Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Infinity-Box > Chinese Miracle & PinFinder
Old 12-19-2009, 08:19   #1 (permalink)
lilong_lee's Avatar
Member: 1070665
Sonork: 100.1636802
5310 china phone dead for infinity box the problem only hung up
infinity team pleas help this problem dead from infinity box the phone is hung up when you insert simcard i try format whole chep the phone is dead .........here in logs .pleas any body help me
COM10 [VCP0] selected
module v2.84
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: write NOR flash
"smart write" active
write: Firmware
skip: Customization/Language Pack
skip: Customization
write: Eeprom/ffs
ffs/eeprom backup enabled, it may takes several minutes !
Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:2A03:0002
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: 98000300000001:18A59F00000000
flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb
detecting chip #01 in region #00...
flash: 98000300000001:18E59F00000000
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
Set baud ...
460800
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
device parameters autodetection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area (code #1) is Ok
security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.61B6DF83.[RHY25_06B_PCB01_GPRS_MT6225_S00.A51_V00_01.BIN_FCF FB73C].rpl
identification#1 detection finished
device-id: 61B6DF83
identification#1 protocol ver: 04
ver. sw 1: RHY25_06B_PCB01_GPRS_MT6225_S00.A51_V00_01.BIN
ver. sw 2: A51.V00.01, C3480003
ffs offset/size: 00E00000/00200000
detect device identification#2...
detect device identification#2 finished
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
checking area [00000000]: 00000000-00FFFFFF...
ffs/eeprom found near: 00FA0000
Detected ffs/eeprom address is non-standard: 00FA0000
Posible reasons:
1. ffs/eeprom is Ok but address is non-standard
2. ffs/eeprom is damaged and can't be detected
3. ffs/eeprom is Ok but detected incorrectly (f.e. unknown ffs/eeprom structure)
If you are not sure that detected address is correct:
1. press "NO" (and select standard address or terminate current operation)
2. make full flash backup for emergency case
3. repeat required operation
Are you sure that detected ffs/eeprom address is correct ?
autodetected ffs/eeprom address confirmed by user: 00FA0000
detecting ffs/eeprom size...
ffs/eeprom size: 00060000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00FA0000-00FFFFFF
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
reading: RHY25_06B_PCB01_GPRS_MT6225_S00.A51_V00_01__ffs...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\RHY25_06B_PCB01_G PRS_MT6225_S00.A51_V00_01__ffs_20091219-161809.B0E.bin
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
security area (code #1) calculation...
done
detecting security area (code #2)...
security area (code #2) is absent
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\R HY25_06B_PCB01_GPRS_MT6225_S00.A51_V00_01__system_ log_61B6DF83_FCFFB73C_20091219-162519.B0X.bin
Area: Firmware
Write: Firmware
Area: Eeprom/ffs
Write: Eeprom/ffs
Write Done
Finalization ...
Finalization Done
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\R HY25_06B_PCB01_GPRS_MT6225_S00.A51_V00_01__system_ log_61B6DF83_FCFFB73C_20091219-162713.B0X.bin
Finished, time used: 701 sec
Remove/Install battery now !
complete but not switch on ....................
Old 12-19-2009, 08:21   #2 (permalink)
lilong_lee's Avatar
Member: 1070665
Sonork: 100.1636802
ffs problem pleas can you give me ffs no ffs support for this model
Old 12-19-2009, 08:28   #3 (permalink)
lilong_lee's Avatar
Member: 1070665
Sonork: 100.1636802
pleas tell me how to solve this i try format but say this
module v2.84
Action: reset settings
Model: Autodetect 6205-6227 NOR
19200 autodetect
CPU: MT6225
high speed boot On
status: FF
Connecting at 19200, wait...
Phone detected, wait...
Hardware: MT6225,E05
Date: 2006.06.14
Version: 1.0
Version: A51.V00.01
Version: RHY25_06B_HW
detecting structure #2...
0 done
44 byte(s) read
imei: 13579024682211
connection Ok
building list...
done
items to clear: 127
warning: wrong packet cs
items cleared: 87 of 127
items remains: 0
Finished, time used: 235 sec
Old 12-19-2009, 08:28   #4 (permalink)
marvin03's Avatar
Member: 1015389
Sonork: 19830303
do you have back ups?
Old 12-19-2009, 10:22   #5 (permalink)
lilong_lee's Avatar
Member: 1070665
Sonork: 100.1636802
no one back up ...........
Old 12-19-2009, 10:45   #6 (permalink)
lilong_lee's Avatar
Member: 1070665
Sonork: 100.1636802
module v2.84
advanced flash detection disabled
write: Firmware
skip: Customization
write: Eeprom/ffs
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
status: FF
Boot Done
Initialize ...
flash: 98000300000001:FFFFFF00000000
flash: Toshiba T 16Mb
Initialize Done
Set baud ...
460800
Set baud Done
Warning: probably flash chip is empty, erased, incorrectly flashed or damaged !
What to do:
1. go to software "Settings" page
2. set "Advanced chip detection method" box CHECKED !
3. make flash write operation
If still no luck: send mail to support (mt62xx@gmail.com) with detailed description of problem,
attach the next files in your e-mail:
1. C:\Program Files\InfinityBox\ChineseMiracle\operation.log
2. C:\Program Files\InfinityBox\ChineseMiracle\cfi_xxxx_xxxx.bin
it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
detection phase #2...
warning: identification#1 information not found, possible reasons:
.old firmware type w/o identification#1 data
.damaged firmware
.damaged hardware
if phone works fine just ignore this warning
standard ffs/eeprom offset assigned: 00E00000
ffs/eeprom found near: 00E00000
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
reading: _ffs...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\_ ffs_20091219-185717.B0E.bin
Write ...
.damaged firmware
.damaged hardware
Area: Firmware
Write: Firmware
error: error# 000000A4
error: flash write error: 00020000:00002000
Write Fail
Finished, time used: 332 sec
Old 12-19-2009, 11:53   #7 (permalink)
mbiborna's Avatar
Member: 770503
make format ffs in complete mode & post result.
biborna.
Old 12-19-2009, 12:01   #8 (permalink)
lilong_lee's Avatar
Member: 1070665
Sonork: 100.1636802
mbiborna make format ffs in complete mode & post result.
biborna.
here in format ffs complete
module v2.84
Action: "format ffs"
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
status: FF
Boot Done
Initialize ...
Initialize Done
Set baud ...
460800
Set baud Done
What to do:
.damaged firmware
.damaged hardware
ffs/eeprom chip: 00
reading: _ffs...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\_ffs_20091219-201356.B0E.bin
Write ...
Write Done
Finalization ...
formatting...
error: wrong erase first sector at 0x00E00000
Finalization Fail
Finished, time used: 216 sec
here complete but not power on but the problem is when you insert sim car the phone out shat off i format infinity whole flash chip the phone is dead infinity team help ..............
Old 12-19-2009, 15:04   #9 (permalink)
lilong_lee's Avatar
Member: 1070665
Sonork: 100.1636802
pleas help
module v2.84
write: Firmware
skip: Customization
write: Eeprom/ffs
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
status: FF
Boot Done
Initialize ...
Initialize Done
Set baud ...
460800
Set baud Done
What to do:
2. set "Advanced chip detection method" box UN-CHECKED !
.damaged firmware
.damaged hardware
ffs/eeprom chip: 00
reading: _ffs...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\5310\eep\SCUD_GEM INI_PCB01_GPRS_MT6225_S00.617B_A_V07_06__ffs_20091 218-153136.B0E.bin
Write ...
.damaged firmware
.damaged hardware
done
Area: Firmware
Write: Firmware
Area: Eeprom/ffs
Write: Eeprom/ffs
Write Done
Finalization ...
Finalization Done
Finished, time used: 388 sec
Old 12-20-2009, 21:47   #10 (permalink)
Member: 148515
hello!
you erased whole flash chip, all16mb.
now phone must be flashed with firmware "HY25_06B_PCB01_GPRS_MT6225_S00.A51_V00_01" in order to get it back to work
for example this one:
flashfiles/ChineseMiracle/_MT6225/RHY25_06B_PCB01_GPRS_MT6225_S00.A51_V00_01__5310_1 6m_En_Ru_Fr_De_Id_Cn_Tr_Farsi_Cn_Ar.B0M.bin
Old 12-20-2009, 21:56   #11 (permalink)
malpinssa's Avatar
Member: 476420
Sonork: 100.1605239
never say that this box kill phone for ever becoz yougogp can live it by flashed it with same virsion .good method you can see support to get procedure to flash shaines phones
good luck
i-Pmart BX Series RJ45 Cable Compatible For China NK N5 For Infinity Box IPMART ipmart WebShop 0 07-09-2009 06:50
i-Pmart BX Series RJ45 Cable Compatible For China Motorola L7+ For Infinity Box IPMART ipmart WebShop 0 07-08-2009 10:50
need china 5310 express music flash file for infinity box pogs1962 Chinese Models & Cloned Phones 1 05-08-2009 14:23
Free First in the world updates only for Infinity Box Customers Infinity-Box Main Sales Section 0 03-01-2009 16:39
1600 china phone hang, using infinity box...... Redtan_70 Chinese Miracle & PinFinder 3 01-07-2009 02:42
Page generated in 0.39754 seconds with 11 queries
