12-07-2008, 10:33 | #1 (permalink) |
Freak Poster Join Date: Jun 2007 Location: S A H I W A L Age: 38
Member: 526737 Status: Offline Thanks Meter: 9 | 6300 RH-37 after factory setting set is gone dead mode infinity team plz help me tomorrow i recive 1 pice 6300 rh-37 chines mobile.set is work fine but after play video songs few sec restart. . . when i apply factory setting set is gone dead mode why??? then i go to infinity support and download all files 6300 and apply one by one but result is same. . . Here is flash log : COM4 selected module v2.70 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: write NOR flash "smart write" active write: Firmware skip: Customization/Language Pack skip: Customization write: Eeprom/ffs Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:A103:000F boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.FC11E46C.[TELSDA26_05C_PCB01_GPRS_MT6226_S01.BASECODE.BIN_6A B6A24B].rpl identification#1 detection finished device-id: FC11E46C identification#1 protocol ver: 04 ver. sw 1: TELSDA26_05C_PCB01_GPRS_MT6226_S01.BASECODE.BIN ver. sw 2: BASECODE, B45D4995 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: 01227E22202200:29EA0000000000 checking area [00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: eeprom[TELSDA26_05C_PCB01_GPRS_MT6226_S01.BASECODE.BIN]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\6300isl\eeprom[TELSDA26_05C_PCB01_GPRS_MT6226_S01.BASECODE.BIN]_20081207-011748.B0E.bin flash: 01227E22202200:29EA0000000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished security area (code #1) calculation... done detecting security area (code #2)... security area (code #2) is absent file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_FC11E46C_TELSDA26_05C_PCB01_GPRS_MT6226_ S01.BASECODE.BIN_6AB6A24B_20081207-012212.B0X.bin Area: Firmware flash: 01227E22202200:29EA0000000000 Write: Firmware Area: Eeprom/ffs flash: 01227E22202200:29EA0000000000 Write: Eeprom/ffs detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished Write Done Finalization ... Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_FC11E46C_TELSDA26_05C_PCB01_GPRS_MT6226_ S01.BASECODE.BIN_6AB6A24B_20081207-012338.B0X.bin Finished, time used: 440 sec Remove/Install battery now ! Here is complete ffs formate : COM4 selected module v2.70 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: "format ffs" Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:A103:000F boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.FC11E46C.[TELSDA26_05C_PCB01_GPRS_MT6226_S01.BASECODE.BIN_6A B6A24B].rpl identification#1 detection finished device-id: FC11E46C identification#1 protocol ver: 04 ver. sw 1: TELSDA26_05C_PCB01_GPRS_MT6226_S01.BASECODE.BIN ver. sw 2: BASECODE, B45D4995 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: 01227E22202200:29EA0000000000 checking area [00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... flash: 01227E22202200:29EA0000000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... formatting... flash: 01227E22202200:29EA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_FC11E46C_TELSDA26_05C_PCB01_GPRS_MT6226_ S01.BASECODE.BIN_6AB6A24B_20081207-013014.B0X.bin Finished, time used: 42 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! Sir i want revive this fone with infinity plz help me plz asist me what whould i have to do. . . i m waiting ur response Regard"s aamirgsm |
12-07-2008, 13:40 | #3 (permalink) |
Member: 526737 Status: Offline Thanks Meter: 9 | sir it is original flash backup version TELSDA26_05C_PCB01_GPRS_MT6226_S01.BASECODE it is original eeprom version eeprom[TELSDA26_05C_PCB01_GPRS_MT6226_S01.BASECODE.BIN]_20081203-051136.B0E Last edited by aamirgsm; 12-07-2008 at 13:45. |
12-07-2008, 22:57 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! flashfiles/ChineseMiracle/_MT6226/TELSDA26_05C_PCB01_GPRS_MT6226_S01.BASECODE__Nokia-6300-RH-30_16m_En_Ru_Fr_De_Id_Th_Vn_Cn_Tr_Farsi_Ar.B0M.bin make format FFS after flashing |
12-08-2008, 09:39 | #5 (permalink) | |
No Life Poster Join Date: Nov 2005 Location: .:GSM WORLD:.
Member: 203158 Status: Offline Sonork: 100.1592032 Thanks Meter: 358 | Quote:
Bro u also need to chek battery connectors .... and also for the advices by great infinity support. | |
infinity team plz help me | qadriatta | Infinity-Box | 2 | 03-08-2009 21:46 |
Infinity team plz help me and give me flash file | aamirgsm | Infinity-Box | 14 | 12-01-2008 08:41 |
infinity team plz help me | Raja_Vickey | Infinity-Box | 1 | 09-18-2008 21:50 |
c140 cant unlock in infinity team plz help me | ramesh_931 | Infinity-Box | 7 | 07-20-2007 17:47 |
Infinity team plz help me to flash for nokia E60 | .::Munazzam::. | Infinity-Box | 7 | 06-27-2007 19:53 |
