11-11-2010, 01:28 | #1 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 74814 Status: Offline Thanks Meter: 30 | scout flasher can't detect v3x, please need advice. i have install new v1.33 trying to flash v3x in flash mode but scout flasher can't detect phone in flash or normal mode, did i missed something? please need advice. tia, |
11-11-2010, 08:14 | #2 (permalink) | |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ GSMaxx, After the phone get connected to PC via mini USB cable, drivers suppose to be installed. Quote:
Also, please tell us, what is wrong with this set. Best Regards GSMServer team | |
11-16-2010, 00:51 | #4 (permalink) |
Member: 74814 Status: Offline Thanks Meter: 30 | sir, 1. i'm trying to flash the phone, problem of phone is camera not working and in menu when you select an item the next item is run not the you the one selected. I have already tried change flex and camera still the same. 2.new version drivers are installed since phone is detected by other flasher and flash succesfully. 3. the reason why i'm trying to flash the phone in scout flasher because i want to try to flash a specific flash file on scout format for the phone that may fix the problem. tia, |
11-16-2010, 08:38 | #5 (permalink) | |
No Life Poster Join Date: Mar 2006 Location: Central Europe Age: 39
Member: 239548 Status: Offline Thanks Meter: 2,781 | Quote:
11-16-2010, 08:46 | #6 (permalink) |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ GSMaxx, Have just tried to connect one V3x handset. It get detected without any problems. Please double check cable and ensure that it is connected properly. After that try to detect the phone once again. Best Regards GSMServer team |
01-21-2011, 15:24 | #9 (permalink) |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ KOBOL, Please explain in more details what problem exactly yo have. What phone model are you trying to connect? What had happened to your phone? What problem it has? Best Regards GSMServer team |
04-28-2011, 09:24 | #13 (permalink) |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ romka21, L7 is a P2k based phone model. It was tested and get detected without any problems. Ensure that the cable is properly connected and try once again. Best Regards GSMServer team |
need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 2 | 03-24-2017 16:24 |
needed pinout for carkit(N61xx) | mobileinfo | Nokia Hardware & Hardware Repair | 2 | 07-23-2013 02:41 |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
