Old 01-07-2009, 09:46   #1 (permalink)
lix_DAVAO's Avatar
Member: 144091
Thanks Meter: 73
5310 no power after format - help
i missed to backup with infinity but had backup with spiderman.
after format it's now dead
here is the backup
http://rapidshare.com/files/18063141...-3-31.BIN.html
TIA
Old 01-07-2009, 10:03   #2 (permalink)
lix_DAVAO's Avatar
Member: 144091
Thanks Meter: 73
http://rapidshare.com/files/18063385...51756.B0M.html
Old 01-07-2009, 10:17   #3 (permalink)
unlock & flash's Avatar
Member: 745728
Sonork: 100.1579942
Thanks Meter: 338
post here mobile picture and tell it is one sim or 2 sim and cpu details
Old 01-07-2009, 11:16   #4 (permalink)
lix_DAVAO's Avatar
Member: 144091
Thanks Meter: 73
CPU is MTK
MT6226 (anyway it's indicated in the flashfiles uploaded)
@Infinity
I already used several flashfiles from support match with this 5310 but no one did work. i will post picture later. thanks
Old 01-07-2009, 11:17   #5 (permalink)
lix_DAVAO's Avatar
Member: 144091
Thanks Meter: 73
CPU is MTK - 1 sim only
@Infinity
Old 01-07-2009, 14:01   #6 (permalink)
lix_DAVAO's Avatar
Member: 144091
Thanks Meter: 73
[D421_05C_PCB01_GPRS_MT6226_S01.GM650-V01-2008-3-31.BIN]_20090107-151756.B0M
pinout is on board
Old 01-07-2009, 15:31   #7 (permalink)
lix_DAVAO's Avatar
Member: 144091
Thanks Meter: 73
i could twist this 5310 into pieces.
now it just turned on using flash flash from infinity in which i had already flashed several times lately.
anyway thanks to infinity...mwah! lesson learned just use infinity SW and it's best
here is log
COM3 [VCP0] selected
module v2.73
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: write NOR flash
"smart write" active
write: Firmware
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
Boot ...
19200 fixed
Connecting, wait...
Initializing [6226:8A02:8A01]...
CPU: MT6226
high speed boot Off
chip: 0031:E5AF:4C49
high speed boot Off
boot packet size: 0002
Release Power button now !
Boot Done
Initialize ...
flash: EC257E25082501:2AEA0000000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud ...
921600
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area (code #1) is damaged, recalculation required
identification#1 detection finished
device-id: 0A1585E5
identification#1 protocol ver: 04
ver. sw 1: D421_05C_PCB01_GPRS_MT6226_S01.GM699-V01-2008-3-31.BIN
ver. sw 2: GM699-V01-2008-3-31, 2C0234E4
ffs offset/size: 00E00000/00200000
detect device identification#2...
warning: optional information is not found,
if phone works well just ignore this warning
detect device identification#2 finished
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
security area (code #1) calculation...
done
detecting security area (code #2)...
security area (code #2) is absent
Area: Firmware
Write: Firmware
Write Done
Finalization ...
Finalization Done
Finished, time used: 430 sec
Remove/Install battery now !
Old 01-07-2009, 19:41   #8 (permalink)
InfinityN's Avatar
Member: 720034
Thanks Meter: 213
@lix_DAVAO
What is backup files from your first message ?
Is it backup files BEFORE format or AFTER format ?
[help] 5310 no display after repair LCD no light thonylvs Nokia Hardware & Hardware Repair 0 01-14-2010 03:33
no power after unlocking siemens a71 help maxheadquarters Siemens Hardware Repair Area 0 02-23-2006 16:27
F2100 no power after flash , help pls.....! BMobile VygisToolbox 4 09-06-2005 17:48
Help me K700 no power after bad charger... uti79 Sony Ericsson Hardware Repair 0 07-06-2005 08:31
6510 no power after flashing,help!!!! michaelcaine22 Nokia Hardware & Hardware Repair 3 02-20-2005 00:33
Page generated in 0.20383 seconds with 9 queries
