09-19-2013, 17:07 | #407 (permalink) |
Junior Member Join Date: Feb 2013 Location: malisya
Member: 1891556 Status: Offline Sonork: 1627444 Thanks Meter: 0 | (how to problam) UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 80018 LIC: True None Authorised Copy of Software Detected, Reinstall HWK: NOT AUTHORISED, Update Box Bad IX: 1111 Failed: 102 Your IP: 180.74.32.69 Support: Bad HID, Cannot Access Suport Something Wrong, Try to Use [Update Box] Box: 1 Location: 275 Serial: 80018 UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 80018 LIC: True Your IP: 180.74.32.69 Support: Bad HID, Cannot Access Suport REST: Ok UFSx: UFS3 SarasSoft, USB S/N: 80018 NVML: Ok BOOT: UFxBoot V2.2 (c) SarasSoft 2003. CORE: UFS_USB V2.8 (c) SarasSoft 2007. SERN: 80018 LIC5: True BOXK: 1 UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 80018 LIC: True ............erroe 16 please renistall support suite |
09-21-2013, 02:11 | #408 (permalink) | |
Registered User Join Date: Mar 2009 Location: Philippines
Member: 995102 Status: Offline Sonork: 100.1647070 Thanks Meter: 2 | Quote:
reinstall support suite... and try to update again.... | |
The Following User Says Thank You to jhed05 For This Useful Post: |
09-24-2013, 09:56 | #409 (permalink) |
Freak Poster Join Date: Jul 2002 Location: .UK Age: 45
Member: 13459 Status: Offline Thanks Meter: 6 | Stuck at 12% and then, message: Connection closed gracefully..... What to do? Box: 1 Location: 289 Serial: 36xxx UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 xxxxx UFS_USB V2.8 (c) SarasSoft 2007., Sn: 36xxx HID: 01C016Bxxxxxxxxx, HWK: A1.04-PRO1 LIC: True Your IP: 92.xx.xx.10 Support: Account Ok REST: Ok UFSx: UFS2 SarasSoft, USB S/N: 36xxx NVML: OK BOOT: UFxBoot V2.2 (c) SarasSoft 2003. CORE: UFS_USB V2.8 (c) SarasSoft 2007. SERN: 36xxx LIC5: True BOXK: 1 UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 xxx UFS_USB V2.8 (c) SarasSoft 2007., Sn: 36xxx HID: 01C016B100xxxxxxx, HWK: A1.04-PRO1 LIC: True Authentication stage error: Connection Closed Gracefully. |
10-07-2013, 05:06 | #410 (permalink) |
Junior Member Join Date: Mar 2013
Member: 1902184 Status: Offline Thanks Meter: 0 | Please forgive me for my English. I had a problem with installing the new update for UFS, and someone really nothing't tell scoffed that bad master cannot install. spera коруптед, then error-6. and not as has not been updated by UFSx_Support_Suite_Setup_v02_03_00_02. But in the end it turns out that the server opens at 8:25 at the time of Tajikistan in Russia respectively at 6:25 and available hour. this time everything is perfectly updated. Actually that's all. After updating my KVC was the status of OK. The only thing that the new update in the Samsung Android is not available, it is designed for a new box. If helped to thank) who will be kind enough to write on other forums, help others, and not as on other forums, instead of threats or accusations of ignorance. a forum and created what would help. just updated and installed for the third box, 2 previous updated it last this time indicated. |
10-20-2013, 02:35 | #412 (permalink) |
Junior Member Join Date: Oct 2013
Member: 2049407 Status: Offline Thanks Meter: 1 | How to help hwk update error pp: UFSx (HWK) Control Panel v 2.3.0.2 by SarasSoft Box: 1 Location: 1059 Serial: 75776 UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 75776 BOX_AUTH_ERROR: 20 BOX: CORRUPTED or MANIPULATED Bad IX: ABCD Failed: -5 Your IP: 27.72.188.188 Support: Bad HID, Cannot Access Suport Something Wrong, Try to Use [Update Box] please help me for the solution |
The Following User Says Thank You to tuanmobilehg For This Useful Post: |
10-20-2013, 06:59 | #414 (permalink) | |
Freak Poster Join Date: Jul 2007 Location: I N D I A
Member: 541724 Status: Offline Sonork: 100.1604043 Thanks Meter: 73 | Quote:
The Following User Says Thank You to wasim_vk For This Useful Post: |
10-20-2013, 07:10 | #416 (permalink) |
Member: 541724 Status: Offline Sonork: 100.1604043 Thanks Meter: 73 | 1. Uninstall ALL previous versions, you MUST uninstall HWK Suite BEFORE trying to uninstall HWK Support Suite Setup. 2. Install UFSx Support Suite Setup 3. Connect your UFSx+HWK before running the UFSx Control Panel 4. Run UFSx Control Panel 5. Select the "Hardware" Tab 6. If you only have one UFSx connected it will be selected, if more than one, select the check box next to the required UFSx. You can click "Scan Boxes" to refresh the list if you have connected further boxes since opening the Control Panel 7. Click "Check Box" 8. Click "Update Box" 9. Click "Check Box" 10. Select the "Software" Tab 11. Amend "Application Install Path" and/or Nokia Install Path, if required. 12. Click "Check Server" 13. Click "Install" 14. If you have more than 1 UFSx+HWK run steps 5-13 for each UFSx+HWK (NOTE: You must install something at step 13) You need to uninstall old HWK Setup Suite and HWK Support Suite and use the new UFSx Support Suite download setup from hear http://www.4shared.com/zip/SLBZupf8/...se_panel_.html |
The Following 2 Users Say Thank You to wasim_vk For This Useful Post: |
10-26-2013, 04:18 | #417 (permalink) |
Member: 2049407 Status: Offline Thanks Meter: 1 | View Post pp: UFSx (HWK) Control Panel v 2.3.0.2 by SarasSoft Box: 1 Location: 1059 Serial: 75776 UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 75776 BOX_AUTH_ERROR: 20 BOX: CORRUPTED or MANIPULATED Bad IX: ABCD Failed: -5 Your IP: 27.72.188.188 Support: Bad HID, Cannot Access Suport Something Wrong, Try to Use [Update Box] my id is not locked by sever it? |
10-28-2013, 14:39 | #419 (permalink) |
Junior Member Join Date: Dec 2012 Location: Roxas, Palawan
Member: 1858421 Status: Offline Thanks Meter: 4 | tanong lang po bat akin nde po mag tuloy CORE: UFST Core v1.2 (c)SarasSoft 2012 SERN: 11262049 LIC5: True BOXK: 0 UFST Boot v1.2 (c)SarasSoft 2012, Id: 54 4D 1 0 UFST Core v1.2 (c)SarasSoft 2012, Sn: 11262049 Last Server Update: 20013/08/21 Not Active Anymore ! For new use this link: Sarunasoftware Support Area -> Message from system No New Items to Install HID: 7EC71E1F416000CD, HWK: A1.04-PRO1 SID: 23067A6819A7A98ED3FA29A48CFE94046674829C XID: 823F5BB63E19D79D68C2A3FEE9DF1999DC4484EF LIC: True Last Server Update: 20013/08/21 Not Active Anymore ! For new use this link: Sarunasoftware Support Area -> Message from system No New Items to Install Connection to server failed. Already connected. None of Boxes Selected or Active Use [Check Box] in Hardware Page None of Boxes Selected or Active Use [Check Box] in Hardware Page None of Boxes Selected or Active Use [Check Box] in Hardware Page None of Boxes Selected or Active Use [Check Box] in Hardware Page None of Boxes Selected or Active Use [Check Box] in Hardware Page None of Boxes Selected or Active Use [Check Box] in Hardware Page None of Boxes Selected or Active Use [Check Box] in Hardware Page App: UFSx (HWK) Control Panel v 2.3.0.1 by SarasSoft Box: 1 Location: 1634 Serial: TMA11262049 UFST Boot v1.2 (c)SarasSoft 2012, Id: 54 4D 1 0 UFST Core v1.2 (c)SarasSoft 2012, Sn: 11262049 HID: 7EC71E1F416000CD, HWK: A1.04-PRO1 SID: 23067A6819A7A98ED3FA29A48CFE94046674829C XID: 823F5BB63E19D79D68C2A3FEE9DF1999DC4484EF LIC: True None Authorised Copy of Software Detected, Reinstall HWK: NOT AUTHORISED, Update Box Bad IX: AB11 Failed: 102 Your IP: 124.6.181.70 Support: Account Ok Something Wrong, Try to Use [Update Box] Last Server Update: 20013/08/21 Not Active Anymore ! For new use this link: Sarunasoftware Support Area -> Message from system No New Items to Install App: UFSx (HWK) Control Panel v 2.3.0.1 by SarasSoft Box: 1 Location: 1634 Serial: TMA11262049 UFST Boot v1.2 (c)SarasSoft 2012, Id: 54 4D 1 0 UFST Core v1.2 (c)SarasSoft 2012, Sn: 11262049 HID: 7EC71E1F416000CD, HWK: A1.04-PRO1 SID: 23067A6819A7A98ED3FA29A48CFE94046674829C XID: 823F5BB63E19D79D68C2A3FEE9DF1999DC4484EF LIC: True None Authorised Copy of Software Detected, Reinstall HWK: NOT AUTHORISED, Update Box Bad IX: AB11 Failed: 102 Your IP: 124.6.181.70 Support: Account Ok Something Wrong, Try to Use [Update Box] Box: 1 Location: 1634 Serial: TMA11262049 UFST Boot v1.2 (c)SarasSoft 2012, Id: 54 4D 1 0 UFST Core v1.2 (c)SarasSoft 2012, Sn: 11262049 HID: 7EC71E1F416000CD, HWK: A1.04-PRO1 SID: 23067A6819A7A98ED3FA29A48CFE94046674829C XID: 823F5BB63E19D79D68C2A3FEE9DF1999DC4484EF LIC: True BOOT: TM UFST Boot v1.2 (c)SarasSoft 2012 Firmware: Ok Your IP: 124.6.181.70 Support: Account Ok REST: Ok UFSx: UFST, USB S/N: 11262049 NVML: OK BOOT: UFST Boot v1.2 (c)SarasSoft 2012 CORE: UFST Core v1.2 (c)SarasSoft 2012 SERN: 11262049 LIC5: True BOXK: 0 UFST Boot v1.2 (c)SarasSoft 2012, Id: 54 4D 1 0 UFST Core v1.2 (c)SarasSoft 2012, Sn: 11262049 HID: 7EC71E1F416000CD, HWK: A1.04-PRO1 SID: 23067A6819A7A98ED3FA29A48CFE94046674829C XID: 823F5BB63E19D79D68C2A3FEE9DF1999DC4484EF LIC: True Connection to server failed. Already connected. Box: 1 Location: 1634 Serial: TMA11262049 UFST Boot v1.2 (c)SarasSoft 2012, Id: 54 4D 1 0 UFST Core v1.2 (c)SarasSoft 2012, Sn: 11262049 HID: 7EC71E1F416000CD, HWK: A1.04-PRO1 SID: 23067A6819A7A98ED3FA29A48CFE94046674829C XID: 823F5BB63E19D79D68C2A3FEE9DF1999DC4484EF LIC: True BOOT: TM UFST Boot v1.2 (c)SarasSoft 2012 Firmware: Ok Your IP: 124.6.181.70 Support: Account Ok REST: Ok UFSx: UFST, USB S/N: 11262049 NVML: OK BOOT: UFST Boot v1.2 (c)SarasSoft 2012 CORE: UFST Core v1.2 (c)SarasSoft 2012 SERN: 11262049 LIC5: True BOXK: 2 UFST Boot v1.2 (c)SarasSoft 2012, Id: 54 4D 1 0 UFST Core v1.2 (c)SarasSoft 2012, Sn: 11262049 HID: 7EC71E1F416000CD, HWK: A1.04-PRO1 SID: 23067A6819A7A98ED3FA29A48CFE94046674829C XID: 823F5BB63E19D79D68C2A3FEE9DF1999DC4484EF LIC: True Connection to server failed. Already connected. yan po help po |
10-30-2013, 04:34 | #420 (permalink) |
No Life Poster Join Date: Mar 2008 Location: RMS- CLUB
Member: 723410 Status: Offline Sonork: 📱 100.1592732 Thanks Meter: 3,374 | Release 28/10/2013 WARNING !!! If the HWK is a "TRIAL" or affected by 3rd party tools, this software may not work properly, so use at your own risk. You need to uninstall old HWK Setup Suite and HWK Support Suite and use the new UFSx Support Suite. UFS_DCTxBB5 V 2.3.0.2 ---------------------- 1. BB5 RAPU Based Products USB Flashing / UI support added: RM-884 (302) 2. DCT4 INFINEON Based Products Flashing / UI support added: RM-908,RM-924,RM-925,RM-926,RM-928,RM-929,RM-961,RM-962 (105,210,.. 210,107,106) 3. Added HiBauds (up to 3Mbaud) on UFST Box, for Infineon XG101 and XG110 Platforms. 4. DCT4 MTK Based Products UI support added: RM-944,RM-945 (108) 5. Windows8 64bit support. UFS_ATRz v2.3.0.2 ------------------ 1. Increased Baud Rate for J220,J230 2. Windows8 64bit support. UFS_KZF v2.3.0.2 ----------------- 1. Added Windows8 64 bit Support. UFS_RTP v2.3.0.2 ---------------- 1. Added Windows8 64 bit Support. SeDBx v2.3.0.2 -------------- 1. Added Windows8 64 bit Support. LG v 2.3.0.2 ------------ 1. Common: Windows8 64bit support. SAMs V 2.3.0.2 -------------- SWIFT-AEROFONE E1260B,E1260L added (PUNL,PIM,FL) E1265,E2262 added (UNL,SECT,IM,FL) INFINEON C3322i,C3590,C3592 added (CUNL,PUNL,PIM,FL,UFL) Many thanks to all those who have supported us!!! Official SarasSoft Mirrors:- ★★ UFSx+HWK Install Files Mirrors & Install Instructions ★★ |
