Old 01-21-2009, 23:51   #1 (permalink)
Member: 904271
Thanks Meter: 3
Question Aparent Nokia 6128...
I found a new version for this chinese phone....
I cannot found the correct pinout..... the connector from usb cable its too similar to D800 samsumg, dissambling the usb cable found usbrx its pin 9, usbtx pin 8, and pins 1234 are gnd......
Old 01-22-2009, 01:29   #2 (permalink)
Member: 904271
Thanks Meter: 3
The problem is cant get network, searching i found this code *#3646633#, and set to 850 band and cant get network, for get software version used this code *#8375#,
VERSION A:E88_JQ3WDOVF10.01.0_25S00
B: E88AGENT_F1.01.1
BRANCH: 06B
BUILD: BUILD_NO
SERIAL#: E88012290001702
BUILD TIME
A:2007/12/30
B:2007/11/13
Old 01-22-2009, 19:45   #3 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
lets start from checking what CPU it is based.
you either can do this by disassembling phone or by typing *#0044# and pressing green (send) button.
if you will see "language set: english"- you can be sure, that this phone is supported by Infintiy software
Old 01-23-2009, 01:22   #4 (permalink)
Member: 904271
Thanks Meter: 3
hello
Do you see the pics?, both cpu its MT based, MT6225A and MT6223AA, the problem its cant get network on 850 band, in my country have 850 band and 1900, i typed *#0044# and pressing green (send) button and appear "language set: english", now the problem its cant get pinout.... now its possible flash it with usb original cable?
Old 01-23-2009, 19:38   #5 (permalink)
Member: 148515
hello!
i can teach how to find pinout for this model using multimeter
Old 01-24-2009, 01:19   #6 (permalink)
Member: 904271
Thanks Meter: 3
plzz help me!!!! how i can do this...............
Old 01-24-2009, 21:30   #7 (permalink)
Member: 148515
hello!
1. set multimeter to voltage measuring.
2. check bettery voltage, it should be more than 3,7volts
3. set one multimeter probe to some grounded phone part
(if you cant find grounded part outside phone- you need to take out small thin wire from negative battery terminal)
4. with second probe touch one by one all phone pins (phone battery attached)
(to get better result i would advice to set needle on the end of second probe)
memorise pins with voltage between 2,7-2,9volts.
those are tx/rx
Chinese Nokia 6128. Raklm Chinese Cocktail 3 07-08-2008 12:28
chinese nokia 6128 pinout TEHGSM Infinity-Box 7 07-01-2008 10:41
I-phone donīt like to support their boxes and aparently...... sergioems Griffin 30 10-28-2004 20:44
LCD - Cover - Chargers - Betteries and many gsm apare parts ...welcome NhatcuongGSM! Nhatcuong Main Sales Section 0 02-26-2003 05:52
aparently dead c25 kajo_mesquita x1x to x45/x50 0 11-07-2000 07:13
Page generated in 0.17143 seconds with 10 queries
