Unlock Server
Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported IMEI calculator Sites or Software Products > allGSMunlock MultiOnline Remote Server
allGSMunlock MultiOnline Remote Server 20
Old 07-03-2009, 17:17   #1 (permalink)
maverick_lp28's Avatar
Member: 172136
Sonork: 100.1574973
Exclamation FAQ: About entering codes. PLEASE READ before asking!!!
As I see in our section every one hour a user asking about how to enter code
and too many double posts and query about models that we already give a solution for it
and as I know many users are lazy and don't want to use search button
So I decide to make this topic
will have less headache and make users more satisfied
BR!
Mave
Old 07-03-2009, 17:17   #2 (permalink)
Member: 172136
Sonork: 100.1574973
Alcatel
How to enter my Unlock Code on Alcatel ?
Model : Method Generic
1 - Switch ON your phone without SIM Card,
2 - Then compose : *#0000*CODE#,
3 - To finish compose : *#0001*CODE#.
Model : 531 & 535
2 - Press * and without release compose 787292,
3 - A new menu "Unlock Network" will appear, then select "YES",
4 - Enter the Code we send to you.
Model : All other Alcatel
1 - Switch on your phone with a not allowed SIM Card,
2 - When the message "Enter Network Key" appear enter the Code we send to you
Old 07-03-2009, 17:18   #3 (permalink)
Member: 172136
Sonork: 100.1574973
Benq
How to enter my Unlock Code on BENQ ?
Model : All Benq
1 - Switch ON your phone with a not allowed SIM Card,
2 - Enter the Unlock Code we send to you.
The Following User Says Thank You to maverick_lp28 For This Useful Post:
Old 07-03-2009, 17:19   #4 (permalink)
Member: 172136
Sonork: 100.1574973
blackberry
How to enter my Unlock Code on BlackBerry ?
Model : Bold, Curve, 8300, 8310, 8320, 8800, 8820, 9000
Must be done without a sim card inserted & wireless radios must be turned off.
1. Go to settings.
2. Go to options.
3. Go to advanced options.
4. Go to sim card.
4. Hold the ALT Key while typing in MEPE or MEPD or MEPPE or MEPPD ( not case sensitive ) ( you will not see text appear on screen while typing ).
5. It will say "Enter Network MEP Code, then you type in the unlock code, press in the trackball to confirm.
6. Your phone is now unlocked.
Model : BlackBery Storm (9500)
1. Insert any sim card
2. Turn off all of the wireless connections
3. Go to Options
4. Select Advanced Options
5. Select SIM Card
6. Hit menu select show keybord
7. Enter mepd (you will not be able to see the typed info)
8. Enter mep2
9. Now it will say enter network mep code
Model : BlackBerry 8700
Go to the Menu -> Options -> Advanced Options -> Sim card press select, while holding the Shift key (bottom right corner CAPS), type mepd. You should now see the five locking categories listed, while holding the alt key, type mep2. Release the alt key. You are now prompted to enter the Network MEP code. Enter the code, enter Return/Enter, the device should then be unlocked.
Model : BlackBerry 8800
***** You must have a SIM card in your phone to complete these steps ( Can be active or inactive ) *****
1 - Go to settings menu => and then Options
2 - Select Advanced options => and then Sim card
3 - Type MEPD using your Blackberry keyboard (NOTE: You will not see any text appear on the screen while typing MEPD)
4 - Hold the ALT Key while typing in MEPE on your Blackberry keyboard (NOTE: You will not see any text appear on the screen while typing MEPD)
5 - You should be presented with a prompt "Enter Network MEP Code". Type in the 16 digit unlock code received from AllGsmUnlock and press in the track wheel / jog dial to confirm
6 - Your phone is now unlocked
Model : BlackBerry 8100 Pearl
1 - Go to Options Menu => Advanced Options
2 - In the SIM Card menu, hold down the shift (right of the zero, cap) press meppd
3 - You'll see the unlocking level screen there you hold the ALT key (left side below @) type mepp2
4 - Enter the unlock code.
Model : BlackBerry 8100 (Vodafone Australia)
PLEASE READ THE INSTRUCTIONS CAREFULLY BEFORE YOU ATTEMPT ANY UNLOCK PROCESS
This procedure unlocks the handset from being network restricted from only using SIM cards from Vodafone Australia. In case of difficulties, please refer to the FAQ listed below
1. Take note of the unlocking code shown above
2. Insert a Non-Vodafone Australia working SIM card.
3. Ensure the phone is charged and then switch the phone on.
4. Optional Step: If the SIM card has a PIN, enter your PIN number. (See FAQ below)
5. The phone will then display a message. The most common is “Invalid SIM card”. (Different message? See FAQ below)
6. Select “Turn Wireless Off”
7. Select “Settings” Menu , then go to Advanced Options > SIM Card
8. Type alt-MEPT by holding the ALT-key and typing the letters MEPT with multitap i.e. type hold ALT, type {M}{ER}{OP}{OP}{TY}
9. When prompted with “Enter Network MEP code (255 left)” on the screen, enter the 16-digit network unlock code provided for your phone, then press Enter. (Unlocking code is shown above)
10. Reset the phone by pulling the battery
11. Switch the phone on and the handset will be unlocked automatically. This will be confirmed if you can make and receive calls with the Non-Vodafone Australia SIM card. (You will need reception and phone credit with the different network provider)
Please Note:
If the unlocking code is entered incorrectly the next attempt to unlock the device will be delayed for 10 seconds increments. The number of unlocking attempts is limited to 255 tries only. When 255 attempts is reached the phone will be permanently blocked.
To unblock the phone, it must be taken to a RIM service centre. No outgoing calls including emergency call is possible when the phone is blocked.
FAQ:
Question: My phone asks to enter a PIN number
Answer: For SIM cards with PIN ENBLED you will be required to enter a PIN. This is not the unlocking code that has just been provided. For information concerning the PIN, PIN2, PUK and PUK2 codes for a SIM card please read the manual that came with your phone. This is not a handset unlocking difficulty.
Question: My handset displays a different message then what is shown in this procedure when I insert a Non Vodafone Australia SIM card.
Answer: The most common message the phone will display is “Invalid SIM card”. Because each handset may have a different variation in software there is no common message. If your handset displays a different message it is recommended to move onto the next step. Note: Faulty SIM Cards - The handset may also display messages indicating the SIM you are using to unlock the handset is faulty, it could display “Insert SIM” “Bad Card”, “Card Error” or “Card Rejected”, confirm the SIM card is inserted correctly – Gold area downwards and the cut of the corner matches correctly. You will need a working Non Vodafone SIM card to unlock the handset, Vodafone can not assists with other networks faulty SIMs.
Question: I am outside of Australia and experiencing difficulties unlocking the phone that I purchased from a Vodafone Australia outlet
Answer: Clearly note this in the difficulties description. Vodafone Australia can only send a reply to the difficulty by email.
Model : All BlackBerry
1 - Using the menu go to Settings Menu -> SIM card pressselect.
2 - While holding the SHIFT key, type mepd
3 - You should now see the five locking categories listed.
4 - While holding the SHIFT KEY, type mep2.
5 - Release the shift key.
6 - You are now prompted to enter the Network MEP code (it will also state how many attempts left)
7 - Enter the code
8 - Enter Return/Enter
9 - The device should then be unlocked
Old 07-03-2009, 17:21   #5 (permalink)
Member: 172136
Sonork: 100.1574973
Bosh
How to enter my Unlock Code on Bosch ?
Model : All Bosch
2 - When the message "Enter Network Key" appear enter the Code we send to you.
Old 07-03-2009, 17:22   #6 (permalink)
Member: 172136
Sonork: 100.1574973
Ericsson
How to enter my Unlock Code on Ericsson ?
Model : All Ericsson
2 - Press 1 time the left arrow,
3 - Press 2 times the button * ,
4 - Press 1 time the left arrow,
5 - The message "Personalize with MNC2" will appear,
6 - You can now enter the Unlock Code we send to you.
Old 07-03-2009, 17:23   #7 (permalink)
Member: 172136
Sonork: 100.1574973
Handspring
How to enter my Unlock Code on Handspring ?
Model : Treo 180 & 270
2 - Compose : *#*#CODE#
Model : Treo 600
1 - Switch ON your phone with Allowed SIM Card,
2 - Go to Menu and select "Phone Tool" or "Phone Application"
3 - Type on Virtual Keyboard *#*#CODE#
4 - Select with PEN "Numer" and phone will show that's unlocked now !
or
1 - Switch ON your phone with a not Allowed SIM Card,
Old 07-03-2009, 17:23   #8 (permalink)
Member: 172136
Sonork: 100.1574973
Kenwood
How to enter my Unlock Code on Kenwood ?
Model : All Kenwood
1 - Switch ON your phone with a not Accepted SIM Card,
Old 07-03-2009, 17:24   #9 (permalink)
Member: 172136
Sonork: 100.1574973
Lg
How to enter my Unlock Code on LG ?
Model : LG KB770
1. Power on phone with original SIM card
2. Type 2945*#770#
3. In the menu that appears select Sim unlock
4. Enter supplied unlock code
5. Your phone is unlocked
Model : LG KP170
1 - Switch ON your phone with a T Mobile Sim inserted
2 - Press telephone icon at bottom of screen to bring up the phone keypad
3 - Then compose : 2945#*170#
4 - A menu will pop up, select Unlock Usim
5 - Then Select Network Lock
6 - Enter your unlock code and press ok (you only have 10 attempts)
7 - The phone will then reboot and the unlock is complete.
Model: LG CU-515
1.Put a SP-locked sim in the phone, phone say invalid smart chip
2.Now enter *#865625# then select option 1 and then again select 1 and enter your 16 digits code
Phone will be unlocked!
Model : LG TE365
2. Type *#0001#code#
3. Your phone is unlocked
Model : LG CT810 (Incite)
2. Type 2945#*810#
Model : LG CB630 (Invision)
1) Insert an AT&T or Cingular SIM in the phone; it does not have to be an active SIM
2) Dial this into the LG Incite's phone menu
3) *#865625#
4) Press CALL.
5) It should you ask you for the code.
Model : LG U830
1. Have your unlock code handy.
2. Insert a 3 SIM card in the phone and switch power on.
3. Enter the following key sequence 94471877#*#
4. Select the option ‘unlock USIM’.
5. Select the option ‘network unlock’
6. Enter your unlock code.
7. Handset should now display ‘network unlock success’.
8. Handset will now restart.
Model : LG KF300
1. Put wrong simcard
2. Phone alert 'insert correct card'
3. Right under in screen you see deblokkeren (dutch)
4. Click on it en click 'Network lock off'
5. Insert code!
Model: KF510
1. Power on phone with original sim.
2. Type 2945#*71001# and enter code.
Model : LG KP100
1. Insert original sim card and turn phone on.
2. Enter 2945#*20001#
3. Sim unlock mode pop up .
4. Enter your unlock code and press ok
5. The phone will then reboot and the unlock is complete.
Model : LG KF755d
2. Press telephone icon at bottom of screen to bring up the phone keypad
3. Enter 2945#*755# (or 2945#*750# if 1st option doesn't work)
4. A menu will pop up, select sim unlock
5. Enter your unlock code and press ok
6. The phone will then reboot and the unlock is complete
Model : LG Incite CT-810
- Insert a SIM from the original network
- 2945#*810# will show the unlock menu
- Enter unlock code
Model : LG KP265
1 - Use Original SIM to switch ON the Phone.
2 - Compose 2945#*265#
3 - Then go to MENU > SETTINGS > SECURITY
4 - Then go to SIM LOCKS > NETWORK > DESACTIVATE
5 - ENTER NCK (your Unlock Code)
Model : LG ME550
2 - Compose 2945#*71101#.
3 - Menu will appear, go to settings > security > sim lock
4 - Enter NCK ( Unlock Code ) and press OK.
Model : LG TU915
- Switch ON your phone with an allowed SIM Card
- Then compose: 2945#*9701#
- It should you ask you for the code.
OR
Enter *#865625# then enter your 16 digits code.
Model : LG KF390 and KF390q
1) Insert a SIM Card from the network the mobile is locked to and turn it on
2) Insert the following sequence *#865625#;
3) Select 'Unlock USIM'
4) Select 'Network Lock'
5) Insert the unlock code
6) Select ok. Done!
Model : LG *****, KE850 :
1. Switch the telephone on with Original SIM card inside.
2. Enter SIM pin if required.
3. Enter 2945#*8501# and press the call button (middle button bottom of the screen).
4. SIM unlock mode will appear on screen.
5. Enter unlock code
6. Select Reboot.
7. Switch phone off, and then turn back on again. Phone is now unlocked
Model : LG CT810
1. insert original sim card and turn phone on.
2. Enter 2945#*810#
3. A menu will pop up, select sim unlock
Model : LG VU CU915 & CU920 (Vu)
1. Put a AT&T or Cingular SIM in the phone; it does not have to be an active SIM
2. Enter *#865625# then the 16 digit unlock code
3. Device should say: Network Lock Deactivated
4. Phone may automatically reboot and is now unlocked !
Model: F2250
1. With orange sim card in the start menu type : 2945#*3311# handset show saved then return to startup screen press Menu key,
2. choose Settings > Security > Sim Lock> Network > Deactivate,
3. handset will now show 'Enter NCK' tape your unlock code and OK.
Model : LG U310
1. Turn ON the phone without SIM Card :
2. Enter 815118#*#
Model : LG KC550, KS360, KP230, KP500, KP501, KP270, KM900, KM500
2. Enter 2945#*71001#
Model: KF310
2. Enter 2945#*310#
Model: KG375
1. insert a locked simcard, enter your pin if asked,
2. when it says simcard not valid enter your nck and press on green button.
Model : LG KF700 (aka LG Virgo)
2. Enter 2945#*700#
Model : LG KC910, KF910 (aka LG *****)
2. Enter 2945#*910#
Model : LG KF750
2. Enter 2945#*750#
Model : LG KF600
Model: LG KM710
1. With original sim card enter 2945#*710#
2. Model : LG U970
2. Enter 2945#*970#
3. A menu will pop up, select Unlock Usim.
4. Select Network Lock.
5. Enter the unlock code and ok.
Model : LG U300
1 - Switch ON the phone with Accepted SIM Card (from Original Network Provider)
2 - Enter Code : 815118#*#
3 - then phone will ask to enter NCK
Model : LG C2000:
1) Insert non-Cingular SIM card
2) Power on the handset - phone will display "phone restricted"
3) Select "Cancel" - phone will display "phone restriction code"
4) Enter the SIM Unlock code
5) Select "OK" - the handset is now successfully unlocked
Model : LG KU990 Viewty & KE990
3. Enter 2945#*990#
6. The phone will then reboot and the unlock is complete.
Model : LG TU720 - LG CU720 (Shine)
1) Power ON your phone with not allowed sim card (one that didn't come with the phone)
2) Type *#865625#
3) the phone will ask you to input the unlock code twice, just input the unlock code
4) Device is now unlocked
Model : LG CE110
1) Put a non AT&T or Cingular SIM in the phone;
2) The phone display: Invalid Smart Chip
3) Power on handset
4) Select "Cancel" - phone displays "phone restriction code"
5) Enter the unlock code (8 digit code*)
6) Select "OK’" - the handset is successfully unlocked
Model : LG GR500 (Xenon)
1) Insert not-allowed SIM card
2) Power on the handset- phone will display "phone restricted"
4) Enter the SIM unlock code
or
2. Enter 2945#*9701#
Model : LG CU320
1) Power on the handset
2) In Idle screen, input the special code "277634#*#".
3) Enter the SIM Unlock code
4) Access the submenu "SIM Test" in Phone Test Mode.
5) Input the special code "2945#*#".
6) Access the submenu "SIM Unlock" which is just activated after the special code.
7) Input the 8-digit Unlock code in the "Enter unlock code" input screen.
8) It will be unlocked.
Model : LG CU400 & CU405 & CU500v
1) Insert non-Cingular SIM card"
2) Power on the handset - Phone will display "Invalid SmartChip".
3) Enter 159753#*#
4) Enter the 8 digit SIM Unlock code
5) Select "OK".
6) The handset will be unlocked.
Model : LG CU500
1) Insert non-Cingular SIM card.
2) Power on the handset. Phone will display "Invalid SmartChip"
3) (IF THE PHONE DOES NOT DISPLAY INVALID SMARTCHIP, PLEASE POWER OFF AND ON AGAIN)
4) In Idle screen, enter 159753#*#. Phone will display "Enter NCK, Remaining 5
5) Enter the 8 digit SIM unlock code
6) Select "OK"
7) The handset is now successfully unlocked.
Model : LG CU515
3) Enter *#865625# then select option 1 and then again select 1
4) Enter the 16 digit SIM Unlock code
5) Device should say: Network Lock Deactivated
6) The handset is unlocked.
Model : LG CU515 (Trax)
1) Put a non-Cingular sim in the phone
2) Phone says invalid smart chip
3) Now enter *#865625# then select option 1 and then again select 1
4) Enter your 16 digits code
Model : LG U8150
1 - Switch ON your phone with a NOT Allowed SIM Card,
2 - Compose : 2, 7, 7, 6, 3, 4, #, *, #,
3 - Go to menu "SIM Lock",
4 - Enter the Unlock Code we send to you.
Model : LG U400
1. Insert the network SIM in the handset which has given u the LG U400.
2. Enter 2945#*88110#.
3. The phone will then prompt 'Unlock sim'. Press OK.
4. The phone will then prompt 'Network Unlock'. Press OK.
5. The phone will then prompt- 'Input Network Control Key'.
Enter the 8 digit unlocking code. Press OK. If the unlocking code comes with only 7 digits, add a 0 in front of the 7 digit code. If the unlocking code comes with only 6 digits, add 00 in front of the 6 digit code.
6. It should give you the message Success.
7. Come back to the main screen and Enter 2945#*88110#.
8. The phone will then prompt unlock sim. Press OK.
9. The phone will then prompt Network Unlock/ Lock but if you scroll down you will see a message Enter SP Lock. Enter SP Code.
10. Then press OK
Model : All other model
1 - Switch ON your phone with an Allowed SIM Card,
2 - Then compose :
2945#*5101# - (if you have a LG 510w)
1945#*5101# - (if you have a LG 1200 & B1200)
2945#*5221# - (if you have a LG 5200 & 52200)
2945#*5301# - (if you have a LG 5300)
2945#*5401# - (if you have a LG 5400)
2945#*70001# - (if you have a LG 7020)
2945#*7101# - (if you have a LG 7100)
2945#*1201# or 2945#*70001# - (if you have a LG 1100)
2945#*70001# - (if you have a LG7250T)
2945#*2201# - (if you have a LG C2200)
2945#*5301# - (if you have a LG T5100)
2945#*3311# - (if you have a LG C3310)
3 - Go to "Menu" and then to "Settings",
4 - Then select "Security",
5 - To finish select "Network Provider" and select "Desactivate"
6 - Enter the Unlock Code we send to you.
Model : To Classify
For the next models u must to insert the original SIM:
LG C3100 press 2945#*3101#
LG C3380 press 2945#*7101#
LG F2300 press 2945#*7101#
LG KE260 press 2945#*2601#
LG KE970 press 2945#*9701#
LG KG120 press 2945#*1201#
LG KG220 press 2945#*1201#
LG KG240 press 2945#*3311#
LG KG280 press 2945#*7101#
LG KG290 press 2945#*7101#
LG KG800 press 2945#*7101#
LG KU250 press 2945#*250#
LG KU380 press 2945#*380#
After that will appear an secret menu,go to settings-security- sim lock ,enter NCK and press OK.
For next models insert one SIM ,not the original SIM:
LG KU311 press 815118#*#
LG KU800 press 82652#*#
LG L600v press 815118#*#
LG U8150 press 277634#*#
LG U8210 press 277634#*#
LG U8500 press 277634#*#
LG U400 press 2945#*88110#
LG KC550 press 2945#*71001#
LG KU580 press 2945#*580#
LG KT520 press 2945#*520#
LG KF750 press 2945#*750#
LG KF600 press 2945#*71001#
LG KG275 press 2945#*20001#
LG KS500 press 2945#*500#
LG KP270 press 2945#*270#
LG KF240 press 2945#*240# or 2945#*2401#
Enter NCK and press OK.
Old 07-03-2009, 17:25   #10 (permalink)
Member: 172136
Sonork: 100.1574973
Mitsubitshi
How to enter my Unlock Code on Mitsubishi ?
Model : Trium Mars
1 - Swith ON your phone without SIM Card,
2 - Press * and without release compose : 787090 or 787292,
3 - The menu "Unlock Network" will appear,
4 - Select "YES" and enter the Unlock we send to you.
Model : Mitsubishi M341i
1 - Swith ON your phone with an Accepted SIM Card,
2 - Press * and without release compose : 787292,
Model : Mitsubishi M342i
2 - Press * and without release compose : 787090,
Model : All Mitsubishi
2 - Press * and without release compose : 787292 or 78729,
Old 07-03-2009, 17:25   #11 (permalink)
Member: 172136
Sonork: 100.1574973
Motorola
How to enter my Unlock Code on Motorola ?
Model : All Motorola
2 - Phone show "Enter Special Code",
3 - You can now enter the Unlock Code we send to you.
WARNING : If one of theses messages appear :
- "Contact Service Provider"
- "Tampert Alter"
- "Wait before enter special Code"
- "Contact Service'
It's because you or somebody allready enter too many wrong codes, you just have to let phone ON on theses errors messages and after 40 min to 2 hours maximum the message "Enter Code Special" will appear again !
Model : Motorola A1000 and other A models
1 - Click on the icon Phone
2 - Enter the following keys: ** 057 *
3 - Mobile displays "locking enter personalization"
5 - Click Ok
Model : Motorola L6i & L7i (not L6 and L7 without "i")
1 - Press and hold "*" key by dialing code 787090
2 - The mobile displays: "Menu. Network"
3 - Choose 'yes' and then press OK
4 - The mobile ask you for code
5 - Enter the code for unlocking.
Motorola 3G
If your phone is on a 3G network enter **057*
Then enter the unlock code into the window
Motorola CDMA & TDMA
Press 74663 # [Menu] [Menu] and you will be asked for a subsidy code
Enter the code you receive
Motorola MPX
Switch ON your phone with a not allowed SIM card
If phone is asking for NETWORK PIN enter the NETWORK PIN we sent you
If phone is asking for SERVICE PROVIDER PIN. Enter the SERVICE PROVIDER PIN we sent you
If phone is asking for NETWORK PUK
Power on the phone with the original card in and wait till phone is fully powered on and you have access to menu
Type * # * * 3 6 4 # and press green button
You will get a error message and after it your will see Engineering menu
Click Options
Click GSM Test
Select Send AT command
Now you will see a new window Saying "Send AT Command"
Type AT+CLCK="PN",0,"[SERVICE PROVIDER PIN or NETWORK PIN]" and press send
If you get Response "0 []" phone is unlocked
If you get 1 error, then make sure you have typed the code correct and try the other code
Switch your phone off, take battery out. Put battery back in. Power on the phone and leave it for 40 minitues to 5 hours until the message "Enter NETWORK PUK" is gone. Now enter the code received from us and 00000000 (eight zero's) as a new password.
If phone is asking for SERVICE PROVIDER PUK
Click Options
Click GSM Test
Type AT+CLCK="PP",0,"[SERVICE PROVIDER PIN or NETWORK PIN]" and press send
If you do not have the original card or if the original card is not accepted because you flashed the phone with other firmware, then we can not help you
MOTOROLA Z8, Z10 RIZR: **057*CODE with SIM
Old 07-03-2009, 17:26   #12 (permalink)
Member: 172136
Sonork: 100.1574973
Nec
How to enter my Unlock Code on NEC ?
Model : Nec N342i
2 - Compose : **00012*CODE#.
Model : All others NEC
2 - Compose : #7320*CODE#.
Model : old NEC
2 - Compose : #3210*CODE# and press Call Button.
Old 07-03-2009, 17:27   #13 (permalink)
Member: 172136
Sonork: 100.1574973
Nokia
How to enter my Unlock Code on Nokia ?
Model : All Nokia
2 - Compose #PW+CODE+1#
(if locked from Fido/Roger Canada, please compose#PW+CODE+7#)
The letter P appear after press 3 times quickly the button star ( * )
The letter W appear after press 4 times quickly the button star ( * )
The letter + appear after press 2 times quickly the button star ( * )
3 - The phone show "SIM Restriction Off" and was unlocked !
Old 07-03-2009, 17:27   #14 (permalink)
Member: 172136
Sonork: 100.1574973
Panasonic
How to enter my Unlock Code on Panasonic ?
Model : Panasonic GD67/68 & GD87/88 & x70 & P341i
2 - Compose : 746 and press 2 times the button "OK",
3 - A new menu will appear, select "NCK",
4 - You can now enter the Unlock Code we send to you.
Mode : Panasonic G60
1 - Switch ON your Phone with a not allowed Accepted SIM Card
2 - Enter your PIN Code and Confirm
3 - Press a second time on OK button
4 - The phone now ask for Unlock Code !
Model : Panasonic GD50 & GD55
Model : Panasonic X60 & X400
1 - Switch ON your phone with an Accepted SIM Card,
2 - Compose : 52824**,
or
3 - Compose : 746 and press 2 times the button "OK",
4 - A new menu will appear, select "NCK",
5 - You can now enter the Unlock Code we send to you.
Model : Panasonic X100
2 - Compose : #*7465625*638*CODE#
Old 07-03-2009, 17:27   #15 (permalink)
Member: 172136
Sonork: 100.1574973
Philips
How to enter my Unlock Code on Philips ?
Model : All Philips
2 - Phone ask for "Enter NCK",
[FAQ] FuriousGold - Frequently Asked Questions !!! READ BEFORE ASKING ANYTHING ! .:hack3r2k:. FuriouS TeaM Products 4 03-23-2011 08:03
Simple inf0 about POLARBOX2 phone not connected please read before complain★★★ FullFLASHgSMPH PolarBox 2 1 05-28-2009 05:28
F.A.Q - Frequently Asked Questions !!! READ BEFORE ASKING ANYTHING ! Mohsin-* FuriouS TeaM Products 0 11-10-2008 15:00
F.A.Q - Frequently Asked Questions !!! READ BEFORE ASKING ANYTHING ! .:hack3r2k:. FuriouS TeaM Products 0 08-02-2007 20:08
Page generated in 1.35804 seconds with 11 queries
