Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > GSMServer Products > Scout
Old 09-18-2012, 16:00   #1 (permalink)
.:SUBRATA:.'s Avatar
Member: 319447
Thanks Meter: 4,949
Flashing MB855
Hi
its possible to flash a MB855 From Sprint,
Which is already flashed with US Cellular firmware.
Lost GSM 3G and 4G now, Phone needs to be re-flashed with Sprint Firmware.
Can Scout downgrade or cross flash this phone ?
Here is log from Scout
SCout 2.03. Flashing phone "SE Flash Sunfire" - "N/a"
flex "N/a" boot 0.07
with firmware "1FF-sunfire-user-2.3.4-4.5.1A-1_SUN-154_5-CM-release-keys-signed-Sprint-US.sbf"
The smart card status is 'removed'
Preparing firmware image...
Loading RAM downloader for bootloader...
Jumping to downloader...
Waiting for re-enumeration
Phone did not re-enumerate after RAM-downloader was sent.
Flash failed
Or Sigma Box can do ? if so i ll buy one to fix this phone.
*Fix is possible @ Xda Dev
But i want quick professional solution.
Old 09-19-2012, 08:09   #2 (permalink)
mcandre's Avatar
Member: 239548
Thanks Meter: 2,781
As far as I remember, you have to enter RSD mode in order to flash this phone.
(VOL down/Power. Use VOL down to scroll though options til you see "RSD" then VOL up to enable.)
What is the current version of this phone? Can it be detected by Scout? If phone doesn't allow to downgrade itself, then it can't be done by regular flashing.
Old 09-19-2012, 08:17   #3 (permalink)
Member: 319447
Thanks Meter: 4,949
@ mcandre
Glad to see you here.
Yes, i connected phone in RSD Mode by pressing Vol Up + Power.
Phone flashed successfully with US Cellular firmware.
1FF-sunfire-user-2.3.5-4.5.1A_SUN_USC_19.0-19-release-keys-signed-USC-US.sbf
Phone needs to be flashed with this firmware
But phone not allowing to change firmware normally.
as i already wrote in my previous post, fix is possible by xda-dev
But its quite lengthy process, is there anything i can do with professional solution ?
Thank you once again for your time.
Old 09-20-2012, 15:39   #4 (permalink)
mcandre's Avatar
Member: 239548
Thanks Meter: 2,781
xda and similar forums put effort into creating solutions for changing radios, gain root access and other interesting options which aren't allowed by the manufacturer.
Scout gives you ability to flash the phone with huge amount of ORIGINAL flash files.
But I have to repeat that if manufacturer doesn't want the phone to be downgraded on some version, Scout can't do anything here.
When you try to downgrade firmware or to perform cross-flashing, in some cases phone dies (you get a brick). Sometimes it's hard to repair such bricks. They can be repaired via J-Tags only.
Flash failed
That's why sometimes phone's hardware doesn't accept some flash files. In other words, it says "I don't accept this firmware, it's not intended for me".
The main benefit of Scout is that it gives you all flash files. But they have to be used with the appropriate phones.
What was I talking about... Ah yes, about MB855 repair.
Looks like your phone can't be repaired by regular flashing only.
You have to flash different parts of firmware. Everything is described on XDA forum.
So use the method from XDA to bring your phone to the normal life. Scout will help you to flash all those files.
Good luck
The Following User Says Thank You to mcandre For This Useful Post:
Old 04-02-2014, 19:20   #5 (permalink)
Member: 1696107
Sonork: 100.1627795
Thanks Meter: 19
please explain me for fixed failed to boot 4 in mb855...........
Old 06-21-2018, 01:05   #6 (permalink)
Member: 2591842
Sonork: 1674297
Thanks Meter: 39
where can i get the se sun fire drives, i cant find them anywhere , please share link,
many thanks in advance
Page generated in 0.16586 seconds with 9 queries
