09-18-2012, 16:00 | #1 (permalink) | |
No Life Poster Join Date: Jul 2006 Location: Bangladesh Age: 42
Member: 319447 Status: Offline Thanks Meter: 4,949 | Flashing MB855 its possible to flash a MB855 From Sprint, Which is already flashed with US Cellular firmware. Lost GSM 3G and 4G now, Phone needs to be re-flashed with Sprint Firmware. Can Scout downgrade or cross flash this phone ? Here is log from Scout Quote:
*Fix is possible @ Xda Dev But i want quick professional solution. | |
09-19-2012, 08:09 | #2 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Central Europe Age: 39
Member: 239548 Status: Offline Thanks Meter: 2,781 | As far as I remember, you have to enter RSD mode in order to flash this phone. (VOL down/Power. Use VOL down to scroll though options til you see "RSD" then VOL up to enable.) What is the current version of this phone? Can it be detected by Scout? If phone doesn't allow to downgrade itself, then it can't be done by regular flashing. |
09-19-2012, 08:17 | #3 (permalink) |
Member: 319447 Status: Offline Thanks Meter: 4,949 | @ mcandre Glad to see you here. Yes, i connected phone in RSD Mode by pressing Vol Up + Power. Phone flashed successfully with US Cellular firmware. Code: 1FF-sunfire-user-2.3.5-4.5.1A_SUN_USC_19.0-19-release-keys-signed-USC-US.sbf Code: 1FF-sunfire-user-2.3.4-4.5.1A-1_SUN-154_5-CM-release-keys-signed-Sprint-US.sbf as i already wrote in my previous post, fix is possible by xda-dev But its quite lengthy process, is there anything i can do with professional solution ? Thank you once again for your time. |
09-20-2012, 15:39 | #4 (permalink) | |
Member: 239548 Status: Offline Thanks Meter: 2,781 | xda and similar forums put effort into creating solutions for changing radios, gain root access and other interesting options which aren't allowed by the manufacturer. Scout gives you ability to flash the phone with huge amount of ORIGINAL flash files. But I have to repeat that if manufacturer doesn't want the phone to be downgraded on some version, Scout can't do anything here. When you try to downgrade firmware or to perform cross-flashing, in some cases phone dies (you get a brick). Sometimes it's hard to repair such bricks. They can be repaired via J-Tags only. Quote:
The main benefit of Scout is that it gives you all flash files. But they have to be used with the appropriate phones. What was I talking about... Ah yes, about MB855 repair. Looks like your phone can't be repaired by regular flashing only. You have to flash different parts of firmware. Everything is described on XDA forum. So use the method from XDA to bring your phone to the normal life. Scout will help you to flash all those files. Good luck | |
The Following User Says Thank You to mcandre For This Useful Post: |
