08-06-2006, 12:38 | #1 (permalink) |
No Life Poster Join Date: Nov 2004 Location: Capetown
Member: 91045 Status: Offline Thanks Meter: 8,696 | 6230 Security Code Reset Wont Work MCU Version V05.35 MCU Compilation Date 03-02-05 Product Manufacturer GSMP1.1 Product RH-12 is compatible with this software. LOCAL mode set OTP IMEI 35623900363xxxx PPM Variant C SECURITY CODE 23985 HWID 0729 PRODUCT CODE 0513124 BASIC PRODUCT CODE 0519939 PRODUCTION S/N KWA038635 MODULE CODE 0201879 UEM 288 UPP 4178 RFIC p 10ff11ff0203 DSP p B0435T_04w46 LCD SEIKO BLUETOOTH 0380 SIMLOCK 001010 ASIC 6 Attached OK, Operation took 3 seconds Executing Post-attach procedures ================================================== ================= 1. Found product LCD Pattern settings! 2. Phone already unlocked, no need to caclculate codes 3. Auto-RPL (Flash IMEI) Backup Backing up Flash-Area RPL... OTP IMEI: 35623900363xxxx RPL Read OK 35623900363xxxx_Flash_Area_IMEI.rpl Written OK! 4. MCUSW CRC Backup Phone does not have MCUSW CRC Checking Procedure! ================================================== ================= Post-attach procedures done Setting Full Factory Defaults TEST mode set Set Factory_2 Failed, FI_2_FF_8 Setting Full Factory Defaults TEST mode set Set Factory_2 Failed, FI_2_FF_8 FLASH IMEI.... OK UEM.............. OK Security Code Shown is Also Worng not work on Phoen when Enter Manually.....Whats Wrong HERE |
08-07-2006, 08:21 | #2 (permalink) | |
No Life Poster Join Date: Feb 2005 Location: Poland Age: 34
Member: 117496 Status: Offline Sonork: 100.83919 Thanks Meter: 22,689 | Quote:
Also i will try to get such phone again to correct bugs | |
Finally!!! Nokia 1100_rh-18 Security Code Reset That Works!!!!!!!!!!!! | DVDKING | Nokia Digital Core Technology 4 ( DCT-4 ) | 22 | 06-08-2013 15:49 |
6230 security code ? | imran_k | Nokia Digital Core Technology 4 ( DCT-4 ) | 2 | 01-11-2005 18:50 |
6230 Security Code problem | N/East Unlocker | Griffin | 3 | 09-14-2004 15:39 |
Siemens S55 security code reset. I need the master code. | -=LTi=- | Phone Unlocking Codes & Maps | 0 | 04-16-2004 09:24 |
