11-30-2008, 08:13 | #4 (permalink) |
No Life Poster Join Date: Jul 2005 Location: player /-GSM-\ Field
Member: 161115 Status: Offline Sonork: Here you can find it... Thanks Meter: 3,039 | Downloads Multi-Box Support Sections. LGMDP_H3G_SC.exe LG_USB_Modem_Driver U310-CODE-TRINITYR-V10a-OCT-12-2006-H3G-LATIN_OFF_SEC.BIN U310-MEDIA-V10a-OCT-12-2006-H3G-IT_OFF.bin U310-MODULE-V10a-OCT-12-2006-H3G-LATIN_OFF_SEC.bin instructions......... - get these 3 files: - U310-CODE-TRINITYR-V10a-OCT-12-2006-H3G-LATIN_OFF_SEC.BIN - U310-MEDIA-V10a-OCT-12-2006-H3G-IT_OFF.bin - U310-MODULE-V10a-OCT-12-2006-H3G-LATIN_OFF_SEC.bin - get the application: LGMDP_H3G_SC.exe - connect the USB Cable to computer - start LGMDP_H3G_SC.exe application - click "Select port" and after it recognise your phone click "Connect" - in the application select these 2 files (MEDIA & MODULE) and select EFS ERASE - click start - do not touch the phone until you see the message "Download complete" - don't unplug the USB Cable, so you still have the phone connected to computer - detach battery - put the original SIM (that came with the phone) into the phone - turn on the mobile - enter to MENU - TOOLS - UNIT CONVERTER and push the "OK" button - VERY QUICKLY (I MEAN VERYYYYYYYY QUICKLY) detach the battery, pull out the original SIM, pull in the new SIM, attach the battery and wait few seconds; This entire step must be done very quickly as I said. - now you'll see on the screen "USIM locked" but you'll see in the upper left corner that you have signal. To confirm that you have signal put someone to give you a call and you'll se that your phone is ringing. - in this moment your phone is functionaly (but the SCREEN is blocked with the message "USIM locked" |
can i unlock kp 170 with multi box plz help | asif_ae | Multi-Box | 1 | 04-13-2009 07:35 |
Lg C1500 Unlocking Is Possible With Multi Box Lite? | sairat | Multi-box LITE | 0 | 01-20-2008 18:29 |
Direct Unlocking Nokia 2310 With Multi-box | blackmatrix | Multi-Box | 5 | 12-20-2006 19:12 |
unlock kg800 ok with multi box | falak | Multi-Box | 2 | 07-11-2006 19:27 |
How to unlock Philips 655 with Multi-Box | Sakura | Multi-Box | 17 | 07-27-2005 13:46 |
