Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > J.A.F - Just Another Flasher > J.A.F. By Jafsupport.com
Old 07-07-2011, 09:34   #1 (permalink)
JUNAID ARAIN's Avatar
Member: 1530955
Sonork: 100.1627356
Thanks Meter: 213
Thumbs down MXKEY / MXBOX v3.5 revision 1.2
MXKEY / MXBOX v3.5 revision 1.2 - MAJOR UPDATE - The only BOX with TMA included
Posted by QMobile Saturday, June 25, 2011 .fullpost { display: inline; }
v3.5 revision 1.2, Public-Release
MAJOR UPDATE
What is new:
MAIN
- Added, Files synchronization feature
- Allows to check and update important files with server without installing full setup.
- Also useful to minimize problems because of users patch.
- Fixed, Access violation on XP for PC without HTI(WinUsb) installed
- Check For updates and Single module update removed(replaced with Synchronize Files)
NK(Nokia Service Tool)
- Added, optional SX5 serial used for SL3 NCK calc (*)
(*) required HTI firmware version 00.17 or later
- Added, Latest flash update definition to setup
- Added, Options to disable/enable RAPIDO new protocol for USB flashing
- Added, Options to disable/enable embedded SBL for XGOLD flashing
- Added, HTI SoftTMA Resistor selection (*)
- Added, Local storage definition for DCC and RFBB data.
- Added, DCC data verify after write
- Improved, DCC data write (If DCC write fail, DATA will be written as PM)
- Fixed, Download in background deadlock bug
- Fixed, PM erase bug (was early stopped on newer BB5 phone)
- Fixed, DCT4 flashing
- Fixed, New ProductProfile write
QCD(CDMA Service Tool)
- updated patch definition to version 1.4
- added unlock definition for: Haier Q9+-INAV1.04-100326-JWD, method: patch unlock
- added unlock definition for: ZTE SM_C36X_RBTL05NV1.0.0B05, method: direct unlock (not tested!)
- fixed unlock definition for: ZTE TM_S189_RBTL35NV1.0.2B01, method: direct unlock
- fixed unlock definition for: ZTE TM_S168_RBTL35NV1.0.0B02, method: direct unlock
- see "modules\{9A05071F-D3A6-484B-8E3E-C6F47311C78C}\supported_phones.txt" for list supported models
BB (BlackBerry Tool)
- Added, Factory lock status on device scan
- Minor bug fixes
Download
The Following User Says Thank You to JUNAID ARAIN For This Useful Post:
Old 07-07-2011, 18:59   #2 (permalink)
Moderator
Nizda Mobile's Avatar
Member: 1464783
Thanks Meter: 1,012
you post in the wrong section
Old 07-08-2011, 05:11   #3 (permalink)
Akhtar Ali Jatt's Avatar
Member: 953334
Sonork: 100.1614005
Thanks Meter: 13,736
ARAIN sahab may be you need glasses this is a wrong section ,
first see then post mx key is the one who killed jaf ....?
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 30 02-24-2016 09:21
DES key Driver black Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 02-08-2014 03:50
8810 mbus-cable zfrank Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 05-19-1999 13:12
Page generated in 0.23675 seconds with 8 queries
