07-14-2009, 10:39 | #1 (permalink) |
No Life Poster Join Date: Sep 2007 Location: PAKISTAN
Member: 585807 Status: Offline Thanks Meter: 781 | 6234 rm123 flashing error MCU ID: 0x0082 FLASH ID0: 367E0001 <=> SPANSION -> Type not in database Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 0 FLASH ID1: 267E0001 <=> SPANSION -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 FLASH ID2: 267E0001 <=> SPANSION -> Type not in database Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 0 FLASH ID3: 267E0001 <=> SPANSION -> Type not in database Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0 First 16 bytes: C6 00 00 EA 75 01 00 EA 78 01 00 EA 7B 01 00 EA Checking RAM for ALGO... Can't find flash loader for this phone...Aborting! Changing flashing settings... FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\NHL-10\NHL105530.C1 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\NHL-10\NHL105530.96 CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE MCU: C:\Program Files\Nokia\Phoenix\Products\NHL-10\NHL105530.C1 Booting phone... MCU ID: 0x0082 BOOT file: C:\Program Files\ODEON\JAF\Flash\w2_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x1058 Boot is ready... FLASH ID0: 267E0001 <=> SPANSION -> Type not in database Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: 267E0001 <=> SPANSION -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 10 FLASH ID2: 267E0001 <=> SPANSION -> Type not in database Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 10 FLASH ID3: 267E0001 <=> SPANSION -> Type not in database Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 10 First 16 bytes: C6 00 00 EA 75 01 00 EA 78 01 00 EA 7B 01 00 EA Flash ID is 0x267E0001 Flash loader is C:\Program Files\ODEON\JAF\Flash\w2_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x7168; Loader chk: b6 Loader is ready... P-key nokia module version 01.02 MSID: 84DAB8267A8EF562A84757CE44 MSID decoded: 3E4EBAF7009A14C6A9000000 FAID: 39F01DDD7B7DF5178B1D084D Flash loader is C:\Program Files\ODEON\JAF\Flash\w3_cbusb.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x2020; Loader chk: 7f Additional Loader is ready... Operation took 0 minutes 27 seconds... Erasing... Found 5 interval(s) to erase Erasing area: 00000000 - 0000FFFF... Erasing area: 00010000 - 007FFFFF... Erasing area: 04000000 - 046FFFFF... Erasing area: 06000000 - 066FFFFF... Erasing area: 047C0000 - 047EFFFF... Operation took 2 minutes 57 seconds... Writing... MCM Register OK Perm. Data Restore OK Operation took 3 minutes 13 seconds... Restarting MCU... PPM: C:\Program Files\Nokia\Phoenix\Products\NHL-10\NHL105530.96 Booting phone... MCU ID: 0x0082 BOOT file: C:\Program Files\ODEON\JAF\Flash\w2_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x1058 Boot is ready... FLASH ID0: 267E0001 <=> SPANSION -> Type not in database Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: 267E0001 <=> SPANSION -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 10 FLASH ID2: 267E0001 <=> SPANSION -> Type not in database Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 10 FLASH ID3: 267E0001 <=> SPANSION -> Type not in database Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 10 First 16 bytes: C6 00 00 EA 75 01 00 EA 78 01 00 EA 7B 01 00 EA Flash ID is 0x267E0001 Flash loader is C:\Program Files\ODEON\JAF\Flash\w2_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x7168; Loader chk: b6 Loader is ready... P-key nokia module version 01.02 MSID: 84D89585362E9CFCA1D55AD7D1 MSID decoded: 3E4EBAF7009A14C6A8000000 FAID: 17DE03FD9B6C521EC7ECA14E Operation took 0 minutes 19 seconds... Erasing PPM... Found 2 interval(s) to erase Erasing area: 00000000 - 0000FFFF... Erasing area: 02000000 - 020DFFFF... Operation took 0 minutes 8 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 9 seconds... Restarting MCU... Flashing Done! Operation took 7 minutes 17 seconds... After flash processing... Waiting for phone to boot... Reading... Phone type: NHL-10, Software version: 5.53.0 IMEI: 351525002541895 Product Code: 0511172 Resetting PPC... Setting FULL FACTORY......Setting test mode... Setting FULL FACTORY... Operation took 1 minutes 12 seconds... Done! Done! Done! Changing mode...Done! Fast phone flashing selected. FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-123\ Searching for default location of ini... Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-123\ Scanning ini files... Searching for default location of ini... Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-123\ FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-123\rm123_145_30005.600.mcusw PPM Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-123\rm123_145_3005.60.ppm_cvf CNT Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-123\rm123_145_30005.60.image_cvf APE Variant file: NONE Languages in ppm: English,German,French,Italian,Dutch,Spanish,Turkis h,Portuguese Changing flashing settings... Searching for default location of ini... Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-123\ FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-123\rm123_145_30005.600.mcusw PPM Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-123\rm123_145_3005.60.ppm_gvf CNT Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-123\rm123_145_30005.60.image_gvf APE Variant file: NONE Languages in ppm: English,German,French,Spanish,Arabic Backing up CRT data... Setting FLASH MODE Loader version: 01.1E.00 -> Revision: 0000 Patching CMT boot step1... Patching CMT boot step2... Patching CMT boot step3... CMT Boot Ready Error finding cmd loader... Failed to backup CRT... Backing up SIMLOCK data... Setting local mode... Failed! Aborting! Failed to backup LCK... Manual mode selected, version can't be checked! Booting phone... CMT Boot Data: Asic ID: 000000010000022600010006010C192101003000 Asic Mode ID: 00 Asic EM ID: 00000352 Asic Public ID: 1470010FDB9F015496A6B72B80ED74B9632DAA66 HASH: BAF3A9C3DBFA8454937DB77F2B8852B100000000 ROM ID: 273F6D55DFAAF68F CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv3_2nd.fg Loader version: 01.1E.00 -> Revision: 0000 Patching CMT boot step1... Patching CMT boot step2... Patching CMT boot step3... CMT Boot Ready CMT Flash ID: 563D0037 <=> Flash ID not in database CMT Flash Data: 0300280061010D014E6F6B6961203531 Error finding cmd loader... Backing up CRT data... Setting FLASH MODE Loader version: 01.1E.00 -> Revision: 0000 Patching CMT boot step1... Patching CMT boot step2... Patching CMT boot step3... CMT Boot Ready Error finding cmd loader... Failed to backup CRT... Backing up SIMLOCK data... Setting local mode... Failed! Aborting! Failed to backup LCK... Manual mode selected, version can't be checked! Booting phone... CMT Boot Data: Asic ID: 000000010000022600010006010C192101003000 Asic Mode ID: 00 Asic EM ID: 00000352 Asic Public ID: 1470010FDB9F015496A6B72B80ED74B9632DAA66 HASH: BAF3A9C3DBFA8454937DB77F2B8852B100000000 ROM ID: 273F6D55DFAAF68F CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv3_2nd.fg Loader version: 01.1E.00 -> Revision: 0000 Patching CMT boot step1... Patching CMT boot step2... Patching CMT boot step3... CMT Boot Ready CMT Flash ID: 563D0037 <=> Flash ID not in database CMT Flash Data: 0300280061010D014E6F6B6961203531 Error finding cmd loader... please help |
07-16-2009, 18:45 | #2 (permalink) |
No Life Poster Join Date: May 1999 Location: Thailand Age: 50
Member: 125 Status: Offline Sonork: 100.100000 Thanks Meter: 1,305 | Install the nokia flash update package and hava try again... BR |
The Following 2 Users Say Thank You to jafsupport.com For This Useful Post: |
07-17-2009, 08:24 | #4 (permalink) |
Member: 585807 Status: Offline Thanks Meter: 781 | JAF version 1.98.61 Detected PKEY: ******* Card life counter: 74.06% P-key nokia module version 01.02 Detected JAF INTERFACE version: 01.B1, Driver version: 40000, Library version: 30107 JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\ JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\ JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\ JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\ USB Cable Driver version: 7.0.2.0 Changing mode...Done! Booting phone... CMT Boot Data: Asic ID: 000000010000022600010006010C192101003000 Asic Mode ID: 00 Asic EM ID: 00000352 Asic Public ID: 1470010FDB9F015496A6B72B80ED74B9632DAA66 HASH: BAF3A9C3DBFA8454937DB77F2B8852B100000000 ROM ID: 273F6D55DFAAF68F CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv3_2nd.fg Loader version: 01.1E.00 -> Revision: 0000 Patching CMT boot step1... Patching CMT boot step2... Patching CMT boot step3... CMT Boot Ready CMT Flash ID: 00000000 <=> Flash -> not detected CMT Flash Data: 00000000000000000000000000000000 CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAP3Gv3_algo.fg Loader version: 01.21.01 -> Revision: 0000 Patching CMT loader step1... Patching CMT loader step3... Error loading cmt loader... Booting phone... Error sync the phone... Booting phone... CMT Boot Data: Asic ID: 000000010000022600010006010C192101003000 Asic Mode ID: 00 Asic EM ID: 00000352 Asic Public ID: 1470010FDB9F015496A6B72B80ED74B9632DAA66 HASH: BAF3A9C3DBFA8454937DB77F2B8852B100000000 ROM ID: 273F6D55DFAAF68F CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv3_2nd.fg Loader version: 01.1E.00 -> Revision: 0000 Patching CMT boot step1... Patching CMT boot step2... Patching CMT boot step3... CMT Boot Ready CMT Flash ID: 00000000 <=> Flash -> not detected CMT Flash Data: 00000000000000000000000000000000 CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAP3Gv3_algo.fg Loader version: 09.11.00 -> Revision: 0000 Patching CMT loader step1... Patching CMT loader step3... Error loading cmt loader... |
07-20-2009, 20:01 | #7 (permalink) | |
Member: 125 Status: Offline Sonork: 100.100000 Thanks Meter: 1,305 | Quote:
BR | |
The Following User Says Thank You to jafsupport.com For This Useful Post: |
Please help for 6234 rm123 dead | mamepap | J.A.F. By Jafsupport.com | 5 | 12-15-2008 02:00 |
need good pm for 6234 rm123 | BABBU GSM | Nokia Base Band 5 ( BB-5 ) | 2 | 07-07-2007 14:32 |
need 6234 -rm123 flash | Vinod Rana | Nokia Base Band 5 ( BB-5 ) | 4 | 08-04-2006 17:02 |
