07-31-2011, 16:48 | #1 (permalink) |
No Life Poster Join Date: Dec 2007 Location: pakistan Age: 41
Member: 653398 Status: Offline Thanks Meter: 669 | 6225 cpu format error read flash error ? module v3.97 Device: _Autodetect MT6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: read flash ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:E703:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 detecting chip #01 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 detecting chip #02 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 detecting chip #03 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 detecting chip #01 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... warning: wrong cs at 0x00006844, retry... warning: wrong cs at 0x00006844, retry... warning: wrong cs at 0x00006844, retry... warning: wrong cs at 0x00006844, retry... warning: wrong cs at 0x00006844, retry... warning: wrong cs at 0x00006844, retry... warning: wrong cs at 0x00006844, retry... search rom info finished rom info structure: [standard] type (04) TCL-ID is absent ==================== New firmware found (v.3.97, database date: 17.07.2011): PROWAVE25_GEMINI_PCB01_GPRS_MT6225_S00.LT526_R1_0_ 31_0.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info ver: 04 sw version: PROWAVE25_GEMINI_PCB01_GPRS_MT6225_S00.LT526_R1_0_ 31_0.BIN project-id: LT526_R1.0.31.0, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [standard] type (04) TCL-ID is absent operation aborted Finished, time used: 27 sec Remove/Install battery now ! |
07-31-2011, 16:50 | #2 (permalink) |
Member: 653398 Status: Offline Thanks Meter: 669 | done with gpg dragon Initializing... DA_LIB_VER_3.4.1.2 It is sensing the pinout fast,please hold on the phone Power key RXD=10 TXD=9 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6225, HardwareVer:8A03, SoftwareVer:8A00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 0098004900000000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: LT526_R1.0.31.0 Changing baudrate to 921600... Done. Formatting Flash... AutoFormat address: start=0x00E00000, size=0x00200000 All Done |
07-31-2011, 16:52 | #3 (permalink) |
Member: 653398 Status: Offline Thanks Meter: 669 | here is format log COM4 [Serial2] selected module v3.97 Device: _Autodetect MT6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:E703:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 detecting chip #01 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 detecting chip #02 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 detecting chip #03 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 detecting chip #01 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 warning: wrong cs at 0x01000000, retry... warning: wrong cs at 0x01000000, retry... warning: wrong cs at 0x01000000, retry... warning: wrong cs at 0x01000000, retry... warning: wrong cs at 0x01000000, retry... warning: wrong cs at 0x01000000, retry... warning: wrong cs at 0x01000000, retry... warning: wrong cs at 0x01000000, retry... warning: wrong cs at 0x01000000, retry... error: too many retries during read operation error: can't read required memory area total flash region size: 02000000 usb bootloader detect... error: wrong answer: 00 .error: wrong answer: 00 . usb bootloader detect (phase #2)... error: wrong answer: 00 .error: wrong answer: 00 . usb bootloader (chip) is absent searching rom info... error: wrong answer: 44 . search rom info finished searching rom info... error: wrong answer: 00 . search rom info finished warning: rom info information not found, possible reasons: - old firmware type w/o rom info information - empty (completely or partially erased) flash chip - damaged firmware - damaged hardware (bad soldered or damaged flash chip) > if phone works fine just ignore this warning < detecting ffs/eeprom area in 2 chip(s)... standard ffs/eeprom offset assigned: 01C00000 warning: wrong cs at 0x01C00000, retry... warning: wrong cs at 0x01C00000, retry... warning: wrong cs at 0x01C00000, retry... warning: wrong cs at 0x01C00000, retry... warning: wrong cs at 0x01C00000, retry... warning: wrong cs at 0x01C00000, retry... warning: wrong cs at 0x01C00000, retry... warning: wrong cs at 0x01C00000, retry... warning: wrong cs at 0x01C00000, retry... error: too many retries during read operation error: wrong answer: 7F error: wrong answer: 00 : wrong answer after chip id request error: wrong answer: FF : wrong answer after chip cfi request error: wrong answer: 00 : wrong answer after chip id request Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 01C00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs/eeprom address selected by user detecting ffs/eeprom size... ffs/eeprom size: 00400000 ffs/eeprom chip: 01 ffs/eeprom area: 01000000:00C00000-00FFFFFF sec info (detailed) detection... searching sec info#1... error: wrong answer: 00 . search sec info#1 finished error: wrong answer: 0B error: connection lost Finished, time used: 42 sec Remove/Install battery now ! |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
My 5110 v5.11 have a strange error.., it resets it self every 60second | luuk | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 24 | 08-11-2006 15:29 |
Avoid 3 times error code in Nokia 6185 | X-plot | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-08-2000 20:24 |
The multiple errors of Winlock ... ??? | Genata | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 09-20-1999 19:12 |
error (1002) simlock3.dll winopen | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 08-28-1999 15:57 |
