Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > GSMServer Products > Scout
Old 01-21-2012, 03:26   #1 (permalink)
Member: 612635
MB300 - Pattern Lock ? Flash ?
Hi
I have a MB300 which has a pattern lock - Ive tried to hard reset the phone but it says "Security on, Fastboot Disabled"
So I am assuming that I can flash the phone
Could you please tell me what file to use ?
I tried another file bfore but it gave a ram error ?
Details of the phone.
Phone model    BACKFLIP MB300
Hardware    SJUG6022AA
IMEI    35669xxxxxxxxxx
Technology    UMTS 3G
System    Blur_Version.0.4.12.MB300.TNZ.en.NZ
Firmware config    GAS_EMEA_USAMOTS01TELNZ_P011
Baseband
Baseband config    USAMOTS01TNZE1048.0R
Build number    R6380CP1_029.00.02
Hope you can help
Cheers!
Old 01-23-2012, 07:40   #2 (permalink)
mcandre's Avatar
Member: 239548
Why do you want to flash your phone for? In case it has phone lock (phone code) make wipe (factory reset):
1. Power off phone.
2. Hold camera button and power on phone at the same time.
3. Release the camera button when prompted to.
4. You will see a message screen telling you to press the up or down volume button
5. Press and HOLD the down volume key (ignore message 'Volume Up Key Pressed')
6. When triangle and phone screen appears
7. Press on the screen just above the back key
8. You will now see the "Motorola system recovery" menu
At this point you will have three choices:
1. reboot system now [Menu+Back]
2. apply ssdcrad:update.zip [Alt+S]
3. wipedata/factory reset [Alt+W]
You can simply tap an item to select it.
At the bottom of the screen you can select OK to apply your choice from the menu.
There is also an opportunity to select Hide on the bottom left, I don't know what that does (I tried it and nothing happened).
Selecting Wipe data/factory reset and tapping Ok and the screen changes to a box and a phone (Get it - out of the box) and you see what is happening on the phone.
pick 2
-- Wiping data...
Formatting DATA:...
Formatting CACHE:...
Data Wipe Complete.
Press Menu+Back to reboot
pressing Menu+Back did nothing for me so I tapped 'reboot system now' on the menu and Ok.
The phone restarted and took me through the setup prompts.
The Following User Says Thank You to mcandre For This Useful Post:
Old 01-24-2012, 06:09   #3 (permalink)
Member: 612635
Thanks
Ive used that method before - But with this phone I get "Security on, Fastboot Disabled"
Old 01-24-2012, 10:17   #4 (permalink)
mcandre's Avatar
Member: 239548
I would suggest you to flash with this version: Android_BACKFLIP_MOTUS_EMEA_MB300\0.4.14\
motus-Retail-02-0.4.14-supermonster-customer-secure
Help: Forgot my 6110 user lock code!! GByte9 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 5 05-10-2012 14:14
my 8810 is phone locked ,can somebody please help duyphuc Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 16 02-01-2012 05:18
SP Lock 1&4 dw Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 11 06-26-1999 06:22
Need info for unliocking 2 lock (with pic microprocesors) Tomas Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 06-26-1999 01:00
Page generated in 0.37230 seconds with 11 queries
