View Poll Results: Nokia 1112 Hard To Unlock | |||
Very | 1 | 9.09% | |
Medium | 3 | 27.27% | |
Easy | 7 | 63.64% | |
Voters: 11. You may not vote on this poll |
10-17-2007, 13:11 | #1 (permalink) |
Junior Member Join Date: Sep 2007
Member: 591917 Status: Offline Thanks Meter: 0 | Nokia 1112 Dead After Unlock Attempt Nokia 1112 dead after attempting to unlock using version 6 MCU software. I then used Erase fls on Jaf but now I cannot flash phone because Jaf cant set it to local mode. Here is a copy of what I have done on Jaff.... MCU ID: 0x2201 Reading flash chip detailes... FLASH ID0: 00EC2268 -> ST Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00000001 -> NOT USED Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 MCU ID: 0x2201 Boot is ready... Algo is ready... Loader is ready... Erasing area: 01000000 - 01FFFFFF... Done! MCU ID: 0x2201 Boot is ready... Algo is ready... Loader is ready... Erasing area: 01000000 - 01FFFFFF... Done! Detected P-KEY: 9000E4E9 P-key nokia module version 01.00 Changing mode...Done! Backing up PM Field 208 as RPL... Setting local mode... Failed! Aborting! Failed to backup imei... Flashing Done! Operation took 0 minutes 32 seconds... After flash processing... Waiting for phone to boot... Failed! Aborting! Reseting MMC...Failed Reseting MMC...OK Initializing MMC...OK Setting MMC block len...OK MMC FORCE ERASING... MMC Not Locked or Failed Powering the phone... Failed! Aborting! Backing up PM Field 208 as RPL... Setting local mode... Failed! Aborting! Failed to backup imei... Im have very little experience in phone flashing/unlocking. Can someone please explain to me in very simple steps what I need to do now. Regards, Simon |
10-18-2007, 20:59 | #2 (permalink) | |
Freak Poster Join Date: Nov 2006 Location: www.indo-services.com
Member: 401010 Status: Offline Thanks Meter: 103 | Quote:
10-20-2007, 14:56 | #5 (permalink) |
Member: 591917 Status: Offline Thanks Meter: 0 | Hi, Thanks for the replies folks. Can you explain to me in step by step detail (im a newbe) how I can flash this phone and where I get the flash files etc etc. Thanks in advance, Simon. |
10-21-2007, 14:59 | #9 (permalink) |
No Life Poster Join Date: Mar 2003 Location: Romania Brasov Age: 46
Member: 25136 Status: Offline Sonork: 1591036 Thanks Meter: 54 | 1.Install the last version from 1112 flash. 2.Select the manual flash just ceck manual 3. Select mcu file rh93_06.41mcu 4. select ppm file rh93_06.41 ee 5. not ceked 308 6. flash the phone |
10-22-2007, 15:35 | #10 (permalink) |
Member: 591917 Status: Offline Thanks Meter: 0 | Thanks for the reply. Tried flashing using your steps but below is what happened. Can anyone please help me with this? Simon. JAF version 1.98.22 Detected PKEY: 9000E4E9 Card life counter: 99.37% P-key nokia module version 01.00 Detected JAF INTERFACE version: 01.AC, Driver version: 40000, Library version: 30107 JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\ JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\ JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\ JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\ FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Phone Type: FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-93\rh93_06.00mc PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Phone Type: FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-93\rh93_06.00mc PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-93\rh93_06.00ee CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,German,Hungarian,Romanian MCU: C:\Program Files\Nokia\Phoenix\Products\rh-93\rh93_06.00mc Booting phone... MCU ID: 0x2201 BOOT file: C:\Program Files\ODEON\JAF\Flash\u_2nd.fia Loader version: 04.3D.00 -> Revision: 0007 Boot size is 0x0958 Boot is ready... FLASH ID0: 00EC2268 -> ST Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00000001 -> NOT USED Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Flash ID is 0x6822EC00 Flash loader is C:\Program Files\ODEON\JAF\Flash\u_amd.fia Loader version: 04.3D.00 -> Revision: 0007 Loader size is 0x6F80; Loader chk: 35 Loader is ready... P-key nokia module version 01.00 MSID: 841589E87E03A5E849731962D8 MSID decoded: 3E4EBAE900D660BFAA000000 FAID: EF1020214AF2856517DF1C0C Operation took 0 minutes 14 seconds... Erasing... Found 2 interval(s) to erase Erasing area: 011E0000 - 011EFFFF... Erasing area: 011F0000 - 0137FFFF... Operation took 0 minutes 10 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 9 seconds... Restarting MCU... PPM: C:\Program Files\Nokia\Phoenix\Products\rh-93\rh93_06.00ee Booting phone... MCU ID: 0x2201 BOOT file: C:\Program Files\ODEON\JAF\Flash\u_2nd.fia Loader version: 04.3D.00 -> Revision: 0007 Boot size is 0x0958 Boot is ready... FLASH ID0: 00EC2268 -> ST Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00000001 -> NOT USED Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Flash ID is 0x6822EC00 Flash loader is C:\Program Files\ODEON\JAF\Flash\u_amd.fia Loader version: 04.3D.00 -> Revision: 0007 Loader size is 0x6F80; Loader chk: 35 Loader is ready... P-key nokia module version 01.00 MSID: 84488FCC4947A25A46E35AF3EA MSID decoded: 3E4EBAE900D660BFA8000000 FAID: 22A750011AB03C11635543B6 Operation took 0 minutes 13 seconds... Erasing PPM... Found 2 interval(s) to erase Erasing area: 011E0000 - 011EFFFF... Erasing area: 011F0000 - 0137FFFF... Operation took 0 minutes 9 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 10 seconds... Restarting MCU... Flashing Done! Operation took 1 minutes 10 seconds... After flash processing... Waiting for phone to boot... Failed! Aborting! Powering the phone... Failed! Aborting! Detected P-KEY: 9000E4E9 P-key nokia module version 01.00 Changing mode...Done! Backup IMEI zone... Setting local mode... Failed! Aborting! Getting MCUID... MCU ID: 0x2201 Reading flash chip detailes... FLASH ID0: 00EC2268 -> ST Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00000001 -> NOT USED Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF MCU ID: 0x2201 Boot is ready... Algo is ready... Loader is ready... Erasing area: 01000000 - 01FFFFFF... Done! MCU ID: 0x2201 Boot is ready... Algo is ready... Loader is ready... Erasing area: 01000000 - 01FFFFFF... Done! FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-93\rh93_06.00mc PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Phone Type: FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Phone Type: FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Phone Type: FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-93\rh93_06.41mcu PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Phone Type: FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-93\rh93_06.41 ee PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Phone Type: FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Phone Type: FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-93\rh93_06.41mcu PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Phone Type: FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Phone Type: FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-93\rh93_06.00ag PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Phone Type: FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-93\rh93_06.41mc PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Phone Type: FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-93\rh93_06.41mc PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-93\rh93_06.41ee CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,German,Hungarian,Romanian MCU: C:\Program Files\Nokia\Phoenix\Products\rh-93\rh93_06.41mc Booting phone... MCU ID: 0x2201 BOOT file: C:\Program Files\ODEON\JAF\Flash\u_2nd.fia Loader version: 04.3D.00 -> Revision: 0007 Boot size is 0x0958 Boot is ready... FLASH ID0: 00EC2268 -> ST Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00000001 -> NOT USED Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Flash ID is 0x6822EC00 Flash loader is C:\Program Files\ODEON\JAF\Flash\u_amd.fia Loader version: 04.3D.00 -> Revision: 0007 Loader size is 0x6F80; Loader chk: 35 Loader is ready... P-key nokia module version 01.00 MSID: 841589E87E03A5E849731962D8 MSID decoded: 3E4EBAE900D660BFAA000000 FAID: EF1020214AF2856517DF1C0C Operation took 0 minutes 14 seconds... Erasing... Found 2 interval(s) to erase Erasing area: 011E0000 - 011EFFFF... Erasing area: 011F0000 - 0137FFFF... Operation took 0 minutes 10 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 9 seconds... Restarting MCU... PPM: C:\Program Files\Nokia\Phoenix\Products\rh-93\rh93_06.41ee Booting phone... MCU ID: 0x2201 BOOT file: C:\Program Files\ODEON\JAF\Flash\u_2nd.fia Loader version: 04.3D.00 -> Revision: 0007 Boot size is 0x0958 Boot is ready... FLASH ID0: 00EC2268 -> ST Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00000001 -> NOT USED Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Flash ID is 0x6822EC00 Flash loader is C:\Program Files\ODEON\JAF\Flash\u_amd.fia Loader version: 04.3D.00 -> Revision: 0007 Loader size is 0x6F80; Loader chk: 35 Loader is ready... P-key nokia module version 01.00 MSID: 84488FCC4947A25A46E35AF3EA MSID decoded: 3E4EBAE900D660BFA8000000 FAID: 22A750011AB03C11635543B6 Operation took 0 minutes 13 seconds... Erasing PPM... Found 2 interval(s) to erase Erasing area: 011E0000 - 011EFFFF... Erasing area: 011F0000 - 0137FFFF... Operation took 0 minutes 9 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 10 seconds... Restarting MCU... Flashing Done! Operation took 1 minutes 9 seconds... After flash processing... Waiting for phone to boot... Failed! Aborting! MCU: C:\Program Files\Nokia\Phoenix\Products\rh-93\rh93_06.41mc Booting phone... MCU ID: 0x2201 BOOT file: C:\Program Files\ODEON\JAF\Flash\u_2nd.fia Loader version: 04.3D.00 -> Revision: 0007 Boot size is 0x0958 Boot is ready... FLASH ID0: 00EC2268 -> ST Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00000001 -> NOT USED Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Flash ID is 0x6822EC00 Flash loader is C:\Program Files\ODEON\JAF\Flash\u_amd.fia Loader version: 04.3D.00 -> Revision: 0007 Loader size is 0x6F80; Loader chk: 35 Loader is ready... P-key nokia module version 01.00 MSID: 841589E87E03A5E849731962D8 MSID decoded: 3E4EBAE900D660BFAA000000 FAID: EF1020214AF2856517DF1C0C Operation took 0 minutes 13 seconds... Erasing... Found 2 interval(s) to erase Erasing area: 011E0000 - 011EFFFF... Erasing area: 011F0000 - 0137FFFF... Operation took 0 minutes 10 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 9 seconds... Restarting MCU... PPM: C:\Program Files\Nokia\Phoenix\Products\rh-93\rh93_06.41ee Booting phone... MCU ID: 0x2201 BOOT file: C:\Program Files\ODEON\JAF\Flash\u_2nd.fia Loader version: 04.3D.00 -> Revision: 0007 Boot size is 0x0958 Boot is ready... FLASH ID0: 00EC2268 -> ST Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00000001 -> NOT USED Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Flash ID is 0x6822EC00 Flash loader is C:\Program Files\ODEON\JAF\Flash\u_amd.fia Loader version: 04.3D.00 -> Revision: 0007 Loader size is 0x6F80; Loader chk: 35 Loader is ready... P-key nokia module version 01.00 MSID: 84488FCC4947A25A46E35AF3EA MSID decoded: 3E4EBAE900D660BFA8000000 FAID: 22A750011AB03C11635543B6 Operation took 0 minutes 13 seconds... Erasing PPM... Found 2 interval(s) to erase Erasing area: 011E0000 - 011EFFFF... Erasing area: 011F0000 - 0137FFFF... Operation took 0 minutes 9 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 10 seconds... Restarting MCU... Flashing Done! Operation took 1 minutes 8 seconds... After flash processing... Waiting for phone to boot... Failed! Aborting! Powering the phone... Failed! Aborting! Phone Type: FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-93\rh93_06.41mc PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-93\rh93_06.41ee CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,German,Hungarian,Romanian |
10-23-2007, 13:38 | #13 (permalink) |
Member: 591917 Status: Offline Thanks Meter: 0 | Update I have now unlocked the phone and it is powering up and working, thanks for all the help guys. It is unlocked and accepting different sims but what happens now is when a new sim is placed in the handset it finds signal briefly and then the signal goes. If I do a manual network search it finds all the networks but when I select the correct network I get the following message "no network access" Regards, Simon. |
A767 dead after unlock attempt with ust | lamont_dun | UST Pro II | 14 | 04-25-2009 16:52 |
W490 W510 V3re Dead after unlock attempt | mishaelwillo | Smart-Clip | 34 | 02-22-2008 09:36 |
5300 Dead after unlock attempt | mishaelwillo | BB5BOX | 2 | 01-26-2008 11:03 |
6280 Dead after unlock attempt | mishaelwillo | BB5BOX | 1 | 11-26-2007 10:16 |
