Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Multi-Box TEAM Products > Multi-Box
Old 07-06-2005, 20:03   #1 (permalink)
Aamir_Zia's Avatar
Member: 47321
Sonork: 100.54032
Thanks Meter: 497
Problem in Connecting Philips 355
how can i unlock 355 with MultiBox
I am trying with T191 Cable .
Can i Unlock this Phone using TAT Mode ????
At last i have to unlock the phone using Redbox .
Why too many Problems in Multi-BOX
Regards
Aamir Zia
Old 07-06-2005, 21:39   #2 (permalink)
Windziarz's Avatar
Member: 18406
Thanks Meter: 84
You have to disasamble phone and follow testpoints from support. Also cable for 355 should be in your cable set from MB
B.R.
Windziarz
Old 07-08-2005, 10:29   #3 (permalink)
Aamir_Zia's Avatar
Member: 47321
Sonork: 100.54032
Thanks Meter: 497
ok
i know that
Its means that we can't even Unlock 355 via TAT MODE
Its a Shame
Old 07-08-2005, 14:14   #4 (permalink)
Aamir_Zia's Avatar
Member: 47321
Sonork: 100.54032
Thanks Meter: 497
New Bad News
Phone Don't even Connecting using TP Adapters ...
Still timeout
on other hand Redbox Connect & Flash it 100%
what the ****
Old 07-08-2005, 14:29   #5 (permalink)
GSMtricks's Avatar
Member: 3610
Sonork: 100.54638
Thanks Meter: 1,652
Wich adapters? We dont have any adapters in set. You have to use cable from Multi-box set and use test point. That all. Tat mode is not relised yet, but... will be leter.
Old 07-08-2005, 20:09   #6 (permalink)
Aamir_Zia's Avatar
Member: 47321
Sonork: 100.54032
Thanks Meter: 497
I recieved the TP Cable for (350 & 355 ) in which we have to open the Phone
Rite ?
But The Phone still not connecting
I am Pluging the Cable in UNIUSB Socet
On Other Hand Phone connects with Com1 using Redbox .
I want to Flash phone using Multi-box but the phone is still not connecting
WHY ??
Old 07-18-2005, 11:56   #7 (permalink)
GSMtricks's Avatar
Member: 3610
Sonork: 100.54638
Thanks Meter: 1,652
Try to use test point. Picture is in support area.
Old 07-18-2005, 20:45   #8 (permalink)
Windziarz's Avatar
Member: 18406
Thanks Meter: 84
Rite ?
WHY ??
I think your cable is faulty Just like mine I'm using my old Delok Philips 355 cable thru my own converter works like charm
Old 07-19-2005, 08:39   #9 (permalink)
GSMtricks's Avatar
Member: 3610
Sonork: 100.54638
Thanks Meter: 1,652
Yes check please with picture from support area.
Old 08-09-2005, 20:15   #10 (permalink)
mrfixit's Avatar
Member: 60899
Thanks Meter: 792
please post picture, thank you
Old 08-10-2005, 07:25   #11 (permalink)
Member: 76522
Thanks Meter: 30
its bulls...t i also have recieve tp adapter its not working. i made tespoint cable use 1.5k resistor but still no conectition! just timeout! on 330 it sea phone but it cant read flash id. i think its fake soft. on 535 soft work fine! buy the way can u add optition 2 use external cable?
Old 08-10-2005, 09:42   #12 (permalink)
GSMtricks's Avatar
Member: 3610
Sonork: 100.54638
Thanks Meter: 1,652
All pictures are in support area.
Old 08-10-2005, 13:33   #13 (permalink)
Member: 76522
Thanks Meter: 30
man if the same cable work whis redbox and do not worl whis multibox and work whis old delock dongle so what kind of pictures i must 2 use may be i need golden wires 4 multibox? )
Old 08-10-2005, 15:06   #14 (permalink)
GSMtricks's Avatar
Member: 3610
Sonork: 100.54638
Thanks Meter: 1,652
The pins is on support area. I dont know what kind of cable use others divices. The better way is checking. No need to told all times about others devices.
Old 08-11-2005, 13:40   #15 (permalink)
ReyTech's Avatar
Member: 135945
Thanks Meter: 85
Do u know anyother english word other then "Check pinout in support area" or pls read FAQ in support area? coz technically this all u know! GREAT SUPPORT!
@Windziarz
M8! wht converter are u talking about? can u pls share it with us?
WBR
ReyTech.
need to know the correct e207 pinouts as problems in connecting! ReyTech Infinity-Box 3 05-29-2008 15:41
problem in connecting ust pro with computer masterspargo UST Pro II 1 12-06-2007 10:30
6288 problem in connectivity waleedy Nokia Base Band 5 ( BB-5 ) 3 02-15-2007 03:31
unable to connect Philips 355 MindPower Multi-Box 1 12-14-2006 12:36
Page generated in 0.20580 seconds with 9 queries
