Go Back   GSM-Forum > Gsm phones Hardware Repair Area > Hardware Equipments for GSM > Tornado Infra Station
Old 01-07-2009, 08:56   #1 (permalink)
Member: 883688
Help me to Tornado Tools
Hi Guys.
Hi have Tornado Pro microscope, Infra Station With Pre Heater.
And now my problem is any one can say me what is the distance between Tornado pre heater and phone boards. at the same time what is the distance between Phone board and Infra hand held gun(in stand)
For a exp: i have to remove CPU of any chinese phones.
so in pre heater heat control should be witch level(1 to 10 available on prea heter control)
same tome in hand held heat control should be how 1 or 2 or 3 ....
and ther is a temprature control i got with this package its for what?
Please Tornado supporters reply me to here. iam waiting for your reply.
Regards.
Old 01-10-2009, 05:46   #2 (permalink)
Member: 883688
Whare are the Tornado supporters? they are sleep????????
The Following User Says Thank You to sulaiti For This Useful Post:
Old 01-10-2009, 15:00   #3 (permalink)
Member: 4566
Sonork: 100.112355
1.The distance between the preheater to pcb and pcb to the hand held gun/heater should be around 2cm.
2. Preheat the PCB at around 100-120 C, use the supplied thermometer to check the actual temperature by placing the tip near the reworked IC.
3. When reworking the IC using the handheld gun/heater/station the temperature should be around 170 - 200 C depending on the melting of that IC you are reworking, for lead free pcb's must be a bit higher are 225C. Try first with the bad non working PCB's for practice. (Use the supplied thermometer to check the actual temperature by placing the tip near the reworked IC.)
The heat control knob varies the voltage supplied to the preheater, so if u set the knob to higher number, the temperature of the preheater/handheld also increases. But the actual temperature that you have to always check was that on the reworked IC/PCB which is measured by the thermometer.
Please do not always set the control knob to maximum at extreme high temperature as it may damage your IC/PCB.
Regards,
The Following 2 Users Say Thank You to ren77 For This Useful Post:
Old 01-11-2009, 09:01   #4 (permalink)
Member: 883688
Anyway Thank you very much.
So these controls on Handheld unit and Pre Heaters atr Not Accurate. also Digital Displays on pre heater and Haldheld unit are Not accurate?
if these Meters show accurate Temprature then these Ifra unit is more usefull.
Thank you.
Old 06-11-2012, 22:11   #5 (permalink)
Member: 1477098
I just bought Tornado infra pro handheld for desoldering glue leadfree iphone logic board but it seem to get long time to melt leadfree and also get high risk to burn the board? So is it important to combine with preheater? is that the best way? Do I need to cover the other ICs and components around and downside of the board? Please help?
please help me to unlock N97 [ANSWERED] longgiang81 Genie Universal 2 03-30-2010 09:18
Help me to an error of the cyclone gardner Cyclonebox 1 03-29-2010 18:51
Help me to identify the network provider borndevils81 iPhone ,iPod & iPad (Apple Inc. Products) 1 03-29-2010 13:38
Help Me My Tornado Ufs-3 When Itry To install HWK_Suite_Setup_v2.0.5.exe PC Suhtdown dvdaio UFS2 + UFS3-Tornadoflasher 3 05-20-2007 20:17
Who can help me to activate the Tornado ? isdnman UFS2 + UFS3-Tornadoflasher 5 02-27-2004 14:44
Page generated in 0.46215 seconds with 11 queries
