Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Multi-Box TEAM Products > Multi-box LITE
Old 02-06-2009, 17:25   #1 (permalink)
Member: 950315
multi box lite nokia
hallo freind and sorry for this english
i am new youser of this power full box i have bout all activation code all work fine eccept nokia module cous cant atach phone with f bus in spetial socket
i need your help for this but with usb all work fine tanks in advence
Old 02-06-2009, 17:52   #2 (permalink)
GSMtricks's Avatar
Member: 3610
Sonork: 100.54638
F-bus? What exactly not working for you?
Old 02-06-2009, 18:17   #3 (permalink)
Member: 950315
sir i cant do any think with f-bus cant attach fone her is the log
Phone not found
1. Check whether phone is in LOCAL MODE/Powered on
2. Check whether MultiBox is in Nokia mode
3. Check whether cable is plugged into Special socket
4. Check whether cable is ok
5. Check the USB Cable length (should not exceed 0,5 meters!)
6. Check whether MultiBox is plugged into Mainboard directly (not any hubs, or front of PC Case)
7. Check and clean if needed phone socket pads
8. If you are trying to connect to NMP Symbian based phone, wait until phone boot-up
i used ufs cable if wrong wath cable should i use thanks
Old 02-07-2009, 13:38   #4 (permalink)
Member: 950315
is there any answor please all modoul activated
Box status: OK
Activated services:
- Henrich Pack
- Karwos Pack
- Multibox Lite
i cant work with dct4 or dct4+ please help
best reagard
thankyou
Old 02-07-2009, 16:06   #5 (permalink)
GSMtricks's Avatar
Member: 3610
Sonork: 100.54638
Box status: OK
Activated services:
- Henrich Pack
- Karwos Pack
- Multibox Lite
best reagard
thankyou
Yes you must use USB cable man
The Following User Says Thank You to GSMtricks For This Useful Post:
Old 02-08-2009, 13:15   #6 (permalink)
Member: 950315
thank you dear master for this usefull info tahnks again
best reagard
Old 02-14-2009, 21:04   #7 (permalink)
Member: 207455
can you come out straight pls which usb cable do one use for DCT4+?
How does PadFinder work with Multi-Box and Multi-Box LITE? Do I need activation? Multi-box TEAM PadFinder box 35 09-18-2008 10:02
Hello Multi-box team.. im a New user of Multi-box Lite. dawgweed Multi-box LITE 1 12-23-2007 16:58
Multi-box & Multi-box lite differences? Mantikor Multi-box LITE 10 09-14-2007 19:32
Confused Which To Buy-multi-box Or Multi-box Lite? jamohaki Multi-Box 0 08-31-2007 20:08
What is the differents between Multi-box and Multi-box LITE? GSMtricks Multi-Box 0 08-29-2007 11:38
Page generated in 0.26015 seconds with 11 queries
