MXKEY / MXBOX v3.5 revision 1.2 MXKEY / MXBOX v3.5 revision 1.2 - MAJOR UPDATE - The only BOX with TMA included Posted by QMobile Saturday, June 25, 2011 .fullpost { display: inline; } v3.5 revision 1.2, Public-Release MAJOR UPDATE What is new: MAIN - Added, Files synchronization feature - Allows to check and update important files with server without installing full setup. - Also useful to minimize problems because of users patch. - Fixed, Access violation on XP for PC without HTI(WinUsb) installed - Check For updates and Single module update removed(replaced with Synchronize Files) NK(Nokia Service Tool) - Added, optional SX5 serial used for SL3 NCK calc (*) (*) required HTI firmware version 00.17 or later - Added, Latest flash update definition to setup - Added, Options to disable/enable RAPIDO new protocol for USB flashing - Added, Options to disable/enable embedded SBL for XGOLD flashing - Added, HTI SoftTMA Resistor selection (*) (*) required HTI firmware version 00.17 or later - Added, Local storage definition for DCC and RFBB data. - Added, DCC data verify after write - Improved, DCC data write (If DCC write fail, DATA will be written as PM) - Fixed, Download in background deadlock bug - Fixed, PM erase bug (was early stopped on newer BB5 phone) - Fixed, DCT4 flashing - Fixed, New ProductProfile write QCD(CDMA Service Tool) - updated patch definition to version 1.4 - added unlock definition for: Haier Q9+-INAV1.04-100326-JWD, method: patch unlock - added unlock definition for: ZTE SM_C36X_RBTL05NV1.0.0B05, method: direct unlock (not tested!) - fixed unlock definition for: ZTE TM_S189_RBTL35NV1.0.2B01, method: direct unlock - fixed unlock definition for: ZTE TM_S168_RBTL35NV1.0.0B02, method: direct unlock - see "modules\{9A05071F-D3A6-484B-8E3E-C6F47311C78C}\supported_phones.txt" for list supported models BB (BlackBerry Tool) - Added, Factory lock status on device scan - Minor bug fixes Download |
you post in the wrong section:p |
ARAIN sahab may be you need glasses this is a wrong section , first see then post mx key is the one who killed jaf ....? |
