Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > J.A.F - Just Another Flasher > J.A.F. By Jafsupport.com
Old 12-10-2011, 20:49   #286 (permalink)
Member: 1110772
Thanks so much...
great....
Old 01-07-2012, 20:11   #287 (permalink)
Member: 1711079
My phone developed this problem two days ago.i tried to flash it but my pc couldn't detect my phone.pls what can i do.
Old 01-19-2012, 20:35   #288 (permalink)
Member: 962803
Thanks Meter: 3
help need....i have a e63-3 rm450 austrailian phone.Phone does not start up. When pressing the power key notification light and display backlight wake up. Vibra makes one jog. Phone showing blank(black) display but nothing else happens. After 30 seconds phone will power off. if i press the power key coninuously it wont power off untill i remove finger from power key. do i need to flash with j.a.f or s.f.i.
and onething i downloaded e63 rm450 with product key using with navi firm 1.5 and i copied all firmware files to nokia software phoenix products location. and i opened phoenix to refurbish the phone and its showing no dp1 or dp2 found in datapakage folder error. i have a doubt, can phoenix flash abroad mobiles like us uk aus,i'm from india.
please help me out
thanks in advance.
Old 01-21-2012, 04:49   #289 (permalink)
Member: 1103578
Nokia E71-1 1st boot err pls help
Old 02-18-2012, 19:38   #290 (permalink)
Member: 1723823
Nokia E71 not booting up.
Hi Friends,
While I was in driving, I switched off my Nokia E71 mobile. When I reached home, I tried to switch on, as usual vibrated once, key pad lights are on, screen blinks slightly for 30 seconds. It's not booting and startup screen also not coming.
Since I bought the mobile on May 2011, I had restart problem when I answering calls.
I have googled and found this forum. I have downloaded attached pmm file also. Please let me know is that the latest file and can I flash my mobile with it.
And also please let me know how to flash the mobile with the file. Step by step instructions are much appreciated.
Thanks in advance.
Regards,
Giri
Old 03-02-2012, 00:29   #291 (permalink)
Member: 568552
Hi there,
I have exactly the same problem like thread starter said in first post, and I also have JAF and all files but the problem is that I CAN'T connect my phone to PC with USB...how to fix this???
I tryed to switch on the phone when it's says "Searching phone" and JAF founds the phone but it lasts only few seconds and after that I get "...error reading rap ver" message...
PLEASE HELP ASAP...
Old 04-03-2012, 11:09   #292 (permalink)
Member: 1231601
Thanks Meter: 13
thanks good solution
Old 09-17-2012, 17:22   #293 (permalink)
Member: 1677416
Sonork: 100.1626947
Thanks Meter: 55
thankz…….a lott…thanxxxxxxxxx!
nice solution its 100% working....
Old 10-09-2014, 19:49   #294 (permalink)
Member: 2271087
Thanks it works , with Pheonix software
Old 04-01-2015, 03:27   #295 (permalink)
Member: 1598181
I have the same problem with my e72 is there a ppm file for e72 also?
Old 04-16-2015, 05:52   #296 (permalink)
Member: 189351
Thanks Meter: 11
Originally Posted by jafsupport.com View Post
hi..,
this is the solution for the e71 which shows the following symptoms...
Phone does not start up when pressing power key. When pressing the power key notification light and display backlight wake up. Vibra makes one jog. Phone will take 230 ma but nothing else happens. After 30 seconds phone will power off. You can update phone software but it doesn't help anything. Phone doesn't start to test mode...
Solution..
Flash the phone using the attached pmm erase file...
Then flash it with latest data pakage..
thank you so much dear its works great
my phone live again
select this file in mcu and flash it after that full flash your pphone
Solution For E51 phone does not start up... jafsupport.com J.A.F. By Jafsupport.com 106 12-22-2012 19:05
E71 phone does not start up szozda2 Nokia Hardware & Hardware Repair 10 12-17-2009 03:19
my n78 phone does not start up... help! yx724 J.A.F. By Jafsupport.com 7 06-10-2009 04:25
my n78 phone does not start up... help! yx724 Nokia Base Band 5 ( BB-5 ) 3 05-08-2009 20:09
Page generated in 0.30056 seconds with 10 queries
