Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > J.A.F - Just Another Flasher > J.A.F. By Jafsupport.com
Old 05-26-2010, 11:08   #1 (permalink)
Member: 614026
6610i(RM-37) wrongly flash to (NHL-4U), pls help
NK 6610i(RM-37), when i use 6610(NHL-4U) files to flASH IT, CONTACT SERVICE, only can power up with the rj45 cable. the phone is now contact service when i use battery, but when i power up in rj45 cable with my ufs, the phone can boot as normal. just cant use battery, it will show contact service. i had tried to erase flash, flash it, write pm then unlock it but its still contact service when i use battery.
may i know how to solve it?
FILES SET FOR FLASHING:
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-37\rm-3704.400
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-37\rm-3704.40c
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-37\rm-3704.40.ucp_c
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Languages in ppm: English,German,French,Italian,Dutch,Spanish,Turkis h,Portuguese
Backing up PM Field 208 as RPL...
Setting local mode...
Reading IMEI...
Reading IMEI data...
Building RPL backup file...
C:\Program Files\ODEON\JAF\ProgData\353382009113890_imei_back up_180265.rpl
Done!
Backup imei OK!
MCU: C:\Program Files\Nokia\Phoenix\Products\RM-37\rm-3704.400
Booting phone...
MCU ID: 0x1120
BOOT file: C:\Program Files\ODEON\JAF\Flash\u_2nd.fia
Loader version: 04.4F.00 -> Revision: 0007
Boot size is 0x09D8
Boot is ready...
FLASH ID0: F822EC00 <=> Flash ID not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
FLASH ID1: 01000000 <=> Flash -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0
First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14
Flash ID is 0xF822EC00
Flash loader is C:\Program Files\ODEON\JAF\Flash\u_amd.fia
Loader size is 0x78C0; Loader chk: 48
Loader is ready...
P-key nokia module version 01.02
MSID: 84E51D7DA77873C073327ADC0A
MSID decoded: 82A9BAE9000AE7C1AA000000
FAID: 7DE054215A65A036374C28F7
Operation took 0 minutes 14 seconds...
Erasing...
Found 3 interval(s) to erase
Erasing area: 01000000 - 0100FFFF...
Erasing area: 01010000 - 017FFFFF...
Erasing area: 01A00000 - 01FDFFFF...
Operation took 2 minutes 43 seconds...
Writing...
Perm. Data Restore OK
Operation took 0 minutes 46 seconds...
Restarting MCU...
CNT: C:\Program Files\Nokia\Phoenix\Products\RM-37\rm-3704.40.ucp_c
Booting phone...
MCU ID: 0x1120
Boot size is 0x09D8
Boot is ready...
Loader is ready...
MSID: 84CF49BDDE440A3EF2C1BC487F
MSID decoded: 82A9BAE9000AE7C1A9000000
FAID: F10B7BF631F4A517BF7FCC3A
Operation took 0 minutes 13 seconds...
Erasing Content Pack...
Found 1 interval(s) to erase
Erasing area: 01800000 - 019FFFFF...
Operation took 0 minutes 23 seconds...
Writing...
Operation took 0 minutes 4 seconds...
Restarting MCU...
Operation took 0 minutes 1 seconds...
Extracting Content Pack...
Running: (c) Nokia File Server
CP Extract Failed!
PPM: C:\Program Files\Nokia\Phoenix\Products\RM-37\rm-3704.40c
Booting phone...
MCU ID: 0x1120
Boot size is 0x09D8
Boot is ready...
Loader is ready...
Operation took 0 minutes 12 seconds...
Erasing PPM...
Writing...
Operation took 0 minutes 11 seconds...
Restarting MCU...
Flashing Done!
Operation took 5 minutes 34 seconds...
After flash processing...
Waiting for phone to boot...
Reading...
Phone type: RM-37, Software version: 4.40
IMEI: 353382009113890
Product Code: 0516166
Resetting PPC...
Setting FULL FACTORY......Setting test mode...
Operation took 0 minutes 6 seconds...
Done!
Done!
Powering the phone...
Unlocking...
ASIC: 2
SW version: 4.40
Checking locks...
Block 1:
Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Done!
DCT4 unlock counter: 1
Done!
Old 05-26-2010, 11:13   #2 (permalink)
alfskiegsm's Avatar
Member: 1225453
Sonork: 100.1595998
This is How to Do Sir....
1.1st Write Good Pm File 6610i
2.Flash firmware NHL-4jx 7250i
3.Set Ui and Unlock
4.after finish try to put battery and On
5.Post if display COntact Service....
br.
Old 05-26-2010, 14:47   #3 (permalink)
Member: 614026
can i have 6610i good pm? last time, during write pm, it will prompt me to replace a few security areas, shud i press yes or no? also, the pm file imei must match with my phone imei or just use back the pm file's imei?
Old 05-27-2010, 15:28   #4 (permalink)
Member: 614026
Detected UFS_USB V2.8 (c) SarasSoft 2007. version: 01.B2, Driver version: 0, Library version: 0
JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\
JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\
JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\
JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\
USB Cable Driver version: 7.1.23.0
Reading product code...
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-37\
Scanning for ini files...
Changing flashing settings...
Reading...
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-37\rm-3704.40s
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-37\rm-3704.40.ucp_s
Languages in ppm: English,Chinese S,Malaysian
Reading IMEI...
C:\Program Files\ODEON\JAF\ProgData\353382009113890_imei_back up_2216275.rpl
Done!
Backup imei OK!
Booting phone...
MCU ID: 0x1120
Boot size is 0x09D8
Boot is ready...
Loader is ready...
Erasing...
Writing...
Operation took 0 minutes 57 seconds...
Restarting MCU...
CNT: C:\Program Files\Nokia\Phoenix\Products\RM-37\rm-3704.40.ucp_s
Booting phone...
MCU ID: 0x1120
Boot size is 0x09D8
Boot is ready...
Loader is ready...
Operation took 0 minutes 22 seconds...
Writing...
Operation took 0 minutes 3 seconds...
Restarting MCU...
CP Extract Failed!
PPM: C:\Program Files\Nokia\Phoenix\Products\RM-37\rm-3704.40s
Booting phone...
MCU ID: 0x1120
Boot size is 0x09D8
Boot is ready...
Loader is ready...
Erasing PPM...
Writing...
Restarting MCU...
Flashing Done!
Operation took 5 minutes 41 seconds...
Product code changed to 0516364
Reading...
Product Code: 0516364
Resetting PPC...
Done!
Done!
Unlocking...
ASIC: 2
SW version: 4.40
Checking locks...
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Done!
Done!
Now the phone cannot power on afte i flash wit 7250i files, with unlock n factory set as ui settings.
Old 05-28-2010, 10:08   #5 (permalink)
Member: 614026
now i its not even responding even i press "check" button. i think its dead?
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 8 Yesterday 19:20
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 28 08-30-2012 03:40
news headlines to gsm phone mos Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 12-18-2011 11:00
Help with 6110 paulomt1 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 05-25-2009 16:29
Page generated in 0.41921 seconds with 11 queries
