05-14-2010, 08:47 | #196 (permalink) | |
Insane Poster Join Date: Oct 2006
Member: 379316 Status: Offline Thanks Meter: 85 | e71 start up Quote:
05-29-2010, 08:16 | #197 (permalink) | |
Freak Poster Join Date: May 2008 Location: The Time Has Come....
Member: 765331 Status: Offline Thanks Meter: 78 | Quote:
Have try this solution, phone now can on working fine but one thing no ringtone and loudspeaker. check buzzer is ok. any solution for this???? | |
06-01-2010, 02:08 | #198 (permalink) |
Junior Member Join Date: May 2010
Member: 1314313 Status: Offline Thanks Meter: 0 | help please!!! this is what i get, JAF version 1.98.62 Detected PKEY: 9000A902 Card life counter: 99.99% P-key nokia module version 01.02 FBUS INTERFACE NOT CONNECTED!!! USB Cable Driver version: 7.0.2.0 Changing mode...Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Detected P-KEY: 9000A902 P-key nokia module version 01.02 Init usb communication... Phone Type: FILES SET FOR FLASHING: MCU Flash file: C:\Documents and Settings\Administrator\My Documents\New Folder (2)\New Folder\E71_blank_504KB_pmm_10\E71_blank_504KB_pmm_ 10.fpsx PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Backing up CRT... Detected P-KEY: 9000A902 P-key nokia module version 01.02 Init usb communication... Failed to backup CRT... Preparing for downgrade... Detected P-KEY: 9000A902 P-key nokia module version 01.02 Init usb communication... Failed to prepare for downgrade... Detected P-KEY: 9000A902 P-key nokia module version 01.02 Init usb communication... PRESS POWER ON NOW! Searching for phone...Found Error reading phone init data... what does that phone init datta means? I loaded the E71_blank_504KB_pmm_10.fpsx file as MCU and without PPM or CNT. am I missing other settings?? help!!!! BR |
06-08-2010, 04:12 | #199 (permalink) |
Freak Poster Join Date: Oct 2008
Member: 883301 Status: Offline Sonork: 100 Thanks Meter: 12 | i have problem in nokia e71 dead it is on when plug charging and press on buttom.now a days it not work some time it work .how to solve help me soon it is urgent. thanks |
06-13-2010, 02:05 | #202 (permalink) |
Junior Member Join Date: Jun 2010
Member: 1323650 Status: Offline Thanks Meter: 0 | e71 dead phone I have a problem with my e71 after a firmware update. I flashed the firmware using the latest phoenix software because I wanted Chinese characters on it and now it is not working. After holding the power button for 5 seconds the keyboard light comes on for about 20 seconds and then it turns off again. Do you know how I would restore it back to factory settings? |
06-17-2010, 11:42 | #208 (permalink) |
Freak Poster Join Date: Sep 2005 Location: saudiarabia/india
Member: 185396 Status: Offline Sonork: 100.1618832 Thanks Meter: 33 | Hi.., This is the solution for the E63which shows the following Symptoms... Phone does not start up when pressing power key. When pressing the power key notification light and display backlight wake up. Vibra makes one jog. Phone will take 230 mA but nothing else happens. After 30 seconds phone will power off. You can update phone software but it doesn't help anything. Phone doesn't start to test mode... Solution.. |
06-23-2010, 19:46 | #210 (permalink) |
Freak Poster Join Date: Oct 2005 Location: Nigeria
Member: 194436 Status: Offline Thanks Meter: 12 | Version from phone: ICPR71_09w22.9 Version from file: 400.21.013 Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010) RAP Data : SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 08500114A97B0052995A4EDCD097C8A930E87AC4 ASIC MODE ID: 00 ROOT KEY HASH: 9A28E119033B91D14D22838C86D0D53C ROM ID: 4B9B75103E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80 Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 FlashID0: 00EC 0040 - 0080 0121 [Samsung 2Gb DDP OneNAND,2 Gbits] type: MuxOneNAND,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520 Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 RAP PAPUBKEYS HASH: D9C25399C696B8549EDCDB1497A950B3A20DDFB6 Reading RAP NPC (0x190 bytes). Reading RAP VARIANT (0x0 bytes). Reading RAP CCC (0x160 bytes). Reading RAP HWC (0xD4 bytes). Flash Imei: 35683602381826 NPC_DATA saved OK CCC_DATA saved OK HWC_DATA saved OK SIMLOCK_DATA saved OK SIMLOCK_KEY_DATA saved OK WMDRM_PD_DATA saved OK RF_DATA saved OK WARRANTY_DATA saved OK PROD_DATA saved OK BT_DATA saved OK LOCK_DATA saved OK LOCK120_DATA saved OK BB_DATA saved OK WLAN_DATA saved OK RPL saved to "C:\mobileEx\3.4\data\backup\BB5_35683602381826_BA CK.rpl" Processing file: rm437_400.21.013_prd.c00 as MCU [BB5,XSR 1.5] size: 64.04 MB Supported RAP Ids: 4003192101002003, 400C192101002003, 0003192101002003, 000C192101002003, 000C192101011103, 0003192101011103, 400C192101011103, 4003192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103 RAP Data : SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 08500114A97B0052995A4EDCD097C8A930E87AC4 ASIC MODE ID: 00 ROOT KEY HASH: 9A28E119033B91D14D22838C86D0D53C ROM ID: 4B9B75103E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80 Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 FlashID0: 00EC 0040 - 0080 0121 [Samsung 2Gb DDP OneNAND,2 Gbits] type: MuxOneNAND,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520 Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 RAP PAPUBKEYS HASH: D9C25399C696B8549EDCDB1497A950B3A20DDFB6 Storing certificate ...OK Partitioning ...OK Erase size: 122.56 MB CMT MuxOneNAND area [00040000-007FFFFF] CMT MuxOneNAND area [00A00000-0759FFFF] CMT MuxOneNAND area [0F1C0000-0F8BFFFF] Formating Partition ... Formating Partition ... Formating Partition ... erased in 0.766 s Flash programming ... CMT PAPUBKEYS: D9C25399C696B8549EDCDB1497A950B3A20DDFB6 (RAP Certificate 137 v.1) written. Programming completed in 5 min 35.531 s Processing file: rm437_400.21.013_prd.v14 as PPM [BB5,XSR 1.5] size: 27.09 MB Supported RAP Ids: 4003192101002003, 400C192101002003, 0003192101002003, 000C192101002003, 000C192101011103, 0003192101011103, 400C192101011103, 4003192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103 RAP Data : SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 08500114A97B0052995A4EDCD097C8A930E87AC4 ASIC MODE ID: 00 ROOT KEY HASH: 9A28E119033B91D14D22838C86D0D53C ROM ID: 4B9B75103E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80 Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 FlashID0: 00EC 0040 - 0080 0121 [Samsung 2Gb DDP OneNAND,2 Gbits] type: MuxOneNAND,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520 Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 RAP PAPUBKEYS HASH: D9C25399C696B8549EDCDB1497A950B3A20DDFB6 Erase size: 33.56 MB CMT MuxOneNAND area [05420000-0759FFFF] Formating Partition ... erased in 0.282 s Flash programming ... Programming completed in 2 min 26.563 s Processing file: rm437_400.21.013.36U as CNT [BB5,XSR 1.5] size: 17.16 MB Supported RAP Ids: 4003192101002003, 400C192101002003, 0003192101002003, 000C192101002003, 000C192101011103, 0003192101011103, 400C192101011103, 4003192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103 RAP Data : SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 08500114A97B0052995A4EDCD097C8A930E87AC4 ASIC MODE ID: 00 ROOT KEY HASH: 9A28E119033B91D14D22838C86D0D53C ROM ID: 4B9B75103E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80 Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 FlashID0: 00EC 0040 - 0080 0121 [Samsung 2Gb DDP OneNAND,2 Gbits] type: MuxOneNAND,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520 Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 RAP PAPUBKEYS HASH: D9C25399C696B8549EDCDB1497A950B3A20DDFB6 Erase size: 64.00 KB Formating Partition ... erased in 1.281 s Flash programming ... Programming completed in 1 min 33.000 s Flashing completed in 10 min 28.891 s After Flash Processing ... Phone Type: RM-437 (Nokia E63) SW Version: V ICPR71_09w22.9 16-10-09 RM-437 (c) Nokia Imei plain: 35683602381826-0 Product Code: 0568897 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 356836023818260 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Total time to process is 10 min 40.110 s |
Solution For E51 phone does not start up... | jafsupport.com | J.A.F. By Jafsupport.com | 106 | 12-22-2012 19:05 |
E71 phone does not start up | szozda2 | Nokia Hardware & Hardware Repair | 10 | 12-17-2009 03:19 |
my n78 phone does not start up... help! | yx724 | J.A.F. By Jafsupport.com | 7 | 06-10-2009 04:25 |
my n78 phone does not start up... help! | yx724 | Nokia Base Band 5 ( BB-5 ) | 3 | 05-08-2009 20:09 |
