Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > GSMServer Products > Scout
Old 06-14-2012, 20:44   #1 (permalink)
turca's Avatar
Member: 211017
Thanks Meter: 265
MB525 dead
Other mb525 dead by Scout
My phone is freeze in logo, phone is Tim brazil, I make hard reset but no work
SCout 2.01. Flashing phone "S Flash OMAP3630" - "ERROR,NOT FOUND!"
flex "ERROR,NOT FOUND!" boot 9.10
with firmware "JORLA_U3_3.4.2_107-9_SIGNED_USAJORDMR1B15TIMBRLA019.0R_JORLAFROTIMBRL A_P013_A009_M001_HWp3_Service1FF.pcf"
Loading file "JORLA_U3_3.4.2_107-9_SIGNED_USAJORDMR1B15TIMBRLA019.0R_JORLAFROTIMBRL A_P013_A009_M001_HWp3_Service1FF.pcf"... OK
Preparing firmware image...
Loading RAM downloader for bootloader...
Jumping to downloader...
Erasing flash memory...
Erase completed!
Flashing code group 31...
Code group 31 flashed
Flashing code group 32...
Code group 32 flashed
Flashing code group 33...
Code group 33 flashed
Flashing code group 34...
Code group 34 flashed
Flashing code group 35...
Code group 35 flashed
Flashing code group 39...
Code group 39 flashed
Flashing code group 42...
Code group 42 flashed
Flashing code group 45...
Code group 45 flashed
Flashing code group 47...
Code group 47 flashed
Flashing code group 53...
Code group 53 flashed
Flashing code group 61...
Code group 61 flashed
Flashing code group 64...
Code group 64 flashed
Flashing code group 65...
Code group 65 flashed
Verifying checksums...
Error verifying code group 31 - checksums mismatch
Error verifying code group 32 - checksums mismatch
Error geting subscriber unit checksum. Device API Error: 0xE003003F Command: RQRCS
Error verifying code group 33 - checksums mismatch
I make 3 mb525 3 dead problem is scout no mb525, Look at my old topics about this model
Old 06-15-2012, 09:09   #2 (permalink)
mcandre's Avatar
Member: 239548
Thanks Meter: 2,188
Are you sure that you have flashed the right version for your phone? Sometimes Motorola doesn't allow you to downgrade or change firmware version.
Sometimes when you use flash file with wrong firmware version, this can cause it's brick.
Are you sure that nothing is wrong with phone's hardware?
Because you told that phone "freeze in logo".
I also have experience of MB525 flashing, everything passed fine: MB525 restarting. Fixed by Scout
Old 06-15-2012, 13:36   #3 (permalink)
turca's Avatar
Member: 211017
Thanks Meter: 265
Look, I know that the correct versions, my phone was working, only problem was with the default block because I could not do a hard reset, if you look at my posts I help a lot to fix several bugs, I understand a bit of software as some versions of the scout that I helped fix bug, I'd like to try other versions as 1:43, but got the error, because with this bug.
SCout 1.43. Flashing phone "S Flash OMAP3630" - "ERROR,NOT FOUND!"
with firmware "JORLA_U3_3.4.2_107-7_R02_SIGNED_USAJORDMR1B15CLABRLA019.0R_JORLAFROCL ABRLA_P009_A008_M002_HWp3_Service1FF.pcf" RAM DL 9.10...
Loading file "JORLA_U3_3.4.2_107-7_R02_SIGNED_USAJORDMR1B15CLABRLA019.0R_JORLAFROCL ABRLA_P009_A008_M002_HWp3_Service1FF.pcf"... OK
Error processing flash file.
Flash completed with error/warning: Flash library error 15
Old 06-19-2012, 22:13   #4 (permalink)
turca's Avatar
Member: 211017
Thanks Meter: 265
I need information is bug?
Old 06-20-2012, 08:28   #5 (permalink)
Member: 686425
Thanks Meter: 9
Scout 1.43 supported flashing MB525 with motorola original .shx / .sbf flash files only, this was a known behavior.
Scout 2.01 supports flashing MB525 with both motorola and scout .pcf files just fine. There is absolutely no reason to go back and install any older version.
The problem with androids and this is exactly the problem with your MB525 is finding a truly corresponding firmware file because flashing an improper firmware leads to sad results including phone death
Old 06-25-2012, 23:24   #6 (permalink)
turca's Avatar
Member: 211017
Thanks Meter: 265
Today I got one more with code MOTOBLUR mb525, I hard reset I did and it worked normal, to take my doubts connected the scout, and rsd motorola software update
This phone is the same operator that the scout who died, had this information
Label: MB525 TLAM212N
SCOUT:
Phone model DEFY MB525
Hardware SJUG5998BA
IMEI 354714040135160
Technology UMTS
System
Firmware config GAS_LA_USAJORDBCLABRLA_P031
Baseband EPU93_U_00.49.00
Baseband config USAJORDB15CLABRLA011.0R (unlocked)
Build number JORLA_U3_6.14.5_R01
RSD LITE:
IMEI: 354714040135160
Technology: UMTS
Software Version: JORLA_U3_6.14.5_R01EPU93_U_00.49.00
Flex Version: USAJORDB15CLABRLA011.0R
Bootloader Version: 0910
DRM Version: N/A
Motorola Software Update:
There is no software update currently available for your phone.
This is my latest version?
Old 06-26-2012, 12:20   #7 (permalink)
mcandre's Avatar
Member: 239548
Thanks Meter: 2,188
Motorola says that the version in your phone is high, no fw update available.
By the way, Scout says that your phone is branded to Claro, but it's unlocked.
But it must be locked, because Claro locks it's phones.
Old 06-26-2012, 13:32   #8 (permalink)
turca's Avatar
Member: 211017
Thanks Meter: 265
So checking the information in this phone that works, it would be possible to repair that died in the software?
Old 12-29-2013, 19:08   #9 (permalink)
clone's Avatar
Member: 19327
Thanks Meter: 45
I have a MB525 with blank screen-but the phone is in boot mode -and during the fw upgrade the phone shows "SW update in progress.." so the display is works . I flashed many versions ,but still can't switch on . Could somebody tell me, whats the latest version -or some help to repair it ?
Old 01-13-2014, 03:36   #10 (permalink)
Member: 1210902
Thanks Meter: 63
4.5.1-134-DFP-74-gingerbread-BL5-fixed - Download - 4shared
RSD lite repair this file by first install the appropriate software on the device will work.
Repaired dead phone without backup Prodigal Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 07-29-2011 11:26
HELP Dead 5130 v5.00 N.Schmetz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 03-08-2011 03:51
help! Dead 5110 v5.30 aklishin Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 04-04-2001 11:56
nokia 5110 dead alpha Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 02-28-2001 10:59
6150 V5.20 WANTED --- DEAD OR ALIVE --- IT'S BETTER ALIVE ! ;))) tcamilo Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 12-19-1999 21:30
Page generated in 0.36529 seconds with 8 queries
