11-24-2008, 18:41 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! pinout is either in system connector or presented under battery as test points. you can examinate them with multimeter. attach battery and measure voltage on each pin in system connector. If you will see voltages 2,7-2,9 volts- those are tx/rx if not- check same way test points |
01-16-2009, 09:50 | #11 (permalink) |
Freak Poster Join Date: Mar 2008 Location: Tangerang indonesia Age: 42
Member: 730337 Status: Offline Thanks Meter: 65 | you can dowload here http://rapidshare.com/files/18415944...inout.rar.html |
The Following User Says Thank You to F-Buzz For This Useful Post: |
01-24-2009, 21:49 | #13 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello mr. Klodi. sorry, i got that phone, but failed to find pinout because it was dead by hardware reason. for you i still can advice to examinate test points with multimeter you will find pinout in 5minutes |
need BGA stencils for Nokia N73 N80 6500s 8800e art | rafauz | Wanted Products | 0 | 11-28-2008 16:55 |
8800e arte charge way deed you now....? | legend0655 | Nokia Hardware & Hardware Repair | 3 | 10-16-2008 20:46 |
8800e arte need pm | mishiko_gsm | Nokia Base Band 5 ( BB-5 ) | 1 | 06-04-2008 13:24 |
