02-21-2007, 17:45 | #1 (permalink) |
Product Supporter Join Date: Dec 2004 Location: Furious Team ... GPGIndustries Age: 45
Member: 95960 Status: Offline Sonork: 100.1574721 Thanks Meter: 14,045 | My LG KG800 dead with Full flash i Donload the full flash from Support now the phone is dead Please advice |
02-22-2007, 15:19 | #5 (permalink) |
Member: 95960 Status: Offline Sonork: 100.1574721 Thanks Meter: 14,045 | Both original flash from Support (Arabic version) And Full flash also , both same same Result Battary should be FUll during flash ???? RGDS |
02-22-2007, 15:58 | #9 (permalink) |
Member: 95960 Status: Offline Sonork: 100.1574721 Thanks Meter: 14,045 | need calbration or not sir ..... Is it same to flash with MOT or BIF ..... i am already using last LG tool Last edited by Fast Unlocker; 02-22-2007 at 16:09. |
02-22-2007, 16:38 | #10 (permalink) | |
No Life Poster Join Date: Mar 2001 Age: 43
Member: 3610 Status: Offline Sonork: 100.54638 Thanks Meter: 1,652 | Quote:
1. Take the Multi-box and connect it to USB-port of PC using the USB cable. 2. Start the LG2G tool of the latest version. One socket will began blinking at the same moment - this must be one called "UNI". 3. Go to bookmark "settings" - and select correct com port. In my case multi-box port is 3 ( do not change it ), phone com port is 6. ( is very important to select correct phone com port - in other case you will get always error in connection ) 4. Go back to main bookmark and select correct phone model and working speed. 5. Connect your phone to cable and then plug the cable to blinking socket "UNi" ( phone must be off ). Press "connect" botton and then press the botton +vcc 5V on box. You will see readed info from your phone: IMEI, phone version and model. ( sometimes software don't show you version and model - don't worry - you can continue your work ) If you get error: ERROR - Phone don't answer RF - that mean that selected working speed is not good for this model - try to select slower speed. 5. Select flash files 1 and 2. First flash file is codedata, second - AlchemyData. 6. Press "write flash" botton. Flashing progress starts. Now you can take a cup of tea. 7. DONE Press "disconnect" botton on software. Disconect the phone from box, cable. Reconect the battery and swith on the phone. Phone working - firmware changed! | |
02-22-2007, 16:49 | #11 (permalink) | |
No Life Poster Join Date: Jun 2002 Location: City
Member: 12663 Status: Offline Thanks Meter: 78 | Quote:
with original flash! U have now flash calibration data, and phone will be OK. P.S Dont forget to rebuild IMEI afther that !!! | |
02-22-2007, 17:07 | #12 (permalink) | |
Member: 95960 Status: Offline Sonork: 100.1574721 Thanks Meter: 14,045 | Quote:
in the middle of flash one is this is the speed also RGDS | |
Vodafone 332 FM unsuported. Link with full flash | stargsm_ro | FuriousGold | 1 | 03-29-2010 19:54 |
LG u8180 Dead after Full Flashing. Plz Help!! | citifone | LG | 12 | 11-06-2008 12:44 |
LG KG800 dead, please help | ab1009 | HWK | 6 | 10-02-2008 01:02 |
lg kg800 dead after flash | chiepsy man | FuriousGold | 15 | 11-17-2007 17:05 |
LG kg800 dead | medo2004 | HWK | 3 | 07-11-2007 17:41 |
