MB525 dead Other mb525 dead by Scout My phone is freeze in logo, phone is Tim brazil, I make hard reset but no work SCout 2.01. Flashing phone "S Flash OMAP3630" - "ERROR,NOT FOUND!" flex "ERROR,NOT FOUND!" boot 9.10 with firmware "JORLA_U3_3.4.2_107-9_SIGNED_USAJORDMR1B15TIMBRLA019.0R_JORLAFROTIMBRL A_P013_A009_M001_HWp3_Service1FF.pcf" Loading file "JORLA_U3_3.4.2_107-9_SIGNED_USAJORDMR1B15TIMBRLA019.0R_JORLAFROTIMBRL A_P013_A009_M001_HWp3_Service1FF.pcf"... OK Preparing firmware image... Loading RAM downloader for bootloader... Jumping to downloader... Erasing flash memory... Erase completed! Flashing code group 31... Code group 31 flashed Flashing code group 32... Code group 32 flashed Flashing code group 33... Code group 33 flashed Flashing code group 34... Code group 34 flashed Flashing code group 35... Code group 35 flashed Flashing code group 39... Code group 39 flashed Flashing code group 42... Code group 42 flashed Flashing code group 45... Code group 45 flashed Flashing code group 47... Code group 47 flashed Flashing code group 53... Code group 53 flashed Flashing code group 61... Code group 61 flashed Flashing code group 64... Code group 64 flashed Flashing code group 65... Code group 65 flashed Verifying checksums... Error verifying code group 31 - checksums mismatch Error verifying code group 32 - checksums mismatch Error geting subscriber unit checksum. Device API Error: 0xE003003F Command: RQRCS Error verifying code group 33 - checksums mismatch I make 3 mb525 3 dead problem is scout no mb525, Look at my old topics about this model |
Are you sure that you have flashed the right version for your phone? Sometimes Motorola doesn't allow you to downgrade or change firmware version. Sometimes when you use flash file with wrong firmware version, this can cause it's brick. Are you sure that nothing is wrong with phone's hardware? Because you told that phone "freeze in logo". I also have experience of MB525 flashing, everything passed fine: http://forum.gsmhosting.com/vbb/f417...scout-1387651/ |
SCout 1.43. Flashing phone "S Flash OMAP3630" - "ERROR,NOT FOUND!" flex "ERROR,NOT FOUND!" boot 9.10 with firmware "JORLA_U3_3.4.2_107-7_R02_SIGNED_USAJORDMR1B15CLABRLA019.0R_JORLAFROCL ABRLA_P009_A008_M002_HWp3_Service1FF.pcf" RAM DL 9.10... Loading file "JORLA_U3_3.4.2_107-7_R02_SIGNED_USAJORDMR1B15CLABRLA019.0R_JORLAFROCL ABRLA_P009_A008_M002_HWp3_Service1FF.pcf"... OK Preparing firmware image... Error processing flash file. Flash completed with error/warning: Flash library error 15 |
Scout 2.01 supports flashing MB525 with both motorola and scout .pcf files just fine. There is absolutely no reason to go back and install any older version. The problem with androids and this is exactly the problem with your MB525 is finding a truly corresponding firmware file because flashing an improper firmware leads to sad results including phone death |
Today I got one more with code MOTOBLUR mb525, I hard reset I did and it worked normal, to take my doubts connected the scout, and rsd motorola software update This phone is the same operator that the scout who died, had this information Label: MB525 TLAM212N SCOUT: Phone model DEFY MB525 Hardware SJUG5998BA IMEI 354714040135160 Technology UMTS System Firmware config GAS_LA_USAJORDBCLABRLA_P031 Baseband EPU93_U_00.49.00 Baseband config USAJORDB15CLABRLA011.0R (unlocked) Build number JORLA_U3_6.14.5_R01 RSD LITE: IMEI: 354714040135160 Technology: UMTS Software Version: JORLA_U3_6.14.5_R01EPU93_U_00.49.00 Flex Version: USAJORDB15CLABRLA011.0R Bootloader Version: 0910 DRM Version: N/A Motorola Software Update: There is no software update currently available for your phone. This is my latest version? |
Motorola says that the version in your phone is high, no fw update available. By the way, Scout says that your phone is branded to Claro, but it's unlocked. But it must be locked, because Claro locks it's phones. |
I have a MB525 with blank screen-but the phone is in boot mode -and during the fw upgrade the phone shows "SW update in progress.." so the display is works . I flashed many versions ,but still can't switch on . Could somebody tell me, whats the latest version -or some help to repair it ? |
4.5.1-134-DFP-74-gingerbread-BL5-fixed - Download - 4shared RSD lite repair this file by first install the appropriate software on the device will work. |
