05-08-2009, 08:45 | #1 (permalink) |
No Life Poster Join Date: Oct 2003 Location: Philippines
Member: 42604 Status: Offline Thanks Meter: 187 | 1600 China phone need pinout tried this pinout..but wont connect..noticed that all the 6 TP on the pcb nothing is connected to GND as indicated in the picture below.. this is the pcb.... i tried using pin finder but still can't find the correct pinout..tried using other tools with auto pinout search but failed to find it.. |
The Following User Says Thank You to kasamiko For This Useful Post: |
05-08-2009, 19:07 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! attach phone battery and measure voltages on those test points. 2,7-2,9 volts will be indicated on Tx/Rx pins |
05-09-2009, 11:22 | #4 (permalink) |
No Life Poster Join Date: Jun 2006 Location: Philippines
Member: 302596 Status: Offline Thanks Meter: 784 | jus fallow this steps 1. set multimeter to voltage measuring. 2. check bettery voltage, it should be more than 3,7volts 3. set one multimeter probe to some grounded phone part (if you cant find grounded part outside phone- you need to take out small thin wire from negative battery terminal) 4. with second probe touch one by one all phone pins (phone must be powered on, you can use rps to power on unit) (to get better result i would advice to set needle on the end of second probe) memorise pins with voltage between 2.3 to 2.9volts. those are tx/rx |
<<< Gaoxinqi GXQ G718 CHINA MOBILE - need pinouts >>> | khadim100 | Infinity-Box | 6 | 03-28-2009 06:53 |
1600 bad software ,need pinout | FullFlashPak | Infinity-Box | 2 | 02-20-2009 15:22 |
1600 china phone hang, using infinity box...... | Redtan_70 | Infinity-Box | 3 | 01-07-2009 03:42 |
new 1600 china phone?? | jhay_12 | Infinity-Box | 6 | 10-28-2008 21:32 |
Nokia 1600 china phone | GSMaxx | SpiderMan | 0 | 09-05-2008 13:31 |
