Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > J.A.F - Just Another Flasher > J.A.F. By Jafsupport.com
Old 02-13-2011, 00:06   #1 (permalink)
Member: 643649
6080b RM-167 IMEI Signal Succesfully
IMEI 6080b RM-167 FCC ID: PPIRM-167
1. Flash With Version 6070 RM-166 v4.22
2. Do unlock
3. Make imei patch ip2
4. Factory settings
5. Full Signal
Firmware
http://www.freeflashfile.com/flashfiles/nokia/dct-4/6070.RM-166/04.22/6070%2004.22(www.freeflashfile.com).rar
LOG JAF 1.98.62 - PKEY Emulator v5
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Phone Type:
MCU Flash file: C:\Documents and Settings\Administrador\Escritorio\6070 04.22(www.freeflashfile.com)\rm166__04.220
Phone Type:
PPM Flash file: C:\Documents and Settings\Administrador\Escritorio\6070 04.22(www.freeflashfile.com)\rm166__04.22g
Phone Type:
CNT Flash file: C:\Documents and Settings\Administrador\Escritorio\6070 04.22(www.freeflashfile.com)\rm166__04.22.image_g
Backing up PM Field 208 as RPL...
Setting local mode...
Reading IMEI...
Reading IMEI data...
Building RPL backup file...
C:\Archivos de programa\ODEON\JAF\ProgData\449306107868960_imei_b ackup_173112.rpl
Done!
Backup imei OK!
MCU: C:\Documents and Settings\Administrador\Escritorio\6070 04.22(www.freeflashfile.com)\rm166__04.220
Booting phone...
MCU ID: 0x2142
BOOT file: C:\Archivos de programa\ODEON\JAF\Flash\u_2nd.fia
Loader version: 04.46.01 -> Revision: 0007
Boot size is 0x09A0
Boot is ready...
FLASH ID0: 22E800EC <=> SAMSUNG (SEC) -> K5G2829ATC Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0
First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14
Flash ID is 0xE822EC00
Flash loader is C:\Archivos de programa\ODEON\JAF\Flash\u_amd.fia
Loader size is 0x7518; Loader chk: 51
Loader is ready...
P-key nokia module version 01.02
MSID: 844694D912D69B3C8BD94470E1
MSID decoded: E32ABAE9008A41DBAA000000
FAID: 594B97895C0CB967533F43D4
Operation took 0 minutes 12 seconds...
Erasing...
Found 3 interval(s) to erase
Erasing area: 01000000 - 0101FFFF...
Erasing area: 01020000 - 018DFFFF...
Erasing area: 01E60000 - 01FDFFFF...
Operation took 1 minutes 43 seconds...
Writing...
Perm. Data Restore OK
Operation took 0 minutes 57 seconds...
Restarting MCU...
CNT: C:\Documents and Settings\Administrador\Escritorio\6070 04.22(www.freeflashfile.com)\rm166__04.22.image_g
Booting phone...
MCU ID: 0x2142
Boot size is 0x09A0
Boot is ready...
Loader is ready...
MSID: 84848B2EDBD2669DF1C25C592F
MSID decoded: 1C15BAE3008A41DBAD0005BD
FAID: 1DCFA4D10DCC59C54AEA3343
Erasing Content Pack...
Found 1 interval(s) to erase
Erasing area: 01B20000 - 01E5FFFF...
Operation took 0 minutes 30 seconds...
Writing...
Operation took 0 minutes 10 seconds...
Restarting MCU...
Operation took 0 minutes 0 seconds...
Extracting Content Pack...
Running: (c) Nokia File Server
CNT Extract Skiped.
Operation took 0 minutes 3 seconds...
PPM: C:\Documents and Settings\Administrador\Escritorio\6070 04.22(www.freeflashfile.com)\rm166__04.22g
Booting phone...
MCU ID: 0x2142
Boot size is 0x09A0
Boot is ready...
Loader size is 0x7518; Loader chk: b1
Loader is ready...
MSID: 8426393AD858056B00183F0A9E
MSID decoded: 3E4EBAE9008A41DBA9000000
FAID: 21041C5A31B7392800073C1C
Operation took 0 minutes 11 seconds...
Erasing PPM...
Erasing area: 018E0000 - 01B1FFFF...
Operation took 0 minutes 23 seconds...
Writing...
Restarting MCU...
Flashing Done!
Operation took 4 minutes 44 seconds...
After flash processing...
Waiting for phone to boot...
Reading...
Phone type: RM-166, Software version: 04.22
IMEI: ???????????????
Product Code: 0533305
Resetting PPC...
Setting FULL FACTORY......Setting test mode...
Operation took 0 minutes 6 seconds...
Done!
Done!
Powering the phone...
Unlocking...
ASIC: 2
SW version: 04.22
Phone is not in LOCAL MODE or TEST MODE, or imei is damaged...
Failed! Aborting!
Done!
Switching to serial...
Reading...
MCU SW version: V 04.22
24-05-07
RM-166
(c) Nokia.
HW version: 4051
PCI version:
UEM version: 416
UPP version: 8514
RFIC version: 0205
DSP version: P05w06.v40
LCD version: SUEZ
PPM version: V 04.22
24-05-07
RM-166
(c) Nokia.
G
Production serial number: XE0126127
Product code: 0533305
Module code: 0202972
Basic production code: 0531002
Flash code:
Order number:
Product specific data:
Long production SN:
ATO: x????????????????????????????????????????????????
Default SN type: x????????????????????????????????????????????????
IMEI plain: ???????????????
IMEI spare to net: FA FF FF FF FF FF FF 0F
IMEI SV to net: F3 FF FF FF FF FF FF 0F F8
Master Code: 5013663745
Phone type: RM-166, Software version: 04.22, Language Pack: G
User code: 12345
Searching for default location of ini...
Checking path: C:\Archivos de programa\Archivos comunes\Nokia\DataPackage\Products\\
Searching for JAF saved location of ini...
Checking path: C:\Archivos de programa\Nokia\Phoenix\Products\\
No ini files found...
Done!
Unlocking...
ASIC: 2
SW version: 04.22
Failed! Aborting!
Connecting to phone...
Imei need to be 14 digits in length...
Unlocking...
SW version: 04.22
Selected flash file: C:\Documents and Settings\Administrador\Escritorio\6070 04.22(www.freeflashfile.com)\rm166__04.220
Decrypting flash...Done
Checking ROM call...Done
Checking imei security function...Done
Encrypting....Done
Patch status: 00
MCU ID: 0x2142
Boot size is 0x09A0
Boot is ready...
Loader is ready...
Erasing area: 010C0000 - 010DFFFF...
Unlocking...
Checking locks...
Block 1:
Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Failed! Aborting!
Done!
what prog changes imei on 6110 and how do i do it? Ravetrancer Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 07-31-2012 20:09
Nokia 51xx/61xx imei changer ver. 1.10?????? Ravetrancer Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 8 04-06-2012 16:22
6110 imei changer !!!!!! Ravetrancer Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 5 11-21-2011 00:44
Working IMEI changed phone? Barjo Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 10-08-1999 14:22
Imei Arnis Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 09-15-1999 02:38
Page generated in 0.31550 seconds with 11 queries
