Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > J.A.F - Just Another Flasher > J.A.F. By Jafsupport.com
Old 05-08-2009, 13:10   #16 (permalink)
Member: 337762
Sonork: 100.1581304
Thanks Meter: 50
larry it unfortunate u dont know me very well i have know u for very long cause of ur acceseries buizness anyway i once work in that complex of your before up stairs before and i know quite lot of people in this buziness ladi kenny etc thank for asking all the same good luck
Old 05-08-2009, 13:18   #17 (permalink)
DieArmeSau's Avatar
Member: 175700
Thanks Meter: 756
every phone other driver, just google it and try different versions
.::EDIT::.
http://rapidshare.com/files/12149738...6_82_4_eng.msi
http://rapidshare.com/files/29779537...83_9_0_cze.zip
http://rapidshare.com/files/10864627...5_10_0_ger.msi
http://rapidshare.com/files/11143480...5_1_eng_us.msi
The Following User Says Thank You to DieArmeSau For This Useful Post:
Old 05-08-2009, 14:12   #18 (permalink)
cellularry's Avatar
Member: 42276
Thanks Meter: 47
Originally Posted by malikawan View Post
what nokia connectivity drivers version u use??
i used the latest version 7.1.8.0
Old 05-08-2009, 19:02   #19 (permalink)
jafsupport.com's Avatar
Member: 125
Sonork: 100.100000
Thanks Meter: 1,305
Arrow
Originally Posted by cellularry View Post
finally i could flash successfully a 5800 now with dead usb.
Not sure if the problem been solved completly i have to try another model as well
OK That means your PC have no problems... Use latest Cable drivers so it covers all most all the models... and remember that all Nokias doesn't support Dead USB Flashing...
The Following User Says Thank You to jafsupport.com For This Useful Post:
Old 05-12-2009, 14:09   #20 (permalink)
kiricu's Avatar
Member: 206710
Thanks Meter: 13
Hi All,
I had same problem with 6500 fold, you need a usb flah driver that is installed with NSU and then all was ok.
Best Regards
kiricu
Old 05-14-2009, 05:02   #21 (permalink)
Member: 125
Sonork: 100.100000
Thanks Meter: 1,305
If install Latest Connectivity cable driver then you have all you needed for usb dead flash...
Old 01-31-2015, 18:46   #22 (permalink)
Member: 2334814
Sonork: sonork
mantaf master.. ijin seruput
Help Me, Error in USB flashing? where is drivers for Nokia USB Rom? gsm_surya Universalbox 0 05-12-2008 13:06
Page generated in 0.17329 seconds with 9 queries
