Unlock Server
Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > GSMServer Products > Scout
Old 03-27-2008, 11:50   #1 (permalink)
GSM_Support's Avatar
Member: 121052
Exclamation M702iS, K1s, W175/W180, W5, U9, Z10 and other models flashing
Dear users,
We are glad to inform you, that the following models:
  • M702iS
  • K1s
  • W5
  • W175/W180
  • U9
  • Z10
are tested and proved to be supported by SCout flasher. Flashes in *.pcf format for them can be downloaded from www.boot-loader.com.
Warning
Some of the flashes might contain SP lock. So it is strictly required to reset Subsidy Code before flashing.
Best Regards
GSMServer team
Old 10-28-2008, 20:07   #2 (permalink)
Member: 534777
U9 not connecting, please help
Hi, i have a motorola U9 which has a phone lock code. i want to flash it using SCOUT. however when i connect the phone to the pc, all i get is
"Found new hardware: MTP device"
and after about 5 seconds the display on the screen reads "usb connection cancelled. Phone now charging. To connect again, unplug cable and plug again."
this when i do brings the display on the pc which says "an error occured while installing your device...."
what do i do????
i'm using a genuine micro usb cable for nokia 6500s and also a genuine motorola micro usb cable.
your help in solving this problem will be greatly appreciated.
thanx and best regards
Old 10-29-2008, 08:30   #3 (permalink)
Mr.Tinkertrain's Avatar
Member: 229997
@ wodashie,
Check this link, please.
Best Regards
Smart-clip team
www.smart-clip.com
www.scoutdongle.com
www.GsmServer.com
www.boot-loader.com
www.smart-unlocker.com
Old 10-30-2008, 21:05   #4 (permalink)
Member: 164455
i wanna flash a motorola w175g , is there any *pcf w175g flashes ......or can i just use the w175 flsh ....thanks
Old 10-31-2008, 09:05   #5 (permalink)
Member: 229997
@ etimoult,
Flash files for the W175g can be found at the boot-loader.com in the SCout->SFL->W175g->... file folder.
W175g can not be flashed with the W175 flash files. Otherwise it will stay in flash mode.
Best Regards
Smart-clip team
www.smart-clip.com
www.scoutdongle.com
www.GsmServer.com
www.boot-loader.com
About PDS-Repair of Z3xx and other Argon-Flash based models. Gubby_J Smart-Clip 1 02-05-2010 10:35
lg 3100 pins ouputs and other models lucian LG 0 03-04-2005 13:26
Sonyericsson T610 And Other Models Online Server !!! bahtiyar Main Sales Section 0 07-02-2003 20:12
CLOCK on T2288 and other models mobitech Old Legacy Motorola (EMMI) 2 09-11-2000 01:04
Page generated in 3.38586 seconds with 11 queries
