Go Back   GSM-Forum > Product Support Sections > Software or online Server Products > allGSMunlock MultiOnline Remote Server
Old 08-23-2008, 16:54   #1 (permalink)
Member: 346934
plz help me with unlock treo 650
Has been the arrival of the Special Body Trio code 680 when introduced, but did accept a letter to inform the mobile
Jet sim lock has not been removed from this phoen.
Please make sure the code sent to us
Sincerely greeting
icket
13276145
Issued
21.08.2008 12:39
Phone Brand
PALM One
Phone Model
Treo 680
Unlock Type
Unlock by Operator
Option
AT&T U.S.A (310-38)
Comments
IMEI
011206001400894
Unlock Code
88574075
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Share on Facebook
Old 08-23-2008, 17:06   #2 (permalink)
AtrixJ's Avatar
Member: 669827
Sonork: 1576281
I don't realy understand what you are saying sir, but here are the correct instructions to enter the code, make sure you follow them precisely:
1. Remove Treo battery, unplug cable
2. Insert incorrect SIM card (Any simcard that the phone does not accept)
3. Power on Treo-650, 'Sim not allowed' is displayed, click OK
4. Go to the dial pad, and use the stylus to enter MEP code . You must enter the code in the following fashion:
*#*#(MEP-CODE)# then press dial
Where (MEP-CODE) is to be replaced by the ACTUAL code supplied by the unlocking software
For example if the software supplied 12345678 as your MEP code for your phone , you must enter the code as follows:
*#*#12345678# , then press dial
Again the above numeric code is for illustration purposes, please enter the MEP code as supplied by the unlock software.
5. Phone will reset and display sim lock removed
Old 08-23-2008, 18:41   #3 (permalink)
Member: 346934
We have been working like commentary that has been explained by you, but the same message to you on the former
Could not accept the code.
Old 09-02-2008, 05:12   #4 (permalink)
Member: 346934
We have been working all that in the commentary but does not accept deciphering final
We have introduced slot that accept him at & t code was accepted, but with the other slot does not accept the code release
I kindly request from allowing work to solve this problem
With thanks
Old 09-02-2008, 11:53   #5 (permalink)
AtrixJ's Avatar
Member: 669827
Sonork: 1576281
First of all sir, please make sure you are entering numbers (digits) for the code and not letters. That is a common mistake.
If you are 100% sure you are doing everything right and that the code is wrong, although Treo codes have very rarely been wrong, press the VERIFY button in the history to send this code for verification with the supplier.
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
GSMCity - GSM Hosting - 1999-2010
Page generated in 0.08264 seconds with 6 queries
