03-09-2012, 22:35 | #1 (permalink) |
No Life Poster Join Date: Dec 2005 Location: mt brazil
Member: 211017 Status: Offline Thanks Meter: 312 | Error flash mb525 SCout 1.43. Flashing phone "S Flash OMAP3630" - "ERROR,NOT FOUND!" flex "ERROR,NOT FOUND!" boot 9.10 with firmware "JORLA_U3_3.4.2_107-7_R02_SIGNED_USAJORDMR1B15CLABRLA019.0R_JORLAFROCL ABRLA_P009_A008_M002_HWp3_Service1FF.sbf" RAM DL 9.10... Preparing firmware image... Loading RAM downloader for bootloader... Jumping to downloader... Erasing flash memory... Erase completed! Flashing code group 31... Code group 31 flashed Flashing code group 32... Code group 32 flashed Flashing code group 33... Code group 33 flashed Flashing code group 34... Code group 34 flashed Flashing code group 35... Code group 35 flashed Flashing code group 39... Code group 39 flashed Flashing code group 42... Code group 42 flashed Flashing code group 45... Code group 45 flashed Flashing code group 47... Code group 47 flashed Flashing code group 53... Code group 53 flashed Flashing code group 61... Code group 61 flashed Flashing code group 64... Code group 64 flashed Flashing code group 65... Code group 65 flashed Verifying checksums... Code group 31 checksums match Error verifying code group 32 - checksums mismatch Error geting subscriber unit checksum. Device API Error: 0xE0030040 Command: RQRCS Error verifying code group 33 - checksums mismatch Error geting subscriber unit checksum. Device API Error: 0xE0030009 Command: RQRCS Error verifying code group 34 - checksums mismatch Error geting subscriber unit checksum. Device API Error: 0xE0030009 Command: RQRCS Error verifying code group 35 - checksums mismatch Error geting subscriber unit checksum. Device API Error: 0xE0030009 Command: RQRCS Error verifying code group 39 - checksums mismatch Error geting subscriber unit checksum. Device API Error: 0xE0030009 Command: RQRCS Error verifying code group 42 - checksums mismatch Error geting subscriber unit checksum. Device API Error: 0xE0030009 Command: RQRCS Error verifying code group 45 - checksums mismatch Error geting subscriber unit checksum. Device API Error: 0xE0030009 Command: RQRCS Error verifying code group 47 - checksums mismatch Error geting subscriber unit checksum. Device API Error: 0xE0030009 Command: RQRCS Error verifying code group 53 - checksums mismatch Error geting subscriber unit checksum. Device API Error: 0xE0030009 Command: RQRCS Error verifying code group 61 - checksums mismatch Error geting subscriber unit checksum. Device API Error: 0xE0030009 Command: RQRCS Error verifying code group 64 - checksums mismatch Error geting subscriber unit checksum. Device API Error: 0xE0030009 Command: RQRCS Error verifying code group 65 - checksums mismatch Flash failed flash scout: SCout 1.43. Flashing phone "S Flash OMAP3630" - "ERROR,NOT FOUND!" flex "ERROR,NOT FOUND!" boot 9.10 with firmware "JORLA_U3_3.4.2_107-9_SIGNED_USAJORDMR1B25CLALALA019.0R_JORLAFROCLALAL A_P021_A013_M011_HWp3_Service1FF.pcf" RAM DL 9.10... Loading file "JORLA_U3_3.4.2_107-9_SIGNED_USAJORDMR1B25CLALALA019.0R_JORLAFROCLALAL A_P021_A013_M011_HWp3_Service1FF.pcf"... OK Preparing firmware image... Error processing flash file. Flash completed with error/warning: Flash library error 15 Help-me |
03-10-2012, 09:43 | #2 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ turca, Please tell us what is wrong with this handset? Why are you trying to flash it? What is current phone's state? Best Regards GSMServer team |
03-10-2012, 17:40 | #3 (permalink) | |
Member: 211017 Status: Offline Thanks Meter: 312 | Quote:
03-20-2012, 08:33 | #6 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Central Europe Age: 39
Member: 239548 Status: Offline Thanks Meter: 2,781 | First of all before flashing you must specify phone's original version. Second: choose appropriate firmware version. What is written on the sticker under the battery? If original version is specified there, then find it at boot-loader and flash your phone with it. |
03-22-2012, 14:46 | #7 (permalink) |
Member: 211017 Status: Offline Thanks Meter: 312 | The original version is not specified there! Teach me how to check the version when the phone is or contains a password mode only boot! is possible by? |
03-26-2012, 15:51 | #10 (permalink) |
Member: 239548 Status: Offline Thanks Meter: 2,781 | First of all, I would try to connect the phone to Scout and read full information from it. Other way to define fw version - it must be written on the sticker. Third way - insert TEST SIM to the phone and find original fw version via phone's menu. I don't recommend you to flash any file you see to your phone. Android based phones aren't cheap. |
03-26-2012, 17:15 | #12 (permalink) | |
03-26-2012, 17:48 | #14 (permalink) |
Member: 211017 Status: Offline Thanks Meter: 312 | In the new update are saying I can upgrade with arq1uivo original, but always got error: SCout 2.00. Flashing phone "S Flash OMAP3630" - "ERROR,NOT FOUND!" flex "ERROR,NOT FOUND!" boot 9.10 with firmware "JORLA_U3_3.4.2_107-7_R02_SIGNED_USAJORDMR1B15CLABRLA019.0R_JORLAFROCL ABRLA_P009_A008_M002_HWp3_Service1FF.sbf" Error processing flash file. Flash completed with error/warning: Flash library error 15 |
03-26-2012, 21:05 | #15 (permalink) |
No Life Poster Join Date: Jun 2004 Location: Poland, Wroclaw Age: 50
Member: 67562 Status: Offline Sonork: none Thanks Meter: 89 | I have JRDNEM_U3_3.4.2_177-003_BLUR_SIGN_SIGNED_UCAJRDNEMARAB1B80AA03A.0R_PDS 03C_USAJRDNFRYORTDACH_P014_A009_HWp3_Service1FF.sb f in DEFY... |
The Following User Says Thank You to roberts For This Useful Post: |
need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-16-2019 19:37 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
error (1002) simlock3.dll winopen | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 08-28-1999 15:57 |
