08-16-2014, 11:54 | #136 (permalink) |
Junior Member Join Date: Nov 2009
Member: 1166538 Status: Offline Sonork: starplus Thanks Meter: 3 | I have tried to flash Nokia e63 with usb. Following is the result: AF version 1.98.66 beta5 Detected PKEY: 9000AAC9 P-key nokia module version 01.02 FBUS INTERFACE NOT CONNECTED!!! USB Cable Driver version: 7.1.182.0 Changing mode...Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-437\ Searching for default location of ini... Checking path: \Products\RM-437\ Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-437\ No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Detected P-KEY: 9000AAC9 P-key nokia module version 01.02 Init usb communication... Phone Type: FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phonix\Products\RM-437\rm437_411.21.001_prd.c00 PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Detected P-KEY: 9000AAC9 P-key nokia module version 01.02 Init usb communication... Phone Type: FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phonix\Products\RM-437\rm437_411.21.001_prd.c00 PPM Flash file: C:\Program Files\Nokia\Phonix\Products\RM-437\rm437_411.21.001_prd.v323 CNT Flash file: NONE APE Variant file: NONE Detected P-KEY: 9000AAC9 P-key nokia module version 01.02 Init usb communication... Phone Type: FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phonix\Products\RM-437\rm437_411.21.001_prd.c00 PPM Flash file: C:\Program Files\Nokia\Phonix\Products\RM-437\rm437_411.21.001_prd.v323 CNT Flash file: C:\Program Files\Nokia\Phonix\Products\RM-437\rm437_411.21.001.323U APE Variant file: NONE Detected P-KEY: 9000AAC9 P-key nokia module version 01.02 Init usb communication... Phone Type: FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phonix\Products\RM-437\rm437_411.21.001_prd.c00 PPM Flash file: C:\Program Files\Nokia\Phonix\Products\RM-437\rm437_411.21.001_prd.v323 CNT Flash file: C:\Program Files\Nokia\Phonix\Products\RM-437\rm437_411.21.001.323U APE Variant file: C:\Program Files\Nokia\Phonix\Products\RM-437\RM437_ENO_008.07.45_100.71.920.a01.fpsx Backing up CRT... Detected P-KEY: 9000AAC9 P-key nokia module version 01.02 Init usb communication... Failed to backup CRT... Backing up CRT... Detected P-KEY: 9000AAC9 P-key nokia module version 01.02 Init usb communication... Failed to backup CRT... Can any one kindly tell how can I flash the phone. The phone open in Local mode when swithed on can't change or I don't understand how to change it. More over connecting to pc it doesn't seem to be detecting. I have checked cable CA-101 it is ok. I have uninstalled and reinstalled Nokia suite and cable driver several times. Please help me to solve out this problem |
How to flash N73 or other like that phones with USB Cable ? Its Possible? | DJiCE | Universalbox | 0 | 12-08-2007 17:02 |
WANTED: Sonyericsson connector with wire, USB cables or sonyericsson <-> USB cables | Mizar | Wanted Products | 1 | 06-25-2004 11:53 |
