Go Back   GSM-Forum > Gsm phones Hardware Repair Area > Hardware Equipments for GSM > Tornado Infra Station
Old 06-26-2008, 14:49   #166 (permalink)
kidgz's Avatar
Member: 551599
anothe great gadgets to use
thanks very much...
Old 09-12-2008, 07:56   #167 (permalink)
cell surgeon's Avatar
Member: 698937
Originally Posted by Syed View Post
good results i tested on some PCB and was good to see the way it worked.
I want more details about it, i m really interested to buy,
want to know that how it removes the connectors without damaging it?
if it gives the heat then how connectors doesn't melt?
Old 10-05-2008, 21:10   #168 (permalink)
gsmsikar's Avatar
Member: 28004
Sonork: 100.1601142
is that possible to remove the connectors without damaging it ?
Old 10-06-2008, 03:42   #169 (permalink)
Member: 4566
Sonork: 100.112355
Yes, its possible.. We have tested it using the tornado infra handheld station by applying less heat around 150 degrees C enough to melt the lead, the infra heat transfers to the metal(lead) thus making the the plastic parts unburnt. For more better and faster reworking we suggest to use the tornado infra preheater for better output.
To measure the temperature, use the thermometer included in the tornado infra package and place the tip near/around the reworked area.
This product is specially made for reworking BGA's, flex, plastic parts, and the lead free IC's.
Br,
Old 11-22-2008, 13:38   #170 (permalink)
moncef5's Avatar
Member: 163515
Is any resseler in tunisia
Old 08-22-2009, 08:34   #171 (permalink)
Member: 1101900
very nice look interesting
many sagem will be unlocked lol
br
Old 02-01-2010, 03:40   #172 (permalink)
ARAB GSM's Avatar
Member: 180675
Sonork: 100.111161 GSM GURU
Very nice device i will buy 1 soon
BR.
ABU
GSM WORLD
Old 09-14-2010, 13:58   #173 (permalink)
Member: 1121946
where can i find live demo in india, west bengal ?
Old 09-16-2010, 04:15   #174 (permalink)
jkniji's Avatar
Member: 643992
Sonork: 100.1625367
Brother i used tonado infra station but big problume is that when i remove flas uem or upp related near components will hot can any one tell me witch is the soluation because infra hot gun hot the big section . can i used high tempreture tap around related components . but my problume is that where to buy this high tempreture tap special tell me new delhi market supplier who can supply this tape kindly solve my problume this is general problume for all tornado infra station user.
Old 09-16-2010, 05:00   #175 (permalink)
Member: 4566
Sonork: 100.112355
@jkniji
You can use the normal aluminum foil found on supermarkets normally used for food keeping. Just wrap it around to cover the components you won't be heating.
Check photo.
Br,
Ren
Old 06-11-2012, 22:05   #176 (permalink)
Member: 1477098
I just bought Tornado infra pro handheld for desoldering glue leadfree iphone logic board but it seem to get long time to melt leadfree and also get high risk to burn the board? So is it important to combine with preheater? is that the best way? Do I need to cover the other ICs and components around and downside of the board? Please help?
Old 08-18-2012, 09:54   #177 (permalink)
Member: 18057
yes pre heater required , cause pre heater can done half job. by heating circuit for 4 min... now infra can take small time to finish work.. but mind it infra only give heat not with air like hot air gun. pre heater very usefull with both for infra or hot air gun too
Old 10-25-2012, 15:44   #178 (permalink)
Crazy Poster
Member: 1147721
Sonork: 100.1624168
hi..i'm interested where to buy in Philippines..and how much the price for complete packages??
**********: CE Certification for Tornado Infra Stations !!! Gobi Tornado Infra Station 10 08-22-2009 08:27
What is Tornado Infra Station ? Gobi Tornado Infra Station 0 07-26-2007 19:05
@tornado Infra Station Needed In Topic @ chiragp Off Topic Zone 1 06-05-2007 12:53
Page generated in 0.37108 seconds with 12 queries
