Old 02-24-2011, 13:16   #1 (permalink)
Registered User
Member: 1359163
Thanks Meter: 37
AnyCool NOR 6205-6239 read flash problem
I Read full flash and firmware with Page .
but after that Language Package Editor dont find any language
When I try to read full flash or firmware with Boot autodetect autoselect on/off and Page + Spare . I have log:
COM5 [VCP0] selected
module v3.26
Device: Autodetect 6205-6239 NOR
Checking data, wait...
Action: read flash
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6235:8A04:8A01]...
CPU: MT6235
high speed boot On
chip: 0000:0000:0003
status: FF
boot packet size: 0400
Release Power button now !
in case of initial connection problem: on/off "Boot baudrate autoselect"
Boot Fail
Finished, time used: 32 sec
Remove/Install battery now !
any solution to read firmware with language to change it ?
The Following User Says Thank You to konaku For This Useful Post:
Old 02-24-2011, 21:19   #2 (permalink)
Registered User
Member: 1359163
Thanks Meter: 37
It`s possible to read fullflash with infinity ?
Old 02-24-2011, 22:37   #3 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
you must select NAND CPU type, page+spare
Old 02-26-2011, 10:36   #4 (permalink)
Registered User
Member: 1359163
Thanks Meter: 37
hello!
NOW I HAVE :
module v3.26
Device: Autodetect 6228-6253 NAND
Action: write flash NAND
write: Firmware
AnyCool 72% PL editor_corrected_AnyCool to polish 3180_PCB01_GPRS_MT6235B_S01.ZZT_3180WP04_5_5T10D10 0930_MB01__firmware_20110225-193341.B4M.bin.B4M.bin
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
nfi area detection...
nfi scat area detected (3 areas)
nfi area detection (3 cores) finished: Ok
interface: BROM_DLL_v3.1016.00
Connect...
Connecting...
Booting...
bootcode current/expected: 3.2/3.2
CPU: 6235:8A04:8A01
status: FF
bbchip bl ver: FE
NOR flash chip: not installed
NAND flash id[0018]: 00AD:007900A50000 [HYNIX] HY27XA081G1M
chip size: 128Mb
page/spare size: 0200/0010
pages per block: 0020
bits i/o: 08
address cycles: 04
internal RAM size: 00010000
external RAM: S_DA_RAM_ERROR
done
Set baudrate (460800)...
done
ram test...
testing...
ram test passed
===> detect existing firmware structure...
detect ffs...
ffs offset/size: 02000000/06000000
firmware size: 32Mb
ffs size: 96Mb
detect sec ro...
detect custom parameters...
detect project-id...
project-id: ZZT.3180WP04.5.5T10D100930_MB01
detect NAND info...
number of areas/bytes to read: 1:00034000
reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)...
bootloader version: 3180_BOOTLOADER_V005_MT6235B_ZZT_3180WP04_5_5T10D1 00930_MB01.bin
warning: ffs can not be detected
TCL-ID detection...
TCL-ID detection done
startup code area #1 detection...
number of areas/bytes to read: 1:00004000
error: unexpected answer:
startup code area #1 is valid
startup code area #1 detection done
rom info ver: 07
sw version: 3180_PCB01_GPRS_MT6235B_S01.ZZT_3180WP04_5_5T10D10 0930_MB01.BIN
project-id: ZZT.3180WP04.5.5T10D100930_MB01, 9CED6B5D
code offset: 00000000
rom info structure: [protected] type (07), 1 record(s)
TCL-ID is absent
===> done
startup code area #1 check...
rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.00006235.[3180_PCB01_GPRS_MT6235B_S01.ZZT_3180WP04_5_5T10D10 0930_MB01.BIN_5D6BED9C].rpl
rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.00006235._3180 _PCB01_GPRS_MT6235B_S01.ZZT_3180WP04_5_5T10D100930 _MB01.BIN_5D6BED9C_.rpl
rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.00006235.[3180_PCB01_GPRS_MT6235B_S01.ZZT_3180WP04_5_5T10D10 0930_MB01.BIN_5D6BED9C].rpl
rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.00006235._3180_PCB01_GPRS_MT6235B_S01.ZZT_3180WP 04_5_5T10D100930_MB01.BIN_5D6BED9C_.rpl
warning: unknown firmware: 3180_PCB01_GPRS_MT6235B_S01.ZZT_3180WP04_5_5T10D10 0930_MB01.BIN_5D6BED9C
Unknown firmware found (v.3.26, database date: 13.01.2011), user action required:
1. download latest software from support area and try again
2. if no still luck follow the next procedure:
- find good working phone with the same firmware:
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage
- include in your e-mail full text from phone back label (phone name etc.)
- be little bit patient and wait update
error: startup code area #1 can't be fixed
You can flash phone now but can not finalize it,
in most cases phone CAN NOT power-on.
Do you want to continue anyway ?
number of cores: 3
loading files...
number of areas: 3
done
write...
write bootloader...
write core...
Disconnect...
done
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\3 180_PCB01_GPRS_MT6235B_S01.ZZT_3180WP04_5_5T10D100 930_MB01__system_log_20110225-204602.B4X.bin
Finished, time used: 15 min 25 sec
now phone not power on,
format safe FFS dont change power on problem
how to write correctly this firmware and have full working phone ?
Old 02-26-2011, 13:27   #5 (permalink)
Member: 764950
i have same problem
i have a same problem with x7 iphone clone mt6235....
here is the log
COM9 [VCP1] selected
module v3.26
write: Firmware
V101_PCB01_GPRS_MT6235B_S01.X7_101213_V1_4_QC_SET_ FOR10.BIN_FLNHYG0UGG0MF1P_5SH0E__fullflash_2011022 6-194930.B4M.bin
skip: Customization
skip: Eeprom/ffs
converting data...
done 0x07C1F200 bytes
bootloader version: V101_BOOTLOADER_V005_MT6235B_X7_101213_V1_4_QC_SET _FOR10.bin
"format ffs" active
Connect...
Connecting...
Booting...
CPU: 6235:8A04:8A01
status: FF
bbchip bl ver: FE
chip size: 128Mb
bits i/o: 08
address cycles: 04
done
Set baudrate (921600)...
done
ram test...
testing...
ram test passed
detect ffs...
ffs offset/size: 03400000/04C00000
firmware size: 52Mb
ffs size: 76Mb
detect sec ro...
project-id: X7_101213_V1.4_QC_SET_FOR10
detect NAND info...
TCL-ID detection...
startup code area #1 is invalid
rom info ver: 07
sw version: V101_PCB01_GPRS_MT6235B_S01.X7_101213_V1_4_QC_SET_ FOR10.BIN_FLNHYG0UGG0MF1P_5SH0E
project-id: X7_101213_V1.4_QC_SET_FOR10, 71F9FB49
TCL-ID is absent
===> done
converting data...
rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.00006235.[V101_PCB01_GPRS_MT6235B_S01.X7_101213_V1_4_QC_SET_ FOR10.BIN_FLNHYG0UGG0MF1P_5SH0E_49FBF971].rpl
rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.00006235._V101 _PCB01_GPRS_MT6235B_S01.X7_101213_V1_4_QC_SET_FOR1 0.BIN_FLNHYG0UGG0MF1P_5SH0E_49FBF971_.rpl
rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.00006235.[V101_PCB01_GPRS_MT6235B_S01.X7_101213_V1_4_QC_SET_ FOR10.BIN_FLNHYG0UGG0MF1P_5SH0E_49FBF971].rpl
rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.00006235._V101_PCB01_GPRS_MT6235B_S01.X7_101213_ V1_4_QC_SET_FOR10.BIN_FLNHYG0UGG0MF1P_5SH0E_49FBF9 71_.rpl
warning: unknown firmware: V101_PCB01_GPRS_MT6235B_S01.X7_101213_V1_4_QC_SET_ FOR10.BIN_FLNHYG0UGG0MF1P_5SH0E_49FBF971
number of cores: 3
loading files...
number of areas: 3
done
write...
write bootloader...
write core...
warning: can not format: HW_STORAGE_NOR is not present
Format...
Disconnect...
done
Finished, time used: 16 min 16 sec
please help
Old 02-26-2011, 16:18   #6 (permalink)
Member: 148515
hello!
what happen if you write original (not translated) backup?
Old 02-27-2011, 07:55   #7 (permalink)
Member: 764950
no..my one is original...backuped from working phone
Old 02-27-2011, 08:05   #8 (permalink)
Member: 1043909
Thanks Meter: 60,912
@ays_babes2
send original flash backup files to [email protected] and in 1 day you will be able to flash your phones
Old 02-27-2011, 22:34   #9 (permalink)
Member: 148515
hello!
what happen if you write t as "firmware"?
Old 03-01-2011, 04:08   #10 (permalink)
Registered User
Member: 1359163
Thanks Meter: 37
hello!
27-02-2011 I send to you , To: <[email protected]>
flash file,
Did you check this firmware ?
Old 03-01-2011, 17:26   #11 (permalink)
Member: 148515
hello!
i just checked our email dated 27th.
no mail with version V101...
can you upload it to rapidshare.com and post link here?
Old 03-01-2011, 20:16   #12 (permalink)
Registered User
Member: 1359163
Thanks Meter: 37
hello!
If thisi is the best way for you , so there is a link to rapidshare
http://rapidshare.com/files/45045840...ware_20110225-
best regards
Old 03-01-2011, 22:59   #13 (permalink)
Member: 130995
Thanks Meter: 35,227
@konaku
Are you sure that it's ORIGINAL file (from good working phone) ?
I can not extract required data from this file, I think that it's not original file, or file that was read from phone with VERY old ChineseMiracle software version
Old 03-02-2011, 00:34   #14 (permalink)
LA4
Member: 5288
take file and write by Flashtool. your phone will be restored
http://rapidshare.com/files/45049332...00930_MB01.rar
Old 03-02-2011, 07:37   #15 (permalink)
Registered User
Member: 1359163
Thanks Meter: 37
Originally Posted by InfinitySupport View Post
@konaku
This is another flashfile N8 , i have problem with Language Package and correctly
write flash to phone , when I change language to othere , and try to write it
I in new language I have many of squares rather than letters. So take a look at this firmware
http://rapidshare.com/files/45046797...D_BQ12__firmwa
5110 flash new software , need help steve Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 01-03-2015 05:41
Eeprom reading KLImax Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 09-22-2011 15:55
Page generated in 0.34331 seconds with 9 queries
