02-22-2007, 10:23 | #1 (permalink) |
No Life Poster Join Date: Feb 2005 Location: Poland Age: 34
Member: 117496 Status: Offline Sonork: 100.83919 Thanks Meter: 22,689 | New Nokia Tools v2.0O, DCT4Plus solved. New Nokia Tools DCT4/WD2 is ready Release highlights 1. DCT4Plus direct unlocking, relocking, autolocking (IMSI level) (1112, 2310) ready. 2. Totally rebuilt PP editor. New is more flexible, and supports up to 1024 descriptors Old was supporting only 64 of them. 3. "Reset Wallet" function added 4. BB5 Downgrade - thx for Dejan solution - this rewrites certificates, so it allow writing older firmware. 5. New feature: IRDA Test 6. New feature: MMC Card tests 7. New feature: Sleep mode test [1..4095 ms] 8. Totally rebuilt *#war0anty# procedures, now its splitted onto '3' types: Standard (3100, 6100, 3510i, and older) UPP 2xxx (6230i, 5140i, 6020, 6070) UPP 3xxx (2310, 1112, 2610, 2626) 9. ASIC11 better handling: fixed direct Contrast problem (now all works smoothly), and also, as far as You know DCT4Plus and ASIC11 phones have locked some PM fields-so is not possible to rewrite them. Until now it wasnt possible to write Warranty block on those phones ("Update not accepted"). KS v3.0O is able to rewrite warranty block on those phones (no solution for IMEI yet) without bigger problems 10. "Phone Usage State" handling is also splitted in 3 "types", also it supports new "Exchange" PUS. 11. Bluetooth CRC Repair added 12. New backup items: MMC Card Settings (passwords), Calendar Settings, Radio Stations, BB5 Certificate 13. "Buzzer Output" gain write function Use _with_caution! 14. Now, after low-level LCD write its restarting phone to see the diffrence 15. FM Radio tests almost ready-for now just "Initialize" released 16. FileSystem formatting. This solves some TIKUs problems (FS is avaiable on TIKU phones: 6230i, 8800, 8800Sirocco, 7280, etc-also on some newer ASIC2 there is FS-5140i i.e.). Also WD2 formatting is moved here (Symbian EPOC Platform). You can format phone hard drives. Note: use with caution! Formatting C:\ disk will cause phone dead( of couse after reflashing all will work OK). Small tutorial is here: http://www.karwosgsm.pl/fs_format_dct4_tiku.exe 17. New products compatible: NHL-4, NHL-4JX, RH-93, RH-86, RM-104 18. New PPUs, Rebuild Definitions, ADC/LCD DisplayTest handlers included 19. As always-many small changes (as a GUI, engine rebuilt) introduced 20. STOP button added Some tutorial regarding FS formatting: http://www.karwosgsm.pl/fs_format_dct4_tiku.exe Download software here: http://www.karwosgsm.pl/nokia_tools_v20_o.rar BR Full Changelog: v3.0o ================================= - New keys added to keyboard test (0x0A and 0x0B - volume up/volume down) - New feature: IRDA subsystem testing - Revised & Released: Sleep mode tests - now possible to make [ms] delay then reset/shutdown phone - New Feature: auto changes-apply after low-level contrast write - Phone Usage State now can switch phone to 3 diffrent phone modes: DEFECTIVE (contact service in result), EXCHANGE (new, used in authorized services), NORMAL - New Feature: Tuning output level of buzzer volume [0..15], usefull in "quiet-buzzer" phones, use with caution. - Fixed: Program hangsup if no SmartCard driver installed and interface is UFSx, and Auth-Type is KAc (not card) - New feature: MMC Cards Testing - New feature: FM Radio Testing - note you need HDS-3 in order to initialize Radio (And of course phone must support it), it was unfinished so for now only "Initialize" avaiable :-) - Redesigned: GUI (previous was.. too small) - New compatible products: NHL-4, NHL-4JX, RH-93, RH-86, RM-104 - Corrected PP editing on RH_64 - Checking UPP for UFSx Ready :-) - DCT4Plus phones unlock solution is ready, tested, and prooved to work - DCT4Plus Autolock IMSI implemented - DCT4Plus Relock implemented - Fixed "Access Violation" on some Configurations while reciving Frames - BB5 Downgrade function added - just for testing - Increased WD2 Bootup time - Increased WD2 Stability in BBSelftests by increasing Execution Timeout - BT Repair Added - Improved phone attaching procedure for UFSx - Improved UFSx Bootloader handler (now all going much faster) - Product Profile Editor upgraded to 2.0 - now its TOTALLY rebuilt ! supports up to 512 descriptors - Runtime Error 216 and other bugs - solved - Attach phone procedure revised, now its asking whether new phone was connected or You just simply re-attaching old phone - ASIC11 Warranty Editing Introduced (note this is not same as 2310,1600,1112-they are STILL ASICs2!) - Realtime Contrast Tuning fixed for 2610 and such phones - ASIC11-Only Production Data Writing support - ASIC11 support for Phone-Usage state changing - Filesystem format introduced ! supported FS: FILE2, Symbian EPOC - Format user area for WD2 moved to FS Tab - Disabled calcualting Unlock codes for ASIC11 (since some guys entered calcualted BAD codes!) - Improved platform selecting algorithm (DCT4/WD2) now it detects automatically all WD2 phones and auto-selecting - "Repowering".. loop-bug fixed - Fixed : "/*" is not valid integer value - Stop button added ;-) This totally "cut-out" FBUS transmission when needed. - Warranty Recover for some ASIC6-like phones - 5140i corrected ("Update not accepted") - Now there is 3 types of "Warranty" Handling * Standard (for UPPs 0xxx, 1xxx) * Fixed - UPP 2xxx (Field-Switch Nokia Trick) - solved (6230, 6230i, 5140i, 6020, etc) * Fixed - UPP 3xxx - Nokia PM Fields protection - solution still exists But: NO IMEI write, Just made/repair/purchased dates, and NO recovery support - Fixed problem for UPPs 3xxx and 2xxx, when after Attach no IMEI presents in "*#war0anty#" tab - New Backup items: Radio Stations, MMC Card Settings (Passwords), Calendar Settings - FBUS routines totally rebuilt - application is now much smoothly - PPUs updated - Rebuild definitions updated - And as always many small bugfixes/changes... prepare for NEXT cool UPDATES! |
The Following 5 Users Say Thank You to karwos For This Useful Post: |
02-22-2007, 12:34 | #12 (permalink) |
No Life Poster Join Date: Nov 2002 Age: 43
Member: 17689 Status: Offline Sonork: 100.72392 Thanks Meter: 737 | @karwos 4. BB5 Downgrade - thx for Dejan solution - this rewrites certificates, so it allow writing older firmware. By this feature can we reset the unlocking counters? |
02-22-2007, 13:57 | #15 (permalink) | |
Member: 117496 Status: Offline Sonork: 100.83919 Thanks Meter: 22,689 | Quote:
With multi-box you can only just "Trick" certificate, and flash you must with any 3rd party FBUS flasher Note that after rewritting certificate, phone needs to be flashed before 1st restart Credits goes to D.K. | |
TestBox2 LG 3G New Security Tool v2.0 | TestBox2 | Service Products News & Updates | 0 | 10-03-2009 08:52 |
24-02-2007 More power with new updates. New Nokia Tool and new files for new Alcatel! | GSMtricks | Multi-Box | 11 | 02-27-2007 07:05 |
21-08-2006! New UPDATE. NEW Nokia Tool v.3.0i BEST testing tool for Nokia! | GSMtricks | Multi-Box | 1 | 08-21-2006 12:37 |
