10-31-2007, 13:40 | #1 (permalink) |
Freak Poster Join Date: Nov 2005 Location: Belo Horizonte - MG - Brazil Age: 40
Member: 199739 Status: Offline Thanks Meter: 15 | w510 flashing error Switching to flash mode... Preparing firmware image... Error getting subscriber unit information. Device API Error: 0xE0030007 Command: RQHW Flash completed with error/warning: Flash library error 32 This is the error that comes when i try to flash this phone what should i do? |
11-06-2007, 10:42 | #3 (permalink) | |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | Quote:
Of course you got the error while trying to flash, as you attempt to use lower version that the handset originally had. Downgrade of firmware will end up with the phone in boot mode. Use the same or higher versions only! P.S. @mcandre Thanks for your reply... Best Regards GSMServer team | |
11-10-2007, 06:07 | #4 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Turkey
Member: 337837 Status: Offline Thanks Meter: 538 | W510 HELLE SIR I USE SMART MOTO VERSION 2.43 THEN SMAE ERROR SmartMoto 2.43 S-Card: 44543**** Smart-Clip dongle, v 1.51, assigned Smart-Clip: 74180***** Europe, initializing... OK Clip serial: 74180********, version: 3.25, initializing... OK Searching for phone... found S Flash Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... C.50 io timeout PLZ HELP ME |
07-06-2008, 19:21 | #5 (permalink) | |
No Life Poster Join Date: Feb 2004 Location: Moon Age: 43
Member: 55717 Status: Offline Thanks Meter: 47 | Quote:
But UPLOAD at YOUR SUPPORT R452G_G_08.11.06R! Only have R452G_G_08.11.05R or lower! And 100000000000000 phones dead at moment! | |
07-07-2008, 07:32 | #6 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Central Europe Age: 39
Member: 239548 Status: Offline Thanks Meter: 2,781 | It's won't be a problem if you use higher version of flash file, for example, R452G_G_08.12.05R. And I'm almost sure that firmware version R452G_G_08.11.06R can be downgraded to R452G_G_08.11.05R |
07-19-2008, 11:23 | #7 (permalink) | |
Is R452G_G_08.11.07R (I have 2 phones damaged) BR. | |
07-21-2008, 14:16 | #8 (permalink) |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | You can find the required file at www.boot-loader.com, pcf / W510 / R452G_G_08.11.07R / Best Regards GSMServer team |
N96 Weird Flashing error | javakiller | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 14 | 10-10-2010 11:55 |
1650 flash error | nilesh_patel717 | Nokia Hardware & Hardware Repair | 3 | 03-29-2010 14:03 |
Help Smart Clip Team W510 Flashing Error | sairat | Smart-Clip | 1 | 11-10-2007 09:24 |
w510 UNLOCK ERROR | shami | Smart-Clip | 4 | 10-29-2007 08:51 |
w510 UNLOCK ERROR | shami | Smart-Clip | 2 | 10-24-2007 07:47 |
