Server returned unrecognized reply |
08-13-2013, 08:48 | #371 (permalink) |
Junior Member Join Date: May 2010 Location: india,darbhanga
Member: 1301266 Status: Offline Sonork: [email protected] Thanks Meter: 1 | download ufs pannel and install |
08-14-2013, 10:10 | #372 (permalink) |
Freak Poster Join Date: Jul 2013 Location: PKD
Member: 1987269 Status: Offline Thanks Meter: 190 | Uninstall old files Disable Antivirus Try these hwk_support_suite_setup_v02.03.000 - Download - 4shared - boy 9440 Regards. |
The Following 2 Users Say Thank You to Major Boy For This Useful Post: |
08-14-2013, 11:50 | #373 (permalink) |
Junior Member Join Date: Jan 2011
Member: 1490667 Status: Offline Thanks Meter: 1 | hi. i can not update the box Box: 1 Location: 33 Serial: 35117 UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 35117 HID: 901B7E1943600023, HWK: A1.04-PRO1 LIC: True HWK: NOT AUTHORISED, Update Box Bad IX: ABCD Failed: 2 Support: Unknown Server Error plz help me |
