08-15-2016, 07:24 | #1 (permalink) |
Freak Poster Join Date: Oct 2006 Location: sakonnakhon,Thailand
Member: 381241 Status: Offline Thanks Meter: 13 | To All Thai users who need help about SPD Phones We are waiting for Full Support of Super3 (SPD7701),Touch Plus(2 Sims,SPD7715) and Max Plus(2Sims,SPD7731) Please post here if you waiting this solution like me. Maybe infinity team will support its in near future. for me,200 Super3 phones waiting for unlock. BR. phitsawarn |
The Following User Says Thank You to phitsawarn For This Useful Post: |
08-18-2016, 06:35 | #2 (permalink) |
Member: 381241 Status: Offline Thanks Meter: 13 | Estimated 1,000S users in Thailand who used CM2 but no one post here. no one want to help infinity team,no one want to help yourself,very very very surprised. |
08-19-2016, 07:13 | #4 (permalink) |
Member: 381241 Status: Offline Thanks Meter: 13 | Hello,YellowBoss I need to send sample phones to you for research if possible. But I don't know how to contact you. If I send samples to you via Group Tour to Russia,and Russian Guide will send you samples,Is it possible? Or I can send via FedEX to your Bussiness Address.Can you accept this? Please PM me If possible. BR. phitsawarn |
08-28-2016, 05:08 | #6 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. If there is any way bring phones to Russia territory - let me know in PM possible ways. Will try think about further moves. BTW : read and send me NVM's from a both phones : Touch Plus(2 Sims,SPD7715) and Max Plus(2Sims,SPD7731) And attach logs of unlocking try, but make backups first! |
The Following 2 Users Say Thank You to JayDi For This Useful Post: |
08-28-2016, 06:21 | #7 (permalink) |
Member: 381241 Status: Offline Thanks Meter: 13 | Hello JayDi Please read PM about sample phones. about Touch Plus(2Sims,SPD7715)and Max Plus(2Sims,SPD7731) can't read NVM from both phone. For Max Plus can't do any opertion. here is log ========================= Start ========================= 28/8/2016 / 11:38:02 ================================================== ======= Card found: S/N : D0096xxx , v0132 Chinese Miracle II [SPD module] v 1.20 Start at : [28/8/2016 / 11:38:28] Operation : Check/Read Info [ v1.20 ] 1. Remove battery. Insert battery back 2. Insert cable 3. In case of SVC init problems - connect with hold "VolDown" button! ==== Wait for phone... Phone found! [ 59 ] Port Opened Sync... InitSvc Done Wait for phone... Sync... Phone Initial Info : Platform : MOCORTM_14A_W14.41_P15.12_P4_Debug Project : sc7715_modem HWInfo : sc7715_sc7715_modem Compile : 01-25-2016 16:41:17 Phone Security Info : IMEI [1] : 8699960245489xx IMEI [2] : 8699960295489xx BT_ADDR : 000000000000 SelfInfo : BatVoltage : 3.711 V Done Reconnect Power/Cable! Start at : [28/8/2016 / 11:39:26] Operation : SP Unlock [ v1.20 ] Mode : DirectUnlock 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 59 ] Port Opened Sync... Initial Boot Failed! Reconnect Power/Cable! |
08-31-2016, 06:34 | #9 (permalink) |
Member: 381241 Status: Offline Thanks Meter: 13 | To JayDi successfully read NV from phone Start at : [30/8/2016 / 19:39:47] Operation : Check/Read Info [ v1.20 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 59 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : P909 Model Brand : SPRD Model Device: P909 AndrVersion : 5.1 BaseBand CPU: P909 CompileDate : 16/3/2016 11:04:24 Project Ver : SMART_MAX_4.0_PLUS_V1.0.3_20160316 Model Ext : SMART MAX 4.0 PLUS ExtraInfo : HWInfo not exists, normal phone Elapsed: 00:00:16 Reconnect Power/Cable! Finish at : [30/8/2016 / 19:40:04] Start at : [30/8/2016 / 19:40:31] Operation : Read NV [ v1.20 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 31 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! Detected eMMC Flash , Structure detect Ok! Read GSM NV Read WCN NV Read Ok , 0x00029878 Saved to : C:\InfinityBox\CM2SPD\phdata\backup\CX_SPDNV.spdnv Elapsed: 00:00:57 Reconnect Power/Cable! Finish at : [30/8/2016 / 19:41:28] Start at : [30/8/2016 / 20:07:26] Operation : Check/Read Info [ v1.20 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 31 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : hy602plus_UUI_B158 Model Brand : TRUE Model Device: hy602 AndrVersion : 4.4.2 BaseBand CPU: HY602 CompileDate : 25/2/2016 7:27:15 Project Ver : SMART_3.5_Touch_Plus_Lock_V07_20160225 Model Ext : SMART 3.5'' Touch+ ExtraInfo : HWInfo not exists, normal phone Elapsed: 00:00:11 Reconnect Power/Cable! Finish at : [30/8/2016 / 20:07:37 Start at : [30/8/2016 / 20:08:36] Operation : Read NV [ v1.20 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 59 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! Detected eMMC Flash , Structure detect Ok! Read GSM NV Read WCN NV Read Ok , 0x000304A8 Saved to : C:\InfinityBox\CM2SPD\phdata\backup\CX_SPDNVt.spdn v Elapsed: 00:01:03 Reconnect Power/Cable! Finish at : [30/8/2016 / 20:09:40] |
08-31-2016, 06:44 | #10 (permalink) |
Member: 381241 Status: Offline Thanks Meter: 13 | To JayDi NVitem_Max_Plus and Smart Plus uploaded to server via iOsFileUploader. please check. Is it safe to try to unlock now or have to wait for check NVM first? BR. |
09-02-2016, 04:49 | #11 (permalink) | |
Member: 381241 Status: Offline Thanks Meter: 13 | Quote:
Do you get it? | |
