Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2006 Location: the center of the world
Member: 309299 Status: Online Thanks: 54
| problem flashing motorola xt300 i just get motorola xt300 stuck on motorola logo, i try factory reset without succes so i decide to flash phone with my scout but i get error here is log SCout 1.33. Flashing phone "Motorola A309" flex "USASESRETBRB1B5LA015.0R" with firmware "SESGC_U3_00.35.0-monster-gener.pcf" RAM DL 0.00... Loading file "SESGC_U3_00.35.0-monster-gener.pcf"... OK Switching to flash mode... Unable to retrieve phone interface Flash completed with error/warning: Flash library error 39 any advice will be great |
| | #2 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2008
Member: 746276 Status: Offline Sonork: 100.1609752 Thanks: 59
| Try to flash the cell phone using latest RSD Lite version, I think Scout software doesn't yet fully support it. In addition, here you are a new firmware for the handset:SESLA_U3_01.72.0.rar maybe it could you help you to revive it. Note: The firmware is a latin american version. |
| | #5 (permalink) |
| Product Supporter ![]() ![]() ![]() Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Thanks: 445
| @ denisirias, What information is signed at the sticker under the battery of the phone? Best Regards GSMServer team |
| | #7 (permalink) | |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Oct 2004 Age: 37
Member: 86865 Status: Offline Thanks: 12
| Quote:
| | #8 (permalink) |
| @ mdpm, Provide us with more detailed information: What had happened to the phone? Why are you trying to flash it? What information is signed at the sticker under the battery of the phone? Post here log file, please. Best Regards GSMServer team |
| | #9 (permalink) |
| Junior Member Join Date: Apr 2011
Member: 1566855 Status: Offline Thanks: 0
| (English) Hello, before I apologize for my English. My SPICE XT300 No boot and only the Motorola logo remained on the screen. After many attempts and several readings I was able to reinstall the entire system in my motorola XT300. Using RSD Lite 4.9, and when trying to use the ROM "SESLAU301.72.0" gave me the error: "Unable to retrieve interface handle. (0x7027); phone connected" and I could not do it until I did what I describe below. 1 - Download the SESLA_U3_01.72.0.sbf (Copy it to C: \) 2 - Install all drivers SPICE XT300. 3 - Connect the SPICE XT300 with the USB cable. 4 - Run RSD Lite 4.9. 5 - Remove the battery from the phone and wait a few seconds. 6 - Insert the battery cell phone and when it starts, hold down the X key on the keyboard until the XT300 a triangle with an exclamation point after that press the key combination ALT + X to access the RECOVERY. 7 - Select WIPE DATA / CACHE using the volume control keys and the ENTER key. 8 - Pay attention now, and remember that you already have a cell phone connected to the USB port and have run the RSD Lite 4.9 (in steps 3 and 4), so just select reboot option and immediately hold down the bar space until the blue screen appears with a message saying BOOTLOADER. 9 - If all this is done step by step you at this time on the screen of your computer would be seeing the RSD Lite 4.9 informing you that you have entered the ENGINEERING MODE. 10 - Using the mouse click on the button with ... (three points) and select the file you copied SESLA_U3_01.72.0.sbf C: \ (in step 1) 11 - Using the mouse, click the START button on the RSD Lite 4.9 And then on screen you will see that SPICE XT300 begin installing the system showing different messages, and at the same time, the window of the RSD Lite 4.9, you will see the progress of the process of flashing. When it reaches 86% of the process is stopped momentarily, but then continues, so do not worry. When the process ends, the XT300 SPICE will automatically restart. Remember the first time the SPICE XT300 starts, it can take about 3 to 10 minutes. I hope that what I just explained it helps someone. Until next time! Mariano mipcomp@gmail.com windor98@hotmail.com (Español) Hola, quería realizar mi aporte para ayudar a los que han pasado por lo mismo que yo y mi SPICE XT300. Mi SPICE XT300 no booteaba y solo quedaba el logotipo de Motorola quedaba en la pantalla. Luego de muchos intentos y de varias lecturas logré instalar nuevamente el sistema por completo en mi motorola XT300. Usando el RSD Lite 4.9, y cuando intentaba utilizar el ROM "SESLAU301.72.0" me daba el error: "Unable to retrieve interface handle.(0x7027);phone connected" y no pude realizarlo hasta que hice lo que describo a continuación. 1- Descargar el SESLA_U3_01.72.0.sbf (Copiarlo al C:\) 2- Instalar todos los drivers del SPICE XT300. 3- Conectar el SPICE XT300 con el cable USB. 4- Ejecutar el RSD Lite 4.9. 5- Quite la batería del celular y espere unos segundos. 6- Inserte la batería al telefono celular y cuando éste se encienda, mantenga presionada la tecla X en el teclado del XT300 hasta que aparezca un triángulo con un signo de admiración, luego de esto presione la combinación ALT+X para acceder al RECOVERY. 7- Seleccione WIPE DATA/CACHE usando las teclas de control de volumen y la tecla ENTER. 8- Preste atención en este momento, y recuerde que usted ya tiene el teléfono celular conectado al puerto USB y ha ejecutado el RSD Lite 4.9 (en los pasos 3 y 4), así que solo debe seleccionar opción REBOOT e inmediatamente mantener presionada la barra espaciadora hasta que la pantalla azul aparezca con un mensaje diciendo BOOTLOADER. 9- Si todo esto lo realizó paso a paso usted en este momento en la pantalla de su computadora estaría viendo que el RSD Lite 4.9 le informándole a usted que ha ingresado al MODO INGENIERÍA. 10- Utilizando el mouse haga click en el botón que aparece con ... (tres puntos) y seleccione el archivo SESLA_U3_01.72.0.sbf que usted copió en C:\ (en el paso 1) 11- Utilizando el mouse haga click en el botón START en el RSD Lite 4.9 Y entonces en la pantalla del SPICE XT300 usted verá que el sistema empieza a instalarse mostrando distintos mensajes, y al mismo momento, en la ventana del RSD Lite 4.9, usted verá el progreso del proceso de FLASHING. Cuando llega al 86% del proceso se detiene momentáneamente, pero luego continua, así que no hay que preocuparse. Cuando termina todo el proceso, el SPICE XT300 se reiniciará automáticamente. Recuerde que la primera vez que el SPICE XT300 inicia, puede demorar alrededor de 3 a 10 minutos. Espero que esto que acabo de explicar le sirva a alguien. Hasta la próxima! Mariano mipcomp@gmail.com windor98@hotmail.com |
| | #10 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Jul 2008 Location: germany
Member: 817412 Status: Offline Sonork: 1618066 Thanks: 1,209
| esta exelente y efectivo el metodo pero brother como hago root a este modelo no funciona y tengo la flash brasileira |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Sim card sleep mode problem with 6130 | ratzfatz | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 4 | 05-22-2012 11:13 |
| Seeking for flash nokia 5110 old version (3 version) can exchange for new | Tomas | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 7 | 11-17-2011 17:08 |
| need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 0 | 08-16-1999 12:20 |
| HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 1 | 07-16-1999 00:44 |
| 5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 2 | 07-07-1999 12:27 |
