04-07-2012, 12:31 | #1 (permalink) |
No Life Poster Join Date: Dec 2008 Location: some were in my head Age: 42
Member: 922273 Status: Offline Sonork: 100.1583612 Thanks Meter: 119 | huawei g 6150 ok ==== [07/04/2012 12:19:09] ==== COM3 [VCP0] selected module v4.12 Model: Huawei-G6150 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6253:8A02:8A00]... CPU: MT6253 high speed boot On chip: 0000:0000:000F status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6253,E02 Date: 2000.00.00 Version: 1.0 Version: FRAC26B181SSC Version: VER.B ==================== New firmware found (v.4.12, database date: 28.11.2011): FRAC26B181SSC This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare ? Secure Data Logistics or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== 115 byte(s) read imei: 35xxxxxxxxxxxxx Finished, time used: 26 sec Remove/Install battery now ! Now click to "OK" button and press and HOLD phone "Power" button again ! interface: META_DLL_v6.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... done Release Power button now ! Shutdown... done Finished, time used: 7 sec Remove/Install battery now ! |
The Following User Says Thank You to GFTELECOM For This Useful Post: |
04-07-2012, 12:47 | #2 (permalink) |
Freak Poster Join Date: Mar 2011
Member: 1527470 Status: Offline Thanks Meter: 11 | module v4.23 Model: Huawei-G6150 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6253:8A02:8A00]... CPU: MT6253 high speed boot On chip: 0000:0000:000F status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6253,E02 Date: 2000.00.00 Version: 1.0 Version: FRAC26B176SSC Version: VER.B 115 byte(s) read imei: 3557*********** Finished, time used: 6 sec Remove/Install battery now ! Now click to "OK" button and press and HOLD phone "Power" button again ! interface: META_DLL_v6.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... done Release Power button now ! error: last error: 0012:[FAT] Target FAT file not found Shutdown... done error: operation failed ! Finished, time used: 5 sec Remove/Install battery now ! what is problem with my set |
04-07-2012, 13:09 | #3 (permalink) |
Junior Member Join Date: Apr 2012
Member: 1744578 Status: Offline Sonork: energy_fx Thanks Meter: 0 | How to get unlock code for Huawei U9120 Please do help me in getting the valid unlock code, i found some online calculator but dat is nt working,. Please help. |
08-01-2012, 00:31 | #5 (permalink) |
No Life Poster Join Date: Dec 2004 Age: 50
Member: 95476 Status: Offline Thanks Meter: 185 | huawei g6150 unlocked with infinity just selecte red code COM1 [Serial0] selected module v4.13 Model: Huawei-G6150 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6253:8A02:8A00]... CPU: MT6253 high speed boot On chip: 0000:0000:000F status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6253,E02 Date: 2000.00.00 Version: 1.0 Version: FRAC26B181SSC Version: VER.B ==================== New firmware found (v.4.13, database date: 08.05.2012): FRAC26B181SSC This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare ? Secure Data Logistics or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== 115 byte(s) read imei: 35391604140654 Finished, time used: 3 min 7 sec Remove/Install battery now ! Now click to "OK" button and press and HOLD phone "Power" button again ! interface: META_DLL_v6.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... done Release Power button now ! Shutdown... done Finished, time used: 6 sec Remove/Install battery now ! |
The Following User Says Thank You to lader For This Useful Post: |
08-01-2012, 10:00 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works, what is phone hardware configuration (f.e. flash chip type) and what is possible problems (so we will be able to fix it) and successfully done work. |
09-11-2012, 11:32 | #7 (permalink) | |
Insane Poster Join Date: Jan 2010 Location: PARIS
Member: 1216581 Status: Offline Sonork: btcoolmi Thanks Meter: 3 | Quote:
module v4.12 Model: Huawei-G7010 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6253:8A02:8A00]... CPU: MT6253 high speed boot On chip: 0000:0000:000F status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6253,E02 Date: 2000.00.00 Version: 1.0 Version: FRAC26B176SSC Version: VER.B 115 byte(s) read imei: 35XXXXXXXXXXXXXX Finished, time used: 8 sec Remove/Install battery now ! Now click to "OK" button and press and HOLD phone "Power" button again ! interface: META_DLL_v6.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... done Release Power button now ! error: last error: 0012:[FAT] Target FAT file not found Shutdown... done error: operation failed ! Finished, time used: 9 sec WHY I CAN UNLOCk,? were is the pb? | |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
6150 Lock Problem | Zeljko | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 10-16-2013 08:16 |
IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-15-2011 13:08 |
i can unlock all nokia 5110/6110/6150 | spterminator | Main Sales Section | 0 | 07-30-1999 03:05 |
