Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > GSMServer Products > Scout
Old 12-10-2010, 16:39   #1 (permalink)
curvenger's Avatar
Member: 1014781
L9 stuck in boot mode with error Code Corrupt after flash with L7 firmware.
I tried to flash L9 which stuck in boot mode and displaying Code Corrupt after my friend flash it using L7 firmware with RSDlite. Now the problem is
when i try to flash with Scout, it gives error and cannot complete flash. Here is the complete log
SCout 1.32. Flashing phone "S Flash Neptune LTE2" - "R452J_G_08.21.09R"
flex "GSTHAWITHGIN05A" boot C.70
with firmware "R452J_G_08.21.09R_PDS005_LP004B_DRM0101_VSTG_30E_ 0c_JPJAVA_G_08_L7xDI_05_01_10R_GSTHAWITHGIN05A_1FF _Bangladesh.pcf" RAM DL C.70...
Loading file "R452J_G_08.21.09R_PDS005_LP004B_DRM0101_VSTG_30E_ 0c_JPJAVA_G_08_L7xDI_05_01_10R_GSTHAWITHGIN05A_1FF _Bangladesh.pcf"... OK
Preparing firmware image...
Loading RAM downloader for bootloader...
Erasing flash memory...
Error erasing subscriber unit. Device API Error: 0xE003003F Command: ERASE
Flash failed
Also i tried to flash with higher version i.e R452J_G_08.21.0AR_PDS005_LP0039_DRM0101_VSTG_30E_0 c_JPJAVA_G_08_L7xME_05_00_09R_GSTHAWITHGTR060_1FF. pcf
but end up with same problem. Also the phone goes to blank screen instead of displaying firmware update .... when trying to flash using scout.
The problem with the set before he flashed was that it used to hang sometimes but can booted properly and can be used normally until it got hanged
and need to take out the battery to restart.
Can this be a hardware problem, or just a software coz the set can be used before flashing with wrong file. Can anybody help me out here.??
BR,
curvenger.
The Following User Says Thank You to curvenger For This Useful Post:
Old 12-11-2010, 08:31   #2 (permalink)
GSM_Support's Avatar
Member: 121052
@ curvenger,
What firmware version it initially had?
Did you try to Flash it with the SmartMoto and *.mfw flash files.
Best Regards
GSMServer team
Old 12-11-2010, 10:06   #3 (permalink)
curvenger's Avatar
Member: 1014781
Originally Posted by GSM_Support View Post
@ curvenger,
Best Regards
GSMServer team
The original firmware is R452J_G_08.21.09R and when trying to flash using SmartMoto and *.mfw firmware, error message Critical Error DEA1 is displayed on the phones screen. Here is the complete log
SmartMoto 4.05
S-Card: 5734270xx Smart-Clip dongle, v 3.03, assigned Smart-Clip: 6653485xx Europe, initializing... OK
Clip serial: 6653485xx, version: 5.02, initializing... OK
Searching for phone... found S Flash Neptune LTE2, getting test interface... interface not found
Switching to flash mode... OK
Reading phone boot version... C.70
io timeout
So what else to do now??? Should i flash it with Flash Option Overwrite boot area enabled??
Old 12-11-2010, 11:36   #4 (permalink)
Member: 121052
@ curvenger,
Double check the cable you use to connect the phone (as an option try to use another one), ensure that the power supply you use with the Smart-Clip provides stable output (10V 1A or 12V 750mA) and try to perform Repair PDS and Full Flash procedures via Smart-Clip once again.
If some error appears, please save log file and post it here.
Please notice that in order to perform Repair PDS and Full Flash procedures, Prepare Smart TestPoint suppose to be performed.
Best Regards
GSMServer team
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 8 05-21-2013 19:20
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 28 08-30-2012 03:40
Help with 6110 paulomt1 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 05-25-2009 16:29
Netmonitor with FBus???? ratzfatz Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 4 06-09-1999 17:04
Page generated in 0.32902 seconds with 11 queries
