allGSMunlock MultiOnline Remote Server 20 |
07-25-2009, 04:41 | #1 (permalink) |
Freak Poster Join Date: Apr 2008
Member: 742276 Status: Offline Thanks Meter: 9 | >>> Samsung GT-S5230 - how to enter codes <<< 93161374 74725731 74725731 7964291 My phone asked for network lock code, this is the code that work: 74725731 Then it asked for SP lock code, none of the code above works. Now after too many retries, phone is freeze. I tried this method (by dharmdev): #0133*SPCK# : reset SP Lock #0141*PCK# : reset SIM Lock #0199*MCK# : reset Phone Freeze status But phone is not responding to any of the inputs. How to unfreeze and input the code again? Last edited by AtrixJ; 07-25-2009 at 11:42. |
The Following User Says Thank You to chikubie For This Useful Post: |
07-25-2009, 10:39 | #2 (permalink) |
Freak Poster Join Date: Feb 2006
Member: 229188 Status: Offline Thanks Meter: 16 | Put wrong sim in it and then press call put the first code 93161374 and then press call now the phone will ask netwrok lock put the seconde code 74725731 en then phone ask for SP code that the 4 th code you have but as you can see you have only 7 digits then try all digits until is good 7964291 (0) 7964291 (1) 7964291 (2) etc ..... until is okey |
The Following 6 Users Say Thank You to stranger55 For This Useful Post: |
07-25-2009, 11:38 | #3 (permalink) | |
Member: 742276 Status: Offline Thanks Meter: 9 | Quote:
Without your help, i would have lost 12 credits because my customer wants the phone back soon. AtrixJ, if you don't have this information on the sticky, please put it there. | |
07-25-2009, 12:23 | #5 (permalink) |
Member: 229188 Status: Offline Thanks Meter: 16 | how to enter code in S5230 in dutch Veel mensen hebben probleem met invoeren van unlock code in samsung S-5230 Wanneer KPN koopt telefoons met twee lock codes , doen ze nog een extra code bij. Dus om dit toestellen te kunnen unlocken heeft men 3 codes nodig: NCK code : netwerk code . Sp code : tweede unlock code . Unfreez code : dat hb je nodig wanneer je verkeerd codes intypt dan gaat de toestel vriezen en can you niet gebruiken . Wanneer je krijgt unlock codes van AllGSMunlock krijg je dit : Voorbeeld : Ticket 10090261 Issued 24.07.2009 16:23 Phone Brand SAMSUNG Phone Model S5230 Unlock Type Unlock by IMEI IMEI 355178*****13 Unlock Code 9490736236403597 36403597 3636093 CREDIT 12Received 24-07-2009 21:24 De eerste code 94907362 is unfreez code dit gebruike je alleen als je verkeerde codes hen ingetoest . De tweede code 36403597 is nsk ( netwerkblokkerings codee ) De derde code 3636093 sp code maar als je ziet heeft alleen 7 cijfers de laatse cijfer moet je zelf ontdeken bij proberen van 0 t/m 9 dus als je de codes krijgt van de server Gewoon verkeerd simkaart in ,dan vraagt de toestel voor blokerring code type de tweede code in (niet de eerst) en darna vraagt ie voor SP code nu moet he de laatste code intypen met 8 cijfers( die code mist een cijfer gewoon probeer alle cijfer van 0 tot 9) dus probeer welke cijfer hoort bij tot dat het lukt als nogmeer vragen je kunt me altijd prive vragen Last edited by AtrixJ; 07-25-2009 at 12:50. |
The Following User Says Thank You to stranger55 For This Useful Post: |
07-27-2009, 00:45 | #6 (permalink) |
Crazy Poster Join Date: Mar 2003 Location: holland Age: 45
Member: 25302 Status: Offline Thanks Meter: 0 | hallo, Ik heb Samsung s-5230 waarvan alle codes hebt maar hj zegt dat het toestel bevroren is (phone freeze) en SIM niet beschikbaar Neem contact op met de serviceprovider als ik verkkerde sim insteek. nu probeer ik zend knop in te drukken zodat ik freeze code kan invoeren maar dan zegt hij Alarm nummer bellen. Hoe kan ik deze oplossen. bedankt alvast |
07-27-2009, 16:39 | #10 (permalink) |
Junior Member Join Date: Jul 2009
Member: 1083534 Status: Offline Thanks Meter: 2 | Hi Insert unaccepted simcard (First tape in the pin of your unaccepted simcard) Now you are asked for making SOS and Make call Click on make call so digit will be displayed Enter Your freeze code and put # ( nothing will happend or see!! ) THEN enter unlock CODE (and put # if im not wrong ) Phone is unlocked and unfreezed. Tested yesterday . 100% |
07-29-2009, 22:12 | #11 (permalink) | |
No Life Poster Join Date: Sep 2008
Member: 868940 Status: Offline Thanks Meter: 90 | GTs5230 unlocked ok Quote:
regards. | |
The Following User Says Thank You to dawah telecom For This Useful Post: |
07-31-2009, 17:34 | #12 (permalink) |
Member: 1086803 Status: Offline Thanks Meter: 1 | hallo ik wil heel graag mn samsung star ontlocken maar ik snap er helemaal niks van...moet ik bepaalde sowtware hebben?? wil je alsjeeeeeeeeeeeeeeblieft helpen?? alvast bedankt Kal |
how to enter code to Z630 SAMSUNG? | .:R-mitik:. | Easy-Unlocker | 0 | 10-18-2007 08:52 |
How to enter codes obtained from GT server n 8120?? | Burnt Cobba | Griffin | 2 | 10-24-2004 19:44 |
Unlocking GD55's by IMEI - How to enter codes correctly - pls read >>> | STB Trading | Phone Unlocking Codes & Maps | 10 | 10-05-2003 08:58 |
Unlocking GD55's by IMEI - How to enter codes correctly - pls read >>> | STB Trading | Phone Unlocking Codes & Maps | 2 | 10-03-2003 15:53 |
