allGSMunlock MultiOnline Remote Server 20 |
06-11-2009, 09:37 | #1 (permalink) |
No Life Poster Join Date: Aug 2005 Location: 突尼斯 Age: 38
Member: 172136 Status: Offline Sonork: 100.1574973 Thanks Meter: 777 | FAQ about BB5 RPL
The Following 3 Users Say Thank You to maverick_lp28 For This Useful Post: |
06-11-2009, 09:52 | #2 (permalink) |
Member: 172136 Status: Offline Sonork: 100.1574973 Thanks Meter: 777 | How To Read With Jaf Box ..( important Tick Plain) How To Read Ask File Using JAF Box ..( Important Need To Ticked Plain Ask ) Start Jaf Latest Software ,Attach Cable Press Check Or Info To Be Sure Your Mobiles Phone is Connecting Properly After Click CRT Tool Now Must Be Tick On Plain Ask & Select Ask And Give It Location Where You Want To Save , Now Press Read Ask It Will Create Ask File Upload this readed file to ALLGSMUNLOCK SERVER And Get your RPL ! |
The Following User Says Thank You to maverick_lp28 For This Useful Post: |
06-11-2009, 09:54 | #3 (permalink) |
Member: 172136 Status: Offline Sonork: 100.1574973 Thanks Meter: 777 | How To Read With MT Box Nokia How To Read Ask File Using MTBOX Connect Box To Pc & Open Software Read Phone Info & Go To BB5 Ask File TAB Press Read BB5 Ask FIle & Its Ask You Location .Save IT Its Created |
06-11-2009, 09:58 | #4 (permalink) |
Member: 172136 Status: Offline Sonork: 100.1574973 Thanks Meter: 777 | After you do like above you jsut send the ask file in allgsmunlock server After you get RPL now time to write it in phone |
The Following 2 Users Say Thank You to maverick_lp28 For This Useful Post: |
06-11-2009, 10:03 | #5 (permalink) |
Member: 172136 Status: Offline Sonork: 100.1574973 Thanks Meter: 777 | How to write RPL using JAF How to write RPL using JAF After connect cabel please MAKE SURE THAT PHONE IS IN TEST MODE otherwise RPL will not be write back correctly and some errors may occur after write RPL make SX4 authentification and write modified PM without PM 308 and better if it is from the same version of your phone make factory setting ATTENTION!!! ASK/RPL calculation will NOT UNLOCK YOUR PHONE !!! ASK/RPL calculation will NOT CHANGE IMEI, but it will repair it if is 123456xxxxxx as it was original before Last edited by maverick_lp28; 06-11-2009 at 11:14. |
06-11-2009, 11:21 | #7 (permalink) |
Member: 172136 Status: Offline Sonork: 100.1574973 Thanks Meter: 777 | As an advice: DO NOT ERASE THE PHONE, IF YOU DON'T KNOW WHAT YOU ARE DOING. For example for N91 if you erase your phone without making CRT Backup you will loose variant certificate which is NOT RESTORED by RPL. So you can't repair Contact Retailer even you got rpl. Better to ask here about your problem. Also first thing you must do when you get a phone make CRT and PM backup. It will save you. Here is some info about the phone when you make backup. 1. If NPC crt is empty then you maybe have an empty board. In this case RPL will NOT WORK 2. If Variant is empty then someone erased the phone and the RPL may not solve the problem. 3. If other crt have missing or not present message its normal message. Always make selftests with Simlock and Security. It will show you what is the best way to repair your phone. When you want to make SX4 auth and you have Error receive SX4 data error 2 there are two possibilities: 1. You have corrupted simlock data (here is included CLOSED (001-01)) 2. Variant certificate is missing from the phone. Erasing is the last option. BR! maverick_lp28 |
06-11-2009, 11:24 | #8 (permalink) |
Member: 172136 Status: Offline Sonork: 100.1574973 Thanks Meter: 777 | Stay tuned this topic will be updated soon by tips for RPL and related issue |
UB has asked no more thread about bb5 rpl unlock... | GSMman187 | Universalbox | 3 | 02-01-2009 18:11 |
about bb5 rpl??? | kumar.1 | Universalbox | 3 | 11-29-2008 20:45 |
about BB5 RPLs, ASK files and UB | yurais | Universalbox | 3 | 10-12-2008 02:16 |
Any on help if u can....about BB5 Rpl...... | thomp4pal | Nokia Base Band 5 ( BB-5 ) | 2 | 11-05-2007 09:29 |
