05-06-2009, 20:07 | #1 (permalink) |
No Life Poster Join Date: Feb 2009 Age: 43
Member: 978268 Status: Offline Thanks Meter: 83 | E6 flash file help SUPPORT i got moto-E6 from customer the phone just hangs on moto logo when i press camera & power button it shows the following info BOOT_G_00.02.21P I am unable to find this similar flash file in boot loader need help regards rkinfo_imran |
05-07-2009, 11:06 | #2 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Central Europe Age: 39
Member: 239548 Status: Offline Thanks Meter: 2,781 | There are such kinds of firmware for E6 as R533, R533H8 (E6) and R535, R535C12, R535H10 (E6e). You must flash proper flash file to the phone. In order to understand what was phone's original firmware version please tell what is written on the sticker under the battery? |
The Following User Says Thank You to mcandre For This Useful Post: |
05-07-2009, 13:15 | #3 (permalink) |
Member: 978268 Status: Offline Thanks Meter: 83 | this is what is written on battery SNN5769A R6W634EGRAER.KE 20070122 KA03173 this is written on the mobile sticker F53AHK2J8Q MT4-411A11 BD ADDR:001C1260B63C FCC ID:IHDT6GP1 T667ZH E6 23MAY07 PLS TELL ME WHICH FIRMWARE I HAVE TO USE TO FLASH THE PHONE WAITING FOR REPLY GRACIAS |
05-07-2009, 13:22 | #4 (permalink) | |
Member: 239548 Status: Offline Thanks Meter: 2,781 | Not quite enough useful information. Quote:
The phone is in a flash mode now, so it worth to try anyway. | |
05-07-2009, 14:14 | #6 (permalink) |
Member: 239548 Status: Offline Thanks Meter: 2,781 | I can't guarantee that the phone will work after flashing because you don't know current firmware version of the phone. If you can do experiments then perform flashing. If not - return this phone to customer. |
05-08-2009, 09:28 | #9 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | Well, we are not on holiday. The suggestion of mcandre is quite right. Now i can only suggest you to try flashing it with higher versions that are located at www.boot-loader.com. Also, can you find out, due to what circumstances the phone got to this "hanging" state? I have a suspect that someone tried unlocking it with network code and didn't succeed. Best Regards GSMServer team |
05-09-2009, 22:50 | #10 (permalink) |
Member: 978268 Status: Offline Thanks Meter: 83 | Searching for phone... found S Blank Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.00 Reading flash id... ST - M58WR032EB Phone group: E2,E6,A1200 after that i full flash the phone,but problem remains same Hardware IMEI: 355557010505733 IMEI OTP status: locked Security area saved to "PDS for S Blank Neptune LTE2 355557010505733 (1).mbk" Unlocking phone... OK Searching for phone... found NS Flash Bulverde, getting test interface... interface not found Switching to flash mode... interface not found Searching for phone... found S Blank Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.00 Reading flash id... ST - M58WR032EB Phone group: E2,E6,A1200 Hardware IMEI: 355557010505733 IMEI OTP status: locked Security area saved to "PDS for S Blank Neptune LTE2 355557010505733 (2).mbk" Writing flash section 2 of 2... 100% (49 Kb/sec) Restarting phone... OK Searching for phone... found S Blank Neptune LTE2 Switching to flash mode... OK IMEI OTP status: locked Performing PDS repair... OK Writing flash section 1 of 1... 100% (17.4 Kb/sec) Please write a corresponding Full_flash file to phone to complete repair after that i full flash the phone with this firmware R533_G_11.12.02P,but problem remains same hoping that gsmserver team will help me out gracias |
05-11-2009, 10:49 | #12 (permalink) | |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | Try flashing it with higher version, for example this one R533_G_11.12.09P.pcf. Also, you didn't reply to the following. Quote:
Best Regards GSMServer team | |
05-12-2009, 09:49 | #14 (permalink) |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | Try flashing it with higher version, for example this one R533_G_11.12.09P.pcf. Best Regards GSMServer team |
05-13-2009, 18:59 | #15 (permalink) |
Member: 978268 Status: Offline Thanks Meter: 83 | [QUOTE=GSM_Support;4460199]Try flashing it with higher version, for example this one R533_G_11.12.09P.pcf. tried but no use this is the log SCout 1.17. Flashing phone "NS Flash Bulverde" with firmware "F:\FLASH-FILES\SMART-CLIP\E-6\R533_G_11_12_09P_1FF.pcf"... Loading file "F:\FLASH-FILES\SMART-CLIP\E-6\R533_G_11_12_09P_1FF.pcf"... OK Preparing firmware image... Loading RAM downloader for bootloader... Waiting for re-enumeration Interface AP-OS: Erasing flash memory... Interface AP-OS: Erase completed! Interface AP-OS: Flashing code group 31... Interface BP: Loading RAM downloader for bootloader... Interface AP-OS: Code group 31 flashed Interface AP-OS: Flashing code group 32... Interface AP-OS: Code group 32 flashed Interface AP-OS: Flashing code group 33... Interface AP-OS: Code group 33 flashed Interface AP-OS: Flashing code group 34... Interface BP: Erasing flash memory... Interface BP: Erase completed! Interface BP: Flashing code group 0... Interface BP: Code group 0 flashed Interface BP: Flashing code group 1... Interface BP: Code group 1 flashed Interface BP: Flashing code group 2... Interface BP: Code group 2 flashed Interface BP: Flashing code group 3... Interface BP: Code group 3 flashed Interface BP: Flashing code group 7... Interface BP: Code group 7 flashed Interface BP: Flashing code group 18... Interface BP: Code group 18 flashed Interface BP: Verifying checksums... Interface BP: Code group 0 checksums match Interface BP: Code group 1 checksums match Interface BP: Code group 2 checksums match Interface BP: Code group 3 checksums match Interface BP: Code group 7 checksums match Interface BP: Code group 18 checksums match Interface BP: Phone is powered down Phone is processing data, please wait. Interface AP-OS: Code group 34 flashed Interface AP-OS: Flashing code group 35... Interface AP-OS: Code group 35 flashed Interface AP-OS: Flashing code group 36... Interface AP-OS: Code group 36 flashed Interface AP-OS: Flashing code group 37... Interface AP-OS: Code group 37 flashed Interface AP-OS: Flashing code group 39... Interface AP-OS: Code group 39 flashed Interface AP-OS: Flashing code group 41... Interface AP-OS: Code group 41 flashed Interface AP-OS: Flashing code group 42... Interface AP-OS: Code group 42 flashed Interface AP-OS: Flashing code group 43... Phone is processing data, please wait. Interface AP-OS: Code group 43 flashed Interface AP-OS: Verifying checksums... Phone is processing data, please wait. Interface AP-OS: Code group 31 checksums match Phone is processing data, please wait. Interface AP-OS: Code group 32 checksums match Phone is processing data, please wait. Interface AP-OS: Code group 33 checksums match Phone is processing data, please wait. Interface AP-OS: Code group 34 checksums match Phone is processing data, please wait. Interface AP-OS: Code group 35 checksums match Phone is processing data, please wait. Interface AP-OS: Code group 36 checksums match Phone is processing data, please wait. Interface AP-OS: Code group 37 checksums match Phone is processing data, please wait. Interface AP-OS: Code group 39 checksums match Phone is processing data, please wait. Interface AP-OS: Code group 41 checksums match Phone is processing data, please wait. Interface AP-OS: Code group 42 checksums match Phone is processing data, please wait. Interface AP-OS: Code group 43 checksums match BP passed AP-OS passed Phone is being rebooted... Phone is processing data, please wait. Device did not re-enumerate after flash operation.Please manually reconnect the device Flash completed! same problem hangs on motorola logo |
Motorola e6 Flash File Needed | kasim | Motorola P2k | 3 | 05-26-2011 19:00 |
Bluetooth nony S208 Flash File Help me | .:ISMAIL_BD:. | SpiderMan | 0 | 03-29-2010 15:34 |
e6 flash file | **JK** | Motorola P2k | 0 | 08-28-2008 15:27 |
E6 Flash File Needed | kasim | Motorola P2k | 0 | 08-26-2008 07:34 |
E6 Flash File Needed | kasim | GSM Mobile Links | 0 | 08-18-2008 14:45 |
