12-25-2007, 11:52 | #1 (permalink) |
No Life Poster Join Date: Apr 2001 Location: IN CASTLE Age: 46
Member: 3925 Status: Offline Thanks Meter: 22 | multi-box lite can repair gd35 boot jtag? i have multi-box lite. can repar gd35 boot jtag ???? any one have lite box pin out ???? i'm connect jtag using old multi box schematic. but for me not working and wich version of soft is good working in lite box.......... help me need repair boot for gd35. tell me step by step thanks a lot |
12-25-2007, 14:24 | #4 (permalink) |
No Life Poster Join Date: Mar 2001 Age: 44
Member: 3610 Status: Offline Sonork: 100.54638 Thanks Meter: 1,652 | How to restore Panasonic with dead boot? 1. 1. Run the software MultiJtag Tool. And check please your box activation status. Your box must have 6 activations like in a picture. If you dont have "- SND / JTAG ST" activation - you need to update the activations - press "box update" button and it will be activated in 2 sec ( internet connection must be on ). Check also box firmware version - must be: Box FW version: 1.0.10 FW If you dont have version 1.0.10 - you must update your box!!!! 2. Connect the JTAG cable to phone. Use for this please picture from support area. All 8 wires must be soldered to phone PCB. Be cearfull please!!! If you have incorrectly soldered - you can damage CPU. 3. Connect this cable to box ( you need to use socket "JTAG" on box ). 4. Select you phone model from models list. 5. So very important to make a back up - even if your phone is dead ( eeprom zone is better to save ). Then press power botton and hold ( ~ 1-2 sec ) and in that time press the botton "check connection". If all is good ( correct connecting via cable ) you will see info ( like here ): then press "read flash backup" botton and wait a little. Save your backup. 6. Now we are ready for restoring. Please reconect your phone from the box ( unplug from JTAG socket ). Then select boot file for your model. Press shotly and hold power botton on your phone and then press "check connection" botton. You must see agine readed info. Press "Write flash" botton - the process will start: 7. So boot is restored. Now you can use any free software for flashing. ( WinModo for example ) 8. If you have Panasonic GD93 ( like I have for this example ) - you can make clone phone. For this you need agine make all steps from 6 but with selecting full flash file ( not boot file ). Flash your phone with this file and - your phone now ALIVE. DONE. All is clear and you phone has a new life ;-) Related ArticlesThere's no articles Comments Add CommentThe first who released such repair tool...waiting for GD87 and all new phone which need JTAG interface (even old...it's so funny).Keep it up,wish you the best future. |
12-25-2007, 16:12 | #5 (permalink) |
Member: 3925 Status: Offline Thanks Meter: 22 | i'm read this manual i'm only ask old multi box jtag pin out same with lite multi-box jtag pin out ???? i'm use old pic for jtag pin out. but for me not working tell me thanks a lot |
12-25-2007, 19:19 | #7 (permalink) |
Member: 3925 Status: Offline Thanks Meter: 22 | thank you for reply mail i'm use multijtagtool v1.7. and my box activated in jtag tool ??? please look my box info Name: siemens man Country: EMail: jan Phone/ICQ: 378826543 Date: 11092007 Box status: OK Activated services: - Henrich Pack - Multibox Lite Box not connected! |
12-26-2007, 08:56 | #8 (permalink) | |
Member: 3610 Status: Offline Sonork: 100.54638 Thanks Meter: 1,652 | Quote:
12-26-2007, 15:36 | #9 (permalink) |
Member: 3925 Status: Offline Thanks Meter: 22 | why i can't connect my phone to soft. i'm connect all pin out same with old pic. +5 volt need turn on ? special mode need turn on ??? pleaSE help me thanks a lot |
12-26-2007, 16:02 | #11 (permalink) |
Member: 3925 Status: Offline Thanks Meter: 22 | yes i'm connect to all 8 pin. and connect to jtag soccet.. push power of phone and push connect button in soft no result. not detected my phone............... wich battery? phone or external ??? |
12-26-2007, 18:34 | #15 (permalink) |
Member: 3925 Status: Offline Thanks Meter: 22 | very strange.............. why for me not working ?????? i'm trying many times no result............... now i'm push check connection allways freezing my soft ..................... how it working.............. |
How does PadFinder work with Multi-Box and Multi-Box LITE? Do I need activation? | Multi-box TEAM | PadFinder box | 35 | 09-18-2008 10:02 |
Hello Multi-box team.. im a New user of Multi-box Lite. | dawgweed | Multi-box LITE | 1 | 12-23-2007 17:58 |
Multi-box & Multi-box lite differences? | Mantikor | Multi-box LITE | 10 | 09-14-2007 19:32 |
Confused Which To Buy-multi-box Or Multi-box Lite? | jamohaki | Multi-Box | 0 | 08-31-2007 20:08 |
What is the differents between Multi-box and Multi-box LITE? | GSMtricks | Multi-Box | 0 | 08-29-2007 11:38 |
