Sf65 Dead Flashed with bootstrap but SAME Hi I have One SF65 dead i did flashed with Boot Strap using these flash files SF65_002C_0x0234000417040000_LG1.pfw SF65_002C_0x0234000417040000_LG1.cus SF65_002C_0x0234000417040000_LG1.plp All went ok.. now when power on phone it shows siemens logo and goes Off Did flashed 2 times...any help ? |
Yes, but flex? Eeprom? Default settings? |
Thankx for answer I ticked Flex phone after Update About EEPROM i dont have can u kindly provide me (my Multibox Support Expired) I did flex manually as well all parts with Default value... Still same... |
HI, yes sir i have did the same as been told in that article and still same phone power on and off again |
CuS and EEPROM is on Same TAB... i selected EEPROM button as well While CUS only loaded is that gona help ? Kindly upload me EEPROM plz..if possible |
Hi, I revived My Phone....Thankx for your Help But Personally Saying none of Your Steps were usefull in that Question of Mine...I saw Your Most of Post suggesting only that Read manual this and that...Do u think am a NEW Bie? You Really need to Check and Find out whats wrong in Your SW for SF65 U suggested me EEPROM (which is not needed in this case) and i asked u kindly can u uploaded ...U Ignored this MSG Thankx again ... Next time Kindly do not suggest something Which u dont even know what r u Talking about... Hopeless |
Your Steps or Manual Has notthing todo with This Problem.. EEPROM and CP r Samething Either u select it or NOt.. About manual i said i have Followed and Done but no Vain....Its exactly same as ive been Doing Before Again Just Letting u Know Flashing manual has not a Single Hint for Solving this problem...User will only keep flashing again and again with Changed Flash Files but will not succeed... Whats the Solution... Same Phone (powered on and off Showing siemens logo)...Connect it in TAT Mode Option Normal Cable SF65 and in Special SOcket of Multibox (uni will not work for this trick)....After COnnection is Done make Default Values and Thats it phone will be Revived... Main point here is All manual and u suggested is to execute in Bootstrap Mode...but only in TAT mode executing Default value Option will Revive your Phone...Thankx for Your Time...and i hope this Helps for All Users with such Problem in Future.! Br, |
